Question about Samsung UN32EH4003F
Can't get the color to work - Samsung UN32EH4003F
Philips magnavox tv model 9p5511c101
if it was working ok before then ring up and complain and get him back as he did not do the installation properly.
Jun 09, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
Beamerproblem! I've got a red-color problem with
Take it to GameStop. They can find the problem lickety-split!
May 17, 2013 | Office Equipment & Supplies
Color duplex doesn't work
The Canon DR-3080C is only color on the front side. The back side is monochrome only. The next model, which was the DR-3080CII will do double sided color scanning
Sep 13, 2012 | Canon DR 3080C Path-Through Scanner
Won't print because color is out, I have setting on black only shouldn't that work?
i think all printers do not print if one of the separate color cartridges is empty. check ink and replace. hope this will help.
Apr 02, 2012 | Canon PIXMA MX310 All-In-One Printer
Swarm Assault's color scheme is corrupt on Windows 7.
I have the game too, played it on Win 95/98. You can do those for compatibility mode, or XP SP2/3.
Under that is the Settings. You can check all those options there (that's how I did it) and just run it with administrator mode.
There you have it, it's fixed, only problem I'm facing now is the blinking "windows circle" from the start bar. That is all.
Mar 06, 2012 | Gate 5 Creations Swarm Assault
I don't know how to successfully connect a JVC AV-27220 (a television) to HR-XVC29SU (a DVD player). I have a set of blue/red/green cables, but the colors don't match the markings on the devices....
The standard colors are : White, Yellow and Red. If you match the Red of the TV, the White of the TV and the Yellow of the TV to the same colors on the DVD player, then all should work properly. It does not matter what color the cable is, match color for color on the devices. Hope this helps and good luck from a teacher to another teacher.
Oct 29, 2017 | JVC AV-27220 TV
Hi, I bought a second hand HP VP6315 for an xbox 360. It works perfectly for 15 minutes and then turns from a colour picture to black and white. It has approx 1700 hours left on the bulb and is connected...
DLP projectors use a color wheel to add the color information to a black and white image. If the wheel doesn't work correctly, you get wrong colors or no color at all. I've never worked on one of these, so I don't know if the color wheel is a separately-replaceable part or is part of the lamp module. I haven't been able to locate a service manual or full parts list to check further, but I'll post a follow-up if I find more information.
The usual problem is that the color wheel motor goes bad and it stops spinning, but there could be other electronic problems as well. It could be simply a matter of bad connections that act up after the unit's been running for a while (thermal trouble). You can try researching this model further on the Web to see if anyone can provide detailed parts info, or see if a service shop in your area works on these. And as I said, if I turn up any more information I'll add it.
Good luck, and thanks for using Fixya!
May 14, 2011 | HP vp6315 DLP Projector
Installing only one printer cartridge
suggest you install a color cartridge and set up the printer for color. When the color cartridge runs out of ink, you should be able to continue printing in black only.
Mar 19, 2010 | HP PSC 750 All-In-One InkJet Printer
Samsung UN32EH4003F Logo
23 people viewed this question
Henry  Thomas
Henry Thomas
