Question about Makita 3612C Router
My makita 3612c speeds up and slows down on its own
Regardless of the position and speed, my unit speeds up and then slows down. What is the problem?
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Where can I get an operator's manual for my Makita
Here is the link to your manual. Thanks for using Fixya
http://powertool.manualsonline.com/manuals/mfg/makita/3612_3612c.html
Posted on Feb 20, 2010
Slow sewing regardless of speed setting
I'm thinking that the problem is in the foot control
take the foot control to a sewing machine repair shop and have it checked out
you say it appears aftermarket--probably is to replace a faulty OEM unit
Aug 22, 2016 | Janome Memory Craft 6500P / MC6500P...
Can the Rpm on the singer speed be slowed down?
if you are talking sewing machine the machine speed is controlled by the foot control. Light pressure slow speed through to full pressure is max speed. If it runs flat out regardless of the foot control position then the fault will be there or the resistance part near the motor.. Have a sewing machine mechanic look at it.
Jun 26, 2013 | Cars & Trucks
My makita 3612c router sounds bad and don't function well ,as can be heard in the video, I can see sparks coming from the brushes!!! Any idea about how to fix? What is the cause of such a problem
You probably have no brushes left running on the armature hence the big sparks and noise. The armature will be beyond repair Take to an appliance repair shop but I fear that it will be cheaper to junk it and get a new one.. My experience with Makita is that the brand is selective in the quality.
Apr 04, 2013 | Tools & Hardware - Others
Unit has hard time starting, need to turn wheel, only runs at slow speed
you have a problem with the bearings or the motor/brushes are burnt. Does this tool arc when running. If so I would check the brushes first, unplug the tool and remove them and while they are out rotate the motor slowly and look at the commutator bars for excessive discoloration or unusual wear.
May 08, 2011 | Makita 9565CV 5" Variable Speed Angle...
GE JVM1430 over the range microwave/exhaust fan unit. The exhaust fan (not the microwave cooling fan) all of a sudden has its speed slowed down considerably. The unit vents out the back, not top. ...
Sounds like a strip down of the fan and lubricate the bearings with sewing machine or thin cycle oil will do the trick.
Hope that helps.
Jan 20, 2011 | Microwave Ovens
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Hobart 135 wire feed sped control problem
you have a resistor down, first check the resistor on the centre pole then those going off to the two other pins
Oct 04, 2009 | Hobart Handler 140 Mig Welder
Can a Model 3612C be connected to a router table
It looks like it can BUT before trying where are you located and I will try and find a Makita Factory Branch in your area that can make that decision or if you want I have Makita Headquarters phone number also. Let me know. Dave
Oct 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 3612C Router Logo
42 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
