Question about Dryers
Status on control panel showing control locked light on not allowing machine to operate
    Genius:
  • Dryers Master
  • 1,669 Answers
The main panel control system is not functioning. Replace it.
Posted on Jan 20, 2013
3 Suggested Answers
  • 107 Answers
SOURCE: Gas duet. Mod: GGW9250PWO Ser: MR3604435. Front
is the other lights DIM(partially lit)?
If so it could be one of the following.
1.) Intermittent ribbon cables between the control board and the Interface board (one with the buttons) Reseat all four cables.
2.) faulty control board.
3.) faulty Input board.
Posted on Nov 12, 2009
SOURCE: control locked light is lit not allowing any operation of the dry
Did you try unlocking it by pressing on the "End of cycle" button for 3 seconds.
If that doesn't solve the issue, it might be the control board (user interface) might have gone bad.
I had the same issue with my GEW9250 and I had followed these steps to repair the board. I am not sure if it works for you, but you can try it out.
Open the User interface control board
Then remove the PCBS (the green control boards)
Check the led bulbs, for me one of them is fried. You can use volt meter to test it.
Remove the bulb(s) that are fried (not working)
That should fix it...
Posted on Jul 31, 2010
Maytag dryer control is locked. how do I unlock it?
Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light goes out when the control panel is unlocked. Also try unplugging it for five minutes to allow it to reset
Jan 12, 2018 | Maytag Washing Machines
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
Whirlpool duet dryer
Oct 22, 2013 | Dryers
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
The "Control Locked" light is
Mar 31, 2011 | Washing Machines
The locked control indicator has a red light and won't allow the machine to do anything; what should I do?
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Jan 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Machine is stuck in control lock
This feature allows you to lock your settings to prevent unintended use of the dryer.You can also use the Control Locked feature to prevent unintended cycle or option changes during dryer operation.
To enable the Control Locked feature when dryer is running:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
The control is locked when a single beep is heard and the Control
Locked status light is on.When the dryer is off,it is not necessary
to press the Control On button before activating the Control Locked
feature.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds to turn this feature off.
NOTE:
When the dryer is running and Control Locked is on, the dryer can be
stopped by pressing the Pause/Cancel button,but can't be restarted
until the control is unlocked.
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It is showing control locked
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can easily be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, or by leaning against the control panel and is usually not an indication of a washer malfunction.
If this is a Whirlpool Duet series, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope you find this information helpful.
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
Locking controls
lit, all buttons are disabled. You can lock the washer while it is
operating.
Select and hold END OF CYCLE SIGNAL for 3 seconds.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
56 people viewed this question
Top Dryers Experts
