Question about Roper RES7646KQ Electric Dryer
Maytag dryer not heating!
Neptune i think! the one that looks like a fridge. dries top and bottom. clothes have been in dryer over 1 hour and still wet!
  • 537 Answers
Check the heating element for the dryer.
I found it in this FixYa thread:
http://www.fixya.com/support/t1168199-roper_electryc_dryer_will_not_heat
Posted on Jan 26, 2009
My Maytag Neptune Dryer works great with no close in it. As soon as you put clothes in it wont stay hot.
Instructions
Things You'll Need:
* Level
1. Ensure that the dryer's door is latched shut and that the power cord is plugged into an electrical outlet. Also check the home's fuse box for a tripped circuit breaker.
2. Make sure that the "Air Fluff" button on the dryer's touchscreen has not been selected if the dryer fails to produce heat. Also clear the lint screen if the dryer fails to heat.
3. Check the exhaust system, which exits from the back of the dryer for clogs, which commonly occur if the lint screen has not been cleaned regularly. Also ensure that only 4-inch metal exhaust tubing is used for the exhaust system. If clogs are present due to an improper exhaust system, the dryer will fail to dry the clothing completely. Also avoid overloading the dryer, which can also cause a drying problem. The amount of clothing equal to a single wash load should not be exceeded.
4. Check for the presence of loose items if the dryer produces noise, such as coins and loose buttons. The dryer will also produce noise if it is not leveled properly. Place a level on top of the dryer and turn the foot located on the bottom of each corner of the dryer until the dryer is level.
Feb 23, 2011 | Maytag Neptune MDG6800 Gas Dryer
No heat coming out to dry clothes, can the heating element be replaced
yes, it is located on the back right inside of the dryer.
1) unplug dryer
2) open door remove screws
3) with a flat tip screw driver pry gently up on the top corners it will pop
4) move front panel forward and disconnect door switch
5) sit panel aside
6) lift top lid of dryer 90 degrees it has clip/hinged on back
7) look to the right back of dryer, it looks like a spring in a metal box disconnect and replace.
Hope this helps Tim
Sep 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
No heat when drying cloths
Check the vent that goes outside it may be blocked.
Jul 23, 2010 | Maytag Neptune MDG9700A Gas Dryer
My dryer is taking about 1 1/2 hours to dry. It still has the heating element working but no matter what setting I put it on, it is taking 91 minutes, 95 minutes to dry. Any ideas why it started to take...
How is the filter and exhaust pipe? Have you cleaned them recently? I think your machine has a clog somewhere between the filter and the outside vent hood.
Pull your machine away from the wall, remove the pipe ... if it is plastic, please consider replacing it with a metal one. Metal will not burn. Vacuum the pipe end to end - then check the flapper outside ... is it clogged? clean it.
Thanks for your interest in FixYa.com
Jun 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
It takes hours to dry the clothes. The dial moves
sounds like a bad timer. if it sticks every time replace they are expensive
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
NOt drying clothes like it should
Has air flow problem, check to make sure the vent going to the outside is not blocked. If it isnt, you should be able to take off back cover of dryer. Should be a duct that air goes through, take it apart and make sure there is no lint in bottom of it. I had the same problem and that fixed it.
Apr 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Roper RES7646KQ Electric Dryer Logo
164 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Roper Dryer Expert? Answer questions, earn points and help others
