Question about Directed OHD900 Car DVD Player
My dvd player does not read dvds of any kind, do I need to replace the whole player or does it charge up or something? What should I do?
My DMR_E80H recorder does not read blank dvd-r disks
I don't have a solution but I am having the same problem (same model DMR-E80H). It will read finalized dvds but won't recognize or play blank or non-finalized dvds. About a year ago I had to replace the hard drive . . . I'm just assuming that the dvd recorder is just slowly breaking down and will need some kind of repair of certain components. (I think we bought it new in 2003/2004?)
Feb 13, 2011 | Panasonic DMR-E80H DVD Recorder
Rotel dvd player not reading dvd but will read cd
if it doesnt read any kind of dvd discs at all it only means you have been rip off. It happened to my sony dvd player that I bought from this website. I tested it and it only reads cd or audio cd. Good thing my couzin fixes electronics, He checked on the lens and it turned out that the lens has been replaced with an audio/cd lens like the one we use for our car stereo. Too bad!!!
Jan 05, 2010 | Rotel RDV-1040 DVD Player
Reads only 15min and stops
sounds like a timing issue. might be a whole batch of those dvds were on assembly line and may all have that same issue.
Jul 02, 2009 | Televison & Video
Player doesn't read blank dvds
From the site of the company that built the computer or motherboard. Usually when this happens it is an head allignment problem or a dirty read head. Have you used/tried one of the cleaner disks on it? If that does not work then buy a replacement  DVD burner and replace it. The alignment is not something can can be done w/o fancy equiptment and burners are not expensive. All of the software wil still be intact and should work with the new burner expecially if you purchase the same brand.
Newegg.com    or                Tiger.com
Both online stores have  a good selections of OEM dvd burners.
Apr 03, 2009 | Computers & Internet
SONY DVP-S7000 does not play DVD
The laser head has probably just got dust on it, get a cleaning disk.
Jan 14, 2009 | Sony DVP-S7000 DVD Player
WILL MY DVD PLAY AREA 1 AND AREAV4 DVD'S?
Hi camonk2004,
It's interesting that your DVD player was purchased in Russia but plays Region 1 DVDs. Region 1 is North America. Does your Player also play Russian DVDs (region 5)? If so, then it has probably been modified to play DVDs from multiple regions.
Check the back side of the DVD player - the rear panel should have a Region number on it. If the region number is 1, then try playing a Region 5 DVD. If it reads the DVD, then the modification that was done in Russia will probably allow it to read any DVD. IF the Region 5 DVD won't play (or if it is ejected automatically), then your player's region control os still intact, and it will only play DVDs from the same region as the one listed on the rear panel of the player (or DVDs marked "ALL").
I hope this helps - please let me know if I can be of any further assistance.
Kind Regards,
H2H
Dec 15, 2008 | Pioneer DV-U7 DVD Player
Symphonic Video/DVD player- dvds not able to be read so they don't play
possibly check the setup of the player. some dvd's will not work in most players. check the manual. if under warranty take back to store. or better yet buy another one like it and take the one that is bad back to the store with the new receipt.
Oct 24, 2008 | Emerson PD6810 CD Boombox
Doesn't read dvd's
This problem is down to failure of the laser and an only be solved by replacing it. Samsung are aware of this fault but will only offer a free replacement if the unit is still covered by it's warranty.
They do offer a replacement service but charge £94 for it.
Jan 31, 2008 | Samsung DVD-HR734 DVD/HDD Recorder
Toshiba RD-XS35 DVD Recorder
Toshiba tech support for this one. If it is not accepting the cleaner disk - you have to wonder if something is already intere or do you mean will not rune the disk? Inwhich case it is a drive failure and needs replacement[of drive if available] or whole machine. Contact Toshiba first though it may be a known issue.
Jul 05, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Directed OHD900 Car DVD Player Logo
20 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
