Question about Hasbro Room Tech Beingz Alarm Clock Radio - Magenta
Alarm won't set
We have a red rund alarm clock I bought at Target - no name or manufacturerer on the clock. It has a roatating dial around the face that changes the time on clicking increments. It has only a set button and a light button. We have the time set and the alarm time, but can't set the alarm. Please help.
You have the room tech Beingz? If so, you go to set time, and then first set the hour with the first buttons. Then, you click the very top once, and you should, after it loads, be able to set the minutes.
Posted on Dec 10, 2010
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
I need discovery kids tm daisy clock manual
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between month/day/year/hour/minute. If it goes to the alarm setting instead of time setting, try again.
2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial near the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time)
Good Luck!
Jun 22, 2013 | Toys
Discovery kids rocket clock - no manual
I can't upload a manual but I can give you instructions:
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between m/d/y/hour/minute. If it goes to the alarm setting instead of time setting, try again.
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial under the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time) to change from 12 to 24 hr or vise-versa
Good Luck!
Dec 03, 2012 | Discovery Channel Discovery Kids - Rocket...
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
How to set clock on the teac sr-l100 just bought at yard sale, no info book. thanks d
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps!
To set the alarm on the TEAC SLR 100:
Be sure the radio is set to off or standby.
Hold down the BUTTON for the alarm you wish to set (#1 or #2) until the TIME ON THE DISPLAY begins flashing. Use the TUNER/CLOCKSET DIAL to change the display to the time you wish the alarm to go off. pRESS THE ALARM BUTTON BRIEFLY TO RETURN TO NORMAL OPERATION.
May 28, 2011 | Teac SRL50 Clock Radio
I have a seiko chonograph couturo alarm. 100m
Many of the Seiko Chronographs have the same setting options (mine is the lightweight "Titanium Sports").
First off, the alarm dial must show the same time as the actual main dial. If not you must adjust this first.
Pull the knob at number 4 position on the watch face out, until you feel two distinct notches/clicks (around 0.5mm travel) and the alarm will make a shrill buzzing for about 1 second.
Now turn the #4 knob to move the small alarm dial at the #6, to be the same as the actual time displayed on the main face, and press the #4 knob fully back in. This sets the alarm and the main time to the same ....er....time. You do not need to do this again, unless you adjust for daylight saving times during summer/winter.
Now you can set the alarm chime point.
Pull the #4 knob out again, but just one click. You should hear one ping from the alarm. Now press the button at #8 position. It will move the small alarm hands by 1 minute intervals, and if you keep it held in, the dial spins around quickly. This allows you to adjust the time the alarm will chime.
When you've got the alarm time and it's chime point set, leave the #4 knob at one click out.
If you wish to switch the alarm off simply press the #4 knob back in, and the alarm dial will spin around to the same time as the main dial.To re-enable the alarm pull the #4 out one click again. It's quite simple once you get the hang of it.
Jan 01, 2010 | Seiko Coutura Chronograph Watch
Clock set
To set the time press and hold the select button in the centre of the volume dial until the word demo appears on the screen. From here you can change the time by pressing the next track >>I button to select clock h. Use the use the volume dial to select the hour. Use the next track button >>I to select clock m and use volume dial to set the minute. This same procedure can be used to change the dimmer on/off, demo on/off and the amp gain. Have a play around. Hope thjis helped.
Jun 29, 2008 | JVC AM FM CD DET FACE CAR STEREO
TEAC SRL100 Set clock
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps! Ted
May 26, 2008 | Teac SRL50 Clock Radio
Setting the alarm alternatives
No solutions yet - just bought the last display model off the shelf at Target with no manual (Timex T617S). I'd like to find a hard copy or online manual, or just some help from a kind owner of this clock radio.
Feb 27, 2008 | Timex Audio Players & Recorders
Hasbro Room Tech Beingz Alarm Clock Radio - Magenta Logo
367 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
