Question about Microsoft Xbox 360 Console
Cant download xbox profile error 80151015
My xbox was skrewing up for a bit so i turned it off and when i turned it back on it froze on the start screen then 5 mins later it started for me to then find out that my xbox proflie was corrupted so i did what youtube said and deleted my account and try to down load it again but then i get sorry, xbox live profiles cant be downloaded right now. try again later 80151015
  • tyler bygrave Jan 20, 2013
    now the error is 08151909
    my consle is also getting slower.
4 Suggested Answers
  • 3 Answers
SOURCE: Corrupted profile on XBox 360
I have heared that if you just delete the profile, just the profile, everything will be just fine (note: This only works if your profile is on xbox live).
Just go to memor, then go into the saving device the corrupted profile is on. Then "click" on the botton that says profile and delete the corrupted profile. Remember; the profile will be a small save and not taking up most of your harddrive, look for something with MB size, not GB size. When you have done this, go to "recover gamertag" and do so for the profile you just deleted. After all this, your game saves and achivements should be present and working.
Posted on May 03, 2009
john1304
  • 37 Answers
SOURCE: corrupted profile
good luck i getting your problem solved with an attitude like that you certainly don't need our help. The problem was clearly too hard for you....
Posted on Jun 22, 2008
  • 321 Answers
SOURCE: I have a corrupt file problem I have 2 xbox 360's
um dont have the modded xbox hooked to the internet online bro, they see what that one tag does when you go online to gain ur achevements. so my point is to have ur Acheicement points show up on ur gamertag or your profile for instance, it has to be legit, that other xbox must have some file thats not allowing to use it cause that other xbox still has its internet hooked up
i think
Posted on Oct 23, 2009
How to adjust idle 2005 Honda 150 dirt bike
Hi, Anonymous you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How to Adjust Idle On Dirt Bike Tips and Tricks 1
How to tune CRF150F dirt bike other basics
CRF150F service manual repair 2003 2013 CRF150 Download Manuals Technical $10
http://www.partsfish.com/page/oem-parts-for-honda
Honda 2004 CRF150F Owner Manual
May 29, 2014 | 2005 Honda CRF 150 F
2005 Honda CRF 150 F idle adjustment
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Air screw question on CRF150 carb
Honda CRF150F Owner Manual
Honda VT 750 Shadow idle too low
Idle adjustments
Adjusting the Mixture Screws
Honda 1998 VT750C Service Manual
Honda VT750C Owner Manual
Apr 21, 2014 | Honda VT 750 Shadow Motorcycles
2006 Honda CRF 150 F slow to return to normal idle
https://crfsonly.com/forum/viewtopic.php?t=32974
CRF150 Hanging Idle
HONDA CRF150F Owner Manual
Jan 20, 2014 | 2006 Honda CRF 150 F
1982 yamaha xj550 idle too slow
Apr 22, 2012 | Yamaha Motorcycles
Honda cb 750 idle adjustment
CB750 idle problems
CB750 Tuning Adjusting
Honda CB750f2 Manual
Honda CB750F2 Owner Manual
Apr 09, 2012 | 1998 Honda CB 750 Nighthawk
1986 Yamaha pw80 carb settings
Yamaha Carb Tuning
Life On 2 Wheels
YAMAHA PW80 Owner Service Manual
OEM parts for Yamaha
YAMAHA PW80 Owner Manual
Feb 24, 2012 | Yamaha PW 80 Motorcycles
How do I adjust the idle on a 1994 Yamaha virago 750
Hi, Csbloom614 you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
Virago XV750 idle
Virago idle problem
Yamaha XV535 Owners Workshop Manual
YAMAHA XV535 Owner Manual
Sep 25, 2011 | Yamaha Motorcycles
How do I adjust the idle on a 2009 yamaha vstar 950?
Hi, Dscotty02 you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
vstar 950 idle speed
Carbtune For Throttle Bodies
2009 2012 Yamaha XVS950 Star Service Repair Manual DOWNLOAD Download... $10
YAMAHA XVS950A Owner Manual
Jul 04, 2011 | 2009 Yamaha V Star 950
2008 Honda VT 750 Shadow Aero carburetor adjustment
Hi, Rockin_hick1 you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
idle screw air fuel mix
2008 Honda Shadow Aero Idle Problem
Feb 02, 2010 | 2005 Honda VT 750 Shadow Aero
Microsoft Xbox 360 Console Logo
1,466 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
