Question about Singer 9960 - 9960 Quantum Stylist
Lcd problems for singer quantum stylist 9960
Lcd screen is very hard to read
2 Suggested Answers
  • 61 Answers
SOURCE: my singer quantum stylist 9960 bobbin case squeaks while sewing the stitches are fine its just sounds terrible
Oil it! Put a drop of oil on everything hat moves every eight hours of operation," except plastic gears etc". Use only Singer oil on Singer machines. Plastic gears require a grease made from plant.. "Do not use petroleum based oils or grease on your machine,it will dissolve the plastic gears etc". used in your machine..
Posted on Nov 13, 2013
Testimonial: "but the manual says do not oil this machine"
Troubles with the bobbin tension on the singer quantum 9960
the small flat spring on the bobbin holder under which you pull the thread is the tension setting for bobbin thread
it extremely delicate and just a partial turn of the screw that holds that spring in place has a large influence on the tension
mostly problems here are that the needle tension is insufficient and causes the problems
Oct 02, 2016 | Singer 9960 - 9960 Quantum Stylist
How do I do a factory reset on a Singer Quantum Stylist 9960?
Here is a link to the instruction manual, if you can do a reset it will be in the manual, if not then it is not an option http://www.singerco.com/uploads/download/1242_9960_esf.pdf
Jul 02, 2016 | Singer 9960 - 9960 Quantum Stylist
What could cause the singer 9960 presser foot does not lift with presser footlifter
Apparently the lifter is loose or broken. Remove front cover , check movement of lifter where lifter stops movement will be where your problem begins!
May 28, 2014 | Singer 9960 - 9960 Quantum Stylist
My sewing machine jammed, not it won't turn on and reset
Mine is doing the same thing. Have you found what the problem is? My email is laneytay@msn.com
May 18, 2014 | Singer 9960 - 9960 Quantum Stylist
My singer quantum stylist 9960 bobbin case squeaks while sewing the stitches are fine its just sounds terrible
Nov 13, 2013 | Singer 9960 - 9960 Quantum Stylist
Singer 9960 automatic thread cutter not working
I'm looking for a solution to why the thread cutter isn't working. It just pulls the thread into a knot and jams the bobbin case. I was hoping for an answer here but the answer had nothing to do with the question!
Sep 20, 2013 | Singer 9960 - 9960 Quantum Stylist
Singer 9960 - 9960 Quantum Stylist Logo
50 people viewed this question
Top Singer Irons Experts
Chance Miller
Are you a Singer Iron Expert? Answer questions, earn points and help others
