Question about Kenmore Dryers
Drum turning slow and sometimes not at all - Kenmore Dryers
    Top Expert:
  • Kenmore Master
  • 35,672 Answers
It may be time for a belt replacement
Posted on Jan 20, 2013
My brakes squeal only in reverse with the brake lightly applied to roll back slow.
Brakes can be strange sometimes. There may be a "Hard Spot" on the brake shoe/pad or even on the drum/rotor. You may need to have the drum/rotor turned. Sometimes they can sand or rough up the shoe/rotor to resolve the issue. Make sure the wear sensors are not damaged or alignment.
Sep 29, 2017 | Cars & Trucks
I have a question in that the washer when it turns either way I hear a knocking sound and I am concerned about this problem if any. Next the hot water is coming out slowly and I checked the fix it
is this front loader? if so, reach into the drum and try to move it up and down - there should be no play. sometimes the arm holding the drum will corrode and break causing the drum to come loose. it's usually not worth fixing if that happens.
Feb 15, 2015 | Washing Machines
Maytag electric dryer drum starts and stops turning but keeps going
I would think you are on the right track, possibly a belt, I would also check all the rollers or idlers while you are replacing the belt.
Enjoy and best wishes
Dec 20, 2011 | Maytag Dryers
Drum only turning sometimes and slowely
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Dryers
Hi, My washing machine drum appears to be loose. When the drum is turning slow it seems to go side to side as well as rotating. When the spin initially starts the drum seems to bang on the sides of the...
Sounds like worn drum bearing however check the top spring is not snapped.Remove lid you will see if spring is broken if not and suspect bearing its quite an expensive job,do you know Hotpint have a 5 year warranty on parts only call charge is around £105........Worthwhile considering as the parts would cost around this to buy excluding labour...Good luck
Jun 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
2003 Whirlpool Duet Washer clear water pooling in drum after use.
When the machine is off, there are only two ways water could possibly enter. 1 Check the drain hose install, that it is not installed deep in the standpipe, if the hose is shoved too deep, it can sometimes siphon (rare with front loaders) water back into the machine.
2. Most likely cause, a slow leak from the water valve. Sometimes the water solenoid will not close completely, and you will get a very, very slow leak into the machine.
If not the drain hose, try shutting off the water supply valves when done using the machine, if that takes care of it, you may want to replace the machine's inlet valve.
Apr 19, 2009 | Whirlpool GHW9400SU Front Load Stacked...
Dryer drum wants to start turning but goes will slow
sonds liker the motor is overheating oyo can try to open the dryen and look for excessive lint hindering the motors operation causing overheating
Mar 05, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
26 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
