Question about Frigidaire Refrigerators
Chill drawer stuck in fphs2399kf1 - Frigidaire Refrigerators
I have a Samsung side by side refrigerator Model No: RS21DCSV. The water and ice dispenser are working. However, the water is no longer chilled?
Water is stored in a tube bundle located behind the crisper drawers (bottom, back of the refrigerator) and is chilled to the temp of the refrigerator (perhaps 40 degrees F). This tubing holds approx. 16-32 ounces (less than a liter) and incoming water pushes the chilled water to the dispenser, but also begins to warm the output water temps.
The only way to get colder water is the set the refrigerator to a lower temperature. But be careful that the temps are not so low as to cause other food items to freeze.
Sep 30, 2016 | Samsung Refrigerators
My stove drawer is stuck and it won't close or come out , what to do ?
drawer is stuck Anon, Pick up on drawer as far back as possible with some force,shake it up and down, this should allow you to lift drawer from track/slides. Clean and lubricate all wheels, bearings and track/slides and reinstall drawer.
HELP bottom oven drawer stuck on new GE range
How to Open an Oven Drawer That Is Stuck eHow
How to Unstick Oven Drawer
Stove Drawer Stuck or Jams DIY fix
Apr 02, 2016 | Kitchen Ranges
Why is there water in the chiller drawer on a French Door Refrigerator-Samsung?
We call that condensation from the moist vegetables, etc. in the chiller, natural occurrence.
Aug 21, 2014 | Samsung RF265AA Bottom Freezer French Door...
Frigidaire gallery refrigerator chill drawer sticks
I have same issue with meat drawer and it appears to be a design issue. Works fine empty. This frig is POS.
Dec 26, 2013 | Refrigerators
The climate control drawers keep running and switching from thaw to chill and we cannot get the climate control drawer to turn off
scroll down and look into the other responses,. there may be some similar one to yours where you will find a better answer than I can give you now.
Best regards,
Ck
Dec 03, 2011 | GE Refrigerators
Fridge w/freezer on bottom will not chill
What you have is probably a bad defrost heater element is my first inclination. I would look for frost buildup on the backside of the bottom drawer. That is a sure sign of defrost failure. And most defrost failures turn out to be broken heaters. The defrost heaters mount on the evaporator coils and simply heat the area for a few seconds to melt frost. If left alone that frost will trun into snow and then into air flow blocking slab of ice and fail fresh food cooling. I have a 3 door repair manual you may want to look through just to see what you are up against. To do this repair the ice maker and all the rails drawers bins and food must come out so you can get to the rear where the evap coil and defrost heater is located.
LG FRENCH DOOR REPAIR MANUAL
Feb 14, 2010 | Refrigerators
I have a samsung side by side fridge, and the fridge side is not staying cool, but the chill drawers are keeping the right temp??? The Model# is RS267LABP
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The chill drawers are probably staying cold because there is a vent to the freezer in the wall for the cold air to seep through.
Nov 03, 2009 | Coffee Makers & Espresso Machines
Refrigerator Compressor does not start
Is your freezer below your frig, like a drawer. If so does it still freeze the food. if this fact is true, then listen with the freezer drawer open to hear if the freezer fan is running. If it is running and your freezer is working then it could possibly be that fan that is the problem. This fan circulates the chilled air from the evaporator coil thru the freezer and the refrigerator. This problem is very hard to diagnose as the fan still spins but not fast enough to circulate the chilled air thru the freezer and frig. The minimum cost is around $300.00 if a service company does it. But if you can do it then you can possibly get the fan motor for around $80.00. This repair is very labor intensive as the access to the electrical connection is at the extreme rear of the freezer compartment.
Jul 23, 2009 | Refrigerators
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
Water line
That coil is the line to the water dispenser, and its purpose is to chill the water before dispensing it. The coil of tubing is better than a tank because it chills quickly, takes less space and doesn't hold stagnant water. It shouldn't have any effect on the icemaker.
Jul 26, 2008 | GALAXY Microsystems 25.4 cu. ft....
Refrigerators Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
