Question about Samsung SP50L6HX 50" DLP HDTV
After fixing a ballast lamp and color wheel how long would a tv last?
Hi im serious considering buying a used it for a low price.. They are the only owners who had this tv from 2006 and said they replaced the colorwheel a year ago and lamp about a month ago.. Is tehre any issues I should be aware of with this model after replacing those 2 items? How long would it approximately last or should I just go get a newer one? Plz help! I cant spend 700 for a new one...Thanks! :D
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
I have the same telly for the last six years and i only changed the lamp two weeks ago i think there a very good telly
Posted on Jan 22, 2013
trintek
  • 111 Answers
SOURCE: picture loses color on samsung HLN4365W
if the picture is still visible but lacking color, it is not the lamp. check the color wheel and make sure it is working. replacing the color wheel is a pretty easy task and can be performed by yourself without many problems. as a sidenote, older samsung dlp tvs seem to experience this problem quite often, although they usually sound like someone strangling a cat before the bearings go out..
partstore.com should carry your replacement for 100 USD or so, the part number is BP96-00250A.
before replacing it, make sure your old one isn't just stuck or not spinning at full rpm, if this is the case, you can usually remove it and clean the motor using electronic or contact cleaner that is safe for plastics.
to check everything out, you will need to remove the back panel of your tv, then power it up (keep kids, small animals, hands and such away from the back while powered up), take a look in front of the projection lamp and see if the wheel is turning. if not, a very good writeup is available here, this is the writeup i send my own customers to if they feel like attempting the repair themselves.
replacing the color wheel is actually not very hard at all, if you have ever worked on your own desktop pc (installed a new drive or upgraded it yourself) then you should be able to do this with limited difficulty.
hope this helps,
trin
Posted on Nov 16, 2007
  • 29 Answers
SOURCE: Samsung blinking lamp light - nothng else
Check the ribbon cable coming from the color wheel, if you plug it in backwards it will do this.
Posted on Mar 15, 2008
SOURCE: TV shuts off every few minutes
The problem lies not with the manufacturer but with the technology. While DLP is one of the clearer, crisper rear projection technologies, it is still rear projection, and therefore the most unreliable of the TV technologies, LCDs being the most reliable and the least expensive to fix (relatively speaking). Projection TVs require that the lamp be changed every 2 years (with about 6 hours a day of use) but this can be as often as 6 months to a year for households that use the TV all day long. Lamps cost 150 to 200 dollars in most cases. Beside the lamp, the other parts in the TV can go as you have learned and they are not cheap to repair. I would recommend an LCD tv as they usually manifest problems in the first year (under warranty) if they are going to have any at all. No man-made technology is 100 percent, but I have to say that Samsung is an excellent brand, very high quality, and more features than the competitors. I own one myself (LCD) and have had it for over a year with not a single problem and it gets heavy use as I use it for HD cable, PC monitor, blu-ray, and Xbox 360.
To wrap things up, let me just say that were this problem to be fixed, being a projection TV you might run into these issues in another couple of years again. I would cut my losses and try an LCD (current generation plasmas are also good but they are super expensive to fix if they do break).
Posted on Mar 11, 2009
  • 304 Answers
SOURCE: Lamp Light still on after replacement
First, A common mistake made is when you insert the orange ribbon cable from the Color Wheel into the DMD bd. To correctly insert the Ribbon Cable you need to look at both sides. You will see a shiny silver side and a dull black/orange side. You must insert the shiny silver side AWAY from the Color Wheel or towards the rear of the set. Now for the Ballast. When you power up the tv,Do you hear a short Buzzing sound? If you do that means that the Ballast is trying to fire up the Lamp and is working. Next, do you hear the Color Wheel spin up? If you do not then you have installed the Color Wheel incorrectly and you need to repeat the installation while making sure that you hold the rubber gasket in perfect place or else it won,t work. Chances are the gasket is in the wrong position and is binding the Glass Wheel. The Ballast is on the right side of the engine and on top of the Lamp Housing. You will see two RED High Voltage wires coming out of one end. Don't worry, there is no stored voltage in the ballast so you won't get a shock providing you have unplugged the tv from the outlet. That is the first step before you change any parts any way. Listen for the correct start sequence. With the rear backing off and the Safety Interlock Switch is being held in the up position, turn on the set. First sound you hear is a clicking which is the power on relay engageing. Then you will hear the fans turn on and then the Color Wheel spin up. Once the Color Wheel spins up and comes to full RPM then the Exciter on the Ballast will Buzz for less than half a second and then the Lamp should light up. Now if you have installed the correct Lamp and correctly installed the Color Wheel and you either are holding up the Interlock Switch or have reinstalled the rear cover and tightened all of the screws you should have a working tv.
Posted on Jul 16, 2009
  • 556 Answers
SOURCE: Samsung HLR5067W replaced color wheel, LAMP light blinks
according to samsung this is indeed the problem.
Posted on Oct 20, 2009
Testimonial: "Excellent expert advice. Confirmed what I believed to be the problem and it was. Very knowledgable"
52WM48P Rear projection TV Lamp fitting
Original brand Toshiba lamp ,unit price is USD100
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 13, 2014 | Lapbix Tv Lamp For Toshiba 52wm48p 120...
Hello, I have a Samsung HLP4663W 46 in. Rear Projection HDTV Television, and they lamp kept going out so I bought the proper lamp to replace it and it still would not show a picture. Should I pay to have...
Recheck the tv projection lamp installation?Recheck the lamp door latch,see if it is proper closed and tightly closed of the lamp door?Hear any clicking noises,when the tv projection lamp tries to ignite up.If hearing constance clicking?Mean the tv board that call the Ballast board it is also dead,this Ballast board only job are to ignite the tv projection lamp only.Ballast board must have be replaced.If the tv have a colors wheel is it dead or damage and broken require changing,u will hear major humming,motor or grinding sound noises and alot of times the tv pictures flashes multiples colors on the tv screen or the tv pictures will have a black&white flashes of a background of white light within the tv pictures background.Selling defective tvs almost impossible to sell it for a decent or a good priced or it at all.If this tv u have less than 5 years old,tv it is still have alot of it life ahead of it,tv tube picture screen panel,will last u atleast another 10 years and have to be 8 hours tv whatching every day to dies this faster or could be last to 15 years,if tv less hours of watching every day.Should get priced quotes from many tvs repair shops and get it fixed max prices about $400-$500 dollars.New tv same model and sized or difference models too will cost u like $1,200-$1,500 dollars.
Aug 06, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
I HAVE A SAMSUNG SP46L6HV REAR PROJECTION HD DLP TV AND IT HAD MAKING A NOISE BUT NOT THAT LOUD AND THEN ONE DAY IT WAS ON AS NOMAL AND JUST WENT OFF , MY HUBBY TOOK THE BACK OFF AND SAID THE LAMP WAS...
Before it went out, was the sound like a fan or high pitched in nature?
Lamp can be removed (is is customer replaceable) to see if shattered inside.
I suspect a bad color wheel, which is not hard to replace. See attached photo of color wheel.
Examine lamp and if not shattered do not buy one to try.
I am here to help you for free.
Comment here and I will assist you.
SD TECH
Sep 16, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
I have a Samsung HL85086W Made a screeching sound/no pic
All projection TVs for Samsungare DLP TVs, with that in mind these TVs have a lamp inside that produces whitelight. The color wheel is the one in charge of giving color to that light. Regularlythe color wheel last between 2 to 5 years depending on the daily tv use. Most ofthe time when the central barring of the wheel is loose, unstable, or out ofplace it will cause the edge of the wheel to make contact with the housing,producing that whining,whirling, screeching or hissing sound. These sounds can either produce just a annoyingsound when watching tv or can cause the tv to shut off. When this happens you’llhave to replace it, if you want to know where to buy, you can look in ebay,there are many parts you can get at very good bargains, the only thing is thatyou buy at a high risk of the part not working ( I had a bad experience). The otheroption is to buy at an electronics store online dedicated at selling tv parts,some can help you trouble shoot your problem and others may have tech support overthe phone (personal recommendation: Discount-Merchant.com ). And last rememberto search your part by part number, NOT by model number, two TVs with samemodel numbers but assembled on different dates ( different generation TVs )will have none compatible tv parts inside, so be very carful.
Nov 03, 2009 | Televison & Video
I have sound only, is there any hope and what could I expect to pay to fix it, please?
Hi,Do you hear clicking or like wanting turn on? If you do it could be an issue with the ballast the ballast is the board that powers the lamp,you can replace it your self here's how: http://guides.fixyourdlp.com/samsung/bp47-00033a.php and estimated price is around $40-$50 If you hear buzzing,whirling,spinning or high pitch sounds?It will be the color wheel, The Samsung color wheels spin anywhere from 6,000 to 15,000 revolutions per minute (RPM’s)--It is one of the few consumable parts in your Samsung TV. The average life expectancy from our data logging shows the Samsung color wheels are fairly reliable with a MEAN average of 5-8 years.Basically the light of the lamp goes through and creates the colors on the tv here's how to replace it: http://guides.fixyourdlp.com/samsung/bp96-01579a.php Stimated time is around $60-$80.00 If you dont hear any of that ,tv is between 2-4 yrs and sound but no pic it will be time to replace the lamp.Samsung uses Philips lamps make sure you get those Original.
Sep 30, 2009 | Televison & Video
Samsung HLN507WX lamp not coming on.
The Ballast is the next logical step but more often the Color Wheel has gone bad. Try this first. Make sure that the Lamp Door has been reinstalled and the screw has been tightened.
Next while you are at the back of the set listen for a short buzzing sound while you turn ON the set with the remote or have another person turn it on. If you hear a short buzzing sound then your Ballast is ok. The reason the lamp does not turn on is because if the Color Wheel does not spin up then the Digital bd will not let the set turn on. Color Wheel part# is BP96-00250A. Ballast part# is BP47-00008A
Jul 09, 2009 | Televison & Video
Lamp light turns red
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
Sep 03, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD 62327
My best gess is the Ballast.
Aug 06, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Wd 62327
Jul 31, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Can you help
Hello Brandon B
Great Job at trying to fix your own TV.....Bravo!! Ok, you may very well have a bad Color wheel. You have already change your Ballast and Lamp. The lamp would have been my first step. If you have a defective color this will surely cause the set not to come on. The DM board detects what going on with the color wheel and will not start the lamp. There are 2 types of color wheel listed for this TV.
List price $100
BP96-00674A COLOR WHEEL (FOR TYPE L3 VERSION PW03 UNITS)
List price $100
BP96-01103A COLOR WHEEL FOR TYPE L6 VERSION PU01 UNITS
Best regards
circuitcity
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung SP50L6HX 50" DLP HDTV Logo
57 people viewed this question
Henry  Thomas
Henry Thomas
