Question about Sanyo SR-3720M Counter-High Refrigerator Black and Platinum Stainless
Sanyo sr3720m just was working yesterday but defrosted and won't get cold
Hotpoint refrigerator won't stop running
The temperature sensor could be at fault
Mar 26, 2013 | Refrigerators
Refrigerator-freezer won't freeze
I think the fridge is low on gas, or the defroster is on all the time
Mar 24, 2013 | Whirlpool Refrigerators
Freezer works but refigerator won't get cold
IF YOU HAVE ALOT OF FROST ON THE BACK PANEL OF THE FREEZER IT IS A DEFROST T-STAT THAT CAN BE BAD IF THERE IS NO FROST FELL UP IN THE LEFT UPPER CORN OF THE FRIG SIDE SEE IF YOU CAN FILL THE AIR COMING OUT OF IT
Nov 01, 2012 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
Kenmore Elite 106.53609202 won't get cold (refrigerator or freezer)
When you say it's running, do you mean the fan in the freezer or the compressor is running?
Oct 19, 2012 | Refrigerators
Frigidaire Refrigerator FFTR1814LW bottom fridge not cooling properly 50 degrees. The top freezer is rock soild Thx
That is the classic symptoms of a defrost system failure. Suggest you look behind the rear panel on the inside of your freezer and see if it is iced up. If it is then it is a defrost problem which could be the defrost heater, defrost thermostat or defrost timer. If it isn't iced up, then check to make sure the fan is operating. If it isn't then it won't push cold air out of the freezer into the refrigerator section.
Sep 14, 2011 | Refrigerators
I have a Sanyo SR-3770S Refrigerator and I defrosted it last night after turning it off and unplugging it. After it had defrosted I plugged it back in and turned it back on at a medium setting and let it...
Greetings
Do you hear the compressor running and no refrigeration? If yes, feel around the back fror the condenser coils.Near the compressor ,the condenser tubing should be very hot to the touch.If not , you have no or low refridgerant. You may have punctured an evap coil during defrost.
After 8 hours evaporator should be ice cold.
If compressor is not running it's thermostat
Was this helpful?
Aug 18, 2011 | Sanyo SR-3770S Compact Refrigerator
Mistral mss15 aircon will not operate on heat setting , not sure if it is being set properly because cannot understand remote control symbols
My Mistral was working yesterday (on heat) now it won't. Just sits there as if warming up but actually blows out freezing air - on "sun" mode.
Jul 12, 2009 | Sanyo 24KS32A Cool Mini Split Air...
Wont cool
COULD HAVE A DEFROST PROBLEM CHECK DEFROST TIMER HEATER LIMITER AND FAN . BUT YOU COULD HAVE THE CONTROL TO ALLOW MORE COLD AIR INTO THE FOOD CAPARTMENT CLOSED SET BOTH CONTROLS HALF WAY FIRST AND THEN SEE IF THAT HELPS
Aug 05, 2007 | Admiral 26 cu. ft. Side-By-Side...
Sanyo SR-3720M Counter-High Refrigerator Black and Platinum Stainless Logo
26 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
