Question about Uniden Bearcat BC142XL Radio Scanner
How to reset a uniden bearcat bc142xl - Uniden Bearcat BC142XL Radio Scanner
5 Suggested Answers
Mechanic688
  • 204 Answers
SOURCE: programing for uniden bearcat scanner bc 144xl
danval, I looked up a pic of your scanner and it is pretty straightforward. If it is the 16 channel I was looking at, here is the step by step programming.
1- Push manual button to go to the channel you want to start programming.
2- Enter the freq number in.
3- Push the E button to enter it in the memory.
4- To review what you programmed, push the Review button.
5- Use manual button to step to next channel and start over from #2
That should get you started with the scanning hobby.
The scanner has a Priority button that when activated will stop scanning and go immediatly to the priority channel if someone keys their mic.
If you need freq's (or more of) for your area, go here and click on your state and county and it'll give you a complete listing.
http://www.radioreference.com/apps/db/
Hope this helps you out, let us know,, Mechanic
Posted on Feb 12, 2008
BillB-SA
  • 2761 Answers
SOURCE: how to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
3. Press the ENTER or E key.
4. Start over with step one to continue programming channels.
Posted on Aug 16, 2009
BillB-SA
  • 2761 Answers
SOURCE: Need a free printable user manual for Bearcat
Its so easy to use you really don't need a manual for the Uniden BC142XL scanner.
Turn it on. Push the "MANUAL" button to stop it from scanning.
Push number 1, then push "MANUAL" again. This should leave you on channel one.
Using the keypad enter the frequency you want to monitor, then push "E." Press "REVIEW" at anytime to see what frequency is programmed there. If the review button flashes 000.0000 on the LED readout display, you might be entering an invalid frequency. Refer to the list of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push "E." Push "MANUAL" to step to channel three. Repeat this process until all the (10) channels are full, or you've run out of frequencies to enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two seconds after the conversation has stopped.
Frequency Range Bands:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band
If this helps, please take a moment to give us a rating -- and a rating of "very helpful" would be greatly appreciated.
Posted on Nov 23, 2009
BillB-SA
  • 2761 Answers
SOURCE: How do you program a Uniden Bearcat bc244CLT?
To program a known frequency into your scanner:
- With power ON, press MANUAL to stop scanning.
- Enter the number of the channel that you wish to program (01 - 30).
- Press MANUAL.
- Enter the frequency, including decimal point (for example, 156.065).
- Press E to enter/store the frequency into memory.
- Press MANUAL to advance to the next channel for programming.
For more information, you can download/print the manual for your scanner here:
http://www.uniden.com/pdf/BC244CLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Posted on Apr 25, 2010
I NEED SCANNER CODES?
It depends on your location. Try this link http://www.radioreference.com/apps/db
You will also need to know if your state and city switched to digital.
If not then it should work fine, but if they did you will need a new scanner because you have an analog scanner. There is a big push to switch over to digital radios in police, firefighter, military because it's more secure to use.
Oct 16, 2015 | Uniden Bearcat Model Bc142xl 10 Channel...
How do i reset uniden bearcat bc355c. To factory settings?
SOME, of the Bearcat radios you could hold down the "2" and "9" button while turning it on - worked on the old units; I don't know about the newer ones.
Apr 12, 2015 | Uniden Radio Communications
Can I disconnect the squelch on a uniden scanner model# bc142xL? & will scanner still work?
Why would you try to disconnect the squelch? If you turn it one way, it does not work at all. If you don't get any sound it won't be caused by the squelch circuit. You really have to look somewhere else if you don't get any sound.
Nov 20, 2014 | Uniden Radio Communications
Uniden bearcat scanner bc142xl manual
Hello, the good news, though, is that all Uniden/Bearcat scanners in the 14X series are nearly identical in features and operation, so you can follow the link below to download/print the manual for the BC148XLT:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC148XLT%20%28Manual%29.pdf
You need adobe reader to read the content.
Good luck
Dec 31, 2012 | Office Equipment & Supplies
I would like to have all the frequencies for surry county, n.c. police,sherrif, emergencies please. I have a uniden bc142xl bearcat thanks.
some one is watching thru you back....
DONT DO THIS.....or for that matter anything that's againt the law of the land....
be a good boy...
Apr 28, 2011 | Office Equipment & Supplies
How to program a bc 560xlt bearcat scanner. Thanks, Les. lorlick@yahoo.com
hello there: here is a link for you that will help out ok
best regards mike
How to Program a Uniden Bearcat Scanner BC 140 | eHow.com How to Program a Uniden Bearcat Scanner BC 140. Programming a Uniden Bearcat ... How to Program a Bearcat 5 Scanner. How to Program a BC 560XLT Scanner ...
www.ehow.com/how_5009391_program-uniden-bearcat-scanner-bc.html - 57k -
Aug 24, 2009 | Office Equipment & Supplies
I LOST MY MANUAL TO MY UNIDEN BEARCAT BC142XL CAN I GET A FREE REPLACEMENT?
A number of scanner manuals can be found online however I don't know the difficulty of finding it for this unit. More than likely if you need printed material sent to you it will cost you.
To program the BC142xl 10-channel scanner:
Press the Manual button. Continue to keep pressing the Manual button until you are at one of the ten channels you wish to program the frequency into
Press the E button
Enter the frequency you want to store in this channel
Press the E button - Your frequency is now stores in this channel.
To later see what frequencies you have stores use the Review button.
Aug 05, 2009 | Uniden Office Equipment & Supplies
Uniden Bearcat BC142XL Radio Scanner Logo
226 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
