Question about HP Compaq Presario CQ50-210US Notebook
My screen is black
When I turn on the laptop the screen totally black
  • HP Master
  • 27,725 Answers
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Posted on Jan 20, 2013
Screen total black out
turn your lap top off, take out the battery, hold your power button for 30-60 secs, turn it back on and PRESTO!
Feb 13, 2012 | Fujitsu Siemens AMILO Pro V2010 Notebook
Turn on screen is black windows will not come up
If screen is totally off (black because of it's off) - screen is dead. If it's black, but you see it's working - could be hard drive or memory fail.
Mar 14, 2011 | Toshiba Satellite M35X-S349 Notebook
Laptop will not display screen although is turned on.....
I assume you are saying the screen is totally black, not blue. If it is totally black there can be a large number of causes. It is hard to give one simple answer. It could relate to the brighteness of the screen, the display, the logic board, the graphics card or even a problem relating to updating Apple firmware, You could try some simple things first.1) If the lighting on your computer is accidentally turned all the way down, your screen will be black! To turn the brighteness up, push F2 on the top of your keyboard and click until the lighting improves and you see the screen. If your display stays black it could be an indication that you just need a new Display. They do wear out. 2) Another thing to try is to start the computer in Safe mode. http://support.apple.com/kb/HT1564?viewlocale=en_US As you push the power button hold the shift key down. This can sometimes help resolve issues relating to startups. Also, if your screen stops being black it is an indication there is nothing wrong with your display. 3) You could try resetting the PRAM http://support.apple.com/kb/ht1379, This can also help with a startup issue. 4) Some specific models of Macbook Pro computors have issues caused by the NVIDIA graphics card, which Apple knows about and apparently will repair, possibly free of charge. My suggestion if none of this helps is to take it to a Genius bar at an Apple store for them to troubleshoot. That, in itself, costs nothing. Other suggestion search with google for further answers from other Mac owners!
Jul 14, 2010 | Apple MacBook Mac Notebook
M50 SCREEN TOTAL BLACKOUT
i think there may be inverter problem.
Mar 07, 2009 | Toshiba Satellite M50 Notebook
Laptop was working fine, suddenly went totally black.
the display of ur laptop has got damaged....if u still have doubt that it might be some software problem try formatting ur system.. Or else u should go for a change of display screen
Feb 02, 2009 | Toshiba Satelite A135-S4467 Notebook
Screen is black. Can't see anything.
Shut it off and try hooking an external monitor up to it. Turn it on and see if there is any display on the monitor
Dec 26, 2008 | Toshiba Satellite A215-S7422 Notebook
Open Questions:
See all HP Compaq Presario CQ50-210US Notebook Questions
HP Compaq Presario CQ50-210US Notebook Logo
129 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
