Question about Bissell 1622 Powerlifter Powerbrush Upright Deep Cleaner Carpet & A
Grinding sound Grinding noise from the unit when started, Lent to friend who owned many pets. Not sure how to diagnose and/or repair problem.
    Top Expert:
  • Bissell Master
  • 34,170 Answers
You need to make a thorough inspection for debris and pet hair cloggin your vac. Could have ingested a load of kitty litter or....
Posted on Jan 20, 2013
Sebo vac grinding noise and burnt smell
Take it to your local vac shop for assessment. Sounds like a bad motor. If they are not a Sebo dealer, make sure they know that a X1 motor is not the same as an X4 motor. It should cost around $200 for the total repair . A new X4 is $799 so the repair is usually a good idea.
Jun 16, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Scooba 385 - Making Grinding Noises - Video I
there are no parts available for these ( toys ) so called vacuum cleaners. Sorry you wasted your money.
Oct 10, 2013 | iRobot Scooba 350 Robotic Vacuum
I have a dyson dc07 with a malfuncitoning clutch diagnosed here on fixya. I've replaced the clutch and the grinding noise when the clutch is engaged for carpet and non rotating brush problem presists. This...
Greetings from GoVacuum,
If you have replaced the clutch already, then this can really only be one other problem, and that is the roller brush. If the roller brush's bearing have locked up, and the brush is no longer spinning, this is going to cause the clutch to make that horrible grinding noise, and a lot of people incorrectly think automatically that the clutch needs to be replaced.
Here's a very easy way that you can test the roller brush on your Dyson to see if it may have gone bad. In 10 years of fixing and selling vacuum cleaners, I have never seen such a cheap roller brush that's in the Dyson DC07 models with clutches, unfortunately this is notorious problem we see on this particular model.
Ok, so to test out the brush, make sure the vacuum is unplugged, and turn it upside down. Remove the 3 plastic screws on the bottom plate, and remove the bottom plate to expose the brush completely.
You may then simply pull upwards on the roller brush, and take the brush out of the belt that is wrapped around it. After the brush has been completely removed from the vacuum cleaner, hold the brush with only your pointer fingers in each hand, and only put your pointer fingers on the outside of the bearing caps on each side of the roller brush.
While holding only the bearing caps with your fingers, try to spin the brush with your thumbs. The brush should spin freely in your fingers, and you should get a good 5 or 6 rotations with each spin.
If the brush doesn't spin, then your roller brush has gone bad. Espcecially with home that have long haired pets, or females, the hair gets between the bearing cap and the bearing inside and causes the plastic caps that are covering the bearings to heat up, ultimately causing the bearing caps to melt, and finally the bearings sieze, and the brush will no longer spin freely which is why the clutch makes that awful noise.
Good news is that the roller brush is not as expensive or as difficult to replace as the clutch was. You may purchase the DC07 roller brush here;
Genuine Dyson DC-07 Roller Brush for Models That Use a Clutch Part # 904174-01
If your roller brush does spin, then I'm baffled as to what could be causing the clutch to make noise, but I'd like to try and help you figure this out.
Please send me an email to chris.jones@govacuum.com, or just request a clarification request here on Fixya, and I'd be more then happy to try and diagnosis this Dyson further for you.
If this Solution was helpful to you, please rate the repair as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of this solution.
Thank you so much, I hope that this helps you.
Chris Jones
GoVacuum.com
Nov 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Loud 'drilling' noise from motor area when turned on.
Sounds like bad bushings/bearings in the motor -- need to replace them.
May 27, 2009 | Electrolux Vacuums
My Bissell Cleanview Bagless vacuum makes loud grinding noise.
the ends of the roller have something wrapped around them.see if you can pull the ends off so you clean the caps and bearings
Apr 09, 2009 | Kenmore Progressive Bagless Upright with...
Floormate noise
The motor sounds bad. Use the Hoover web site to locate a shop near you for warranty repair. hoover.com
Oct 09, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Loud noise
I think you damaged the belt. I ran over a sock once and it made a grinding noise but still worked for several months after the incident. Finally, the belt broke off. I had it replaced and now it doesn't make that sound.
Sep 26, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Roomba
Mine did the same thing. I'm going to send it back for a warranty repair.
Dec 23, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Bissell 1622 Powerlifter Powerbrush Upright Deep Cleaner Carpet & A Logo
74 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
