Question about Toshiba Bdx5300 Bdx5300 3d Bluray Player With Builtin Wifi
Toshiba BDX5300 player won't connect to the internet
My android tablet won't turn on all the way
You may want to post to Tablets and eReader category for a Tablet Expert.
Mar 18, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
Connection problem on vigo tablet
Not a solution, but... we could not connect to Vodafone, as the Vigo was not compatable with our Vodafone supplied Huawai modem!!!!!
Dec 27, 2012 | Tablets & eReaders
How to I install the internet to my cobyMID7016? I had it working at one point, but now it will not load to my coby?
http://www.cobyusa.com/?p=faq#faqcat_8
on this page you will find almost all answers for your questions related with the tablet ..(under internet tablets sector )
The issue in your case it is the internet connection itself ..either the wireless network you used it is not working anymore or not on (if you use a router ) ..or simply you reset the tablet and you need to make the connection again ..Just open the internet connections ..(wireless card 0 ..and select to scan for networks ...and when you find your network ..select ti ..and than click connect ..This should connect it right the way ..
Also check if your internet network may need your mac address for to let you connect ..(this happens on the networks having the access restricted by the Mac address..)
to get it follow these :
  1. Click on Settings.
  2. Click on Wireless & Networks.
  3. Click on Wi-Fi Settings.
  4. Click the MENU button, located on the side of the unit.
  5. Click on "Advanced".
  6. Your MAC address will appear in the Advance Menu ..
same way to get to the connection for to activate just open wifi connections ..
Dec 26, 2011 | Tablets & eReaders
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
I'm having trouble getting my Toshiba Thrive tablet to connect to the internet. I called Toshiba tech support and I was told to contact 2wire and ask for the settings to be changed so it would be...
it sounds right for wireless access point comes from your router... if your tablet's wireless setting is different form what 2wire has then it wont really work...
if you can specifically tell me the changes that toshiba wants on the 2wire wireless modem/router kindly reply on this and i would be more than willing to help you out on giving instructions...
Try this links:
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"---- ---you may also leave testimonial----- ---if I help you please help me---
Thank you for choosing fixya
Roger
Sep 04, 2011 | Toshiba Thrive Android Tablet
My toshiba r15-s822 says it has no drive and gives a (Ide#0 ERROR) i had a virus and i formated the drive a while back and i got a new windows xp install but i cant seem to load it cause it wont show the...
Xp can only "See" a hard drive up to about 128GB, if its bigger than that, XP won't install.
Make sure your drive is properly connected, and jumper in the right place (1 drive, set to master)
If it used to work before your problem, should be ok.
Then boot from your windows disk. If your bios is set to boot from the hard drive, if there's no operating system on your hard drive it can't boot.
If its set to boot from the hard drive first, it may, after a few seconds revert to booting from the disk drive. If not, while booting watch the screen, at the bottom it you should see "Press F2 for setup or F10 for boot options" or something similar. To temporarily change the settings, choose the boot options menu and select "Boot from CD". Restart and you should be on your way.
If that doesn't work, you may need a new hard drive.
Aug 23, 2011 | Toshiba Satellite R15-S822 Tablet PC
My Toshiba r15-s822 isn't connecting to a wireless network and the router I already installed the router to my pc even connected an internet cable to it but Internet Explorer wont open it keeps...
Try connecting to the Internet through the ethernet port (via a cable). If Internet Explorer loads the target page then you have a configuration problem with WI-Fi access : The wireless security settings are not allowing the computer to access the Internet.
If Internet Explorer does not connect with the cable then the problem resides with Internet Explorer. Try to reset the defaults. To confirm that download FireFox and use it. Besides you need two browsers just in case one acts up.
Jul 02, 2011 | Toshiba Satellite R15-S822 Tablet PC
Toshiba Portege M780 - THe F10 light is on & the keyboard won't work. I have tried hitting Fn F10 to toggle but it does nothing.
Press the Fn-F10 combination to deactivate the overlay keyboard (numerical pad). The Fn key is the one to the right of the Left CTRL key.
Jun 27, 2011 | Toshiba Portege M780S7220 Tablet PC Intel...
My iPad asks me to type IP address http://192.168.1.3:8080. Why doesn't anything happen when I do?
That won't do you any good unless you're connected to a private network with an IP addressing scheme setup that starts with 192.168.1. 192.168.1.3 would be on a private network and is not a webserver you'd find on the Internet. Do you know whether or not you have a proxy server setup at the location you're trying to use WiFi? 192.168.1.3:8080 seems like it would be the address of a proxy.
Jun 10, 2011 | Tablets & eReaders
Toshiba Bdx5300 Bdx5300 3d Bluray Player With Builtin Wifi Logo
44 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
