Where can I get a replacement swivel for AKG K 490NC headphones? The plastic broke right at the end that attaches to one of the earpieces.
The plastic piece broke right at the connection to the earpiece. I'm pretty sure I can repair it if I can find the replacement part. The headphones are less than a year old.
    New Friend:
Have you found a solution for it? I have a similar problem
Posted on Jul 22, 2013
  • Steve
    Steve Jul 30, 2015
    I have the same problem . . . they should have made that whole piece metal, not unforgiving hard platic. they're rendered useless...
Xome
  • 79 Answers
SOURCE: I have a AKG K 480 NC headphones. There is a loose
The wires must have been damaged so remove the casing and place extra lead on connected points and the wires well.
Think this is helpful !
Posted on Aug 12, 2010
SOURCE: Shure E4C headphone failure
I just found out how to open the E4's.
What you do is, unscrew the metal cap that holds the angled earbud tube in place. Note that the tube itself can't be turned.
Then remove the metal ring behind it as well as the small rubber ring.
There is a 'hinge' at the cord end of the earbud, so what you should do is take a very sharp knife (I used a scalpel) and pry the top off the earbud from the end that had the ring mounted by inserting the knife between the top piece and the metal element. Note that it's attached with a little glue, so it will take some coaxing to get off.
Posted on Apr 02, 2009
SOURCE: My headphones are feedbacking all of a sudden
thanks, I have the same problem..i just changed the battery yesterday and saw corrosion on it! I will dry it out. that feedback was amazingly loud..thanks to all!
Posted on Jul 28, 2009
  • 15 Answers
SOURCE: Snapped Earpiece Off Skullcandy Hesh
Skullcandy does not sell replacement parts. but you can warranty those. they will either replace them or send you a 50% off code to use on there website.
Posted on Aug 10, 2009
  • 1138 Answers
SOURCE: im looking for replacement plastic swivel part. left side
Try asking here:https://servicesales.sel.sony.com/ecom/accessories/web/welcome.jsp
Posted on Oct 24, 2009
How can i open my AKG k141 studio headphone to repair it ?
I had a problem with my AKG K141 Studio headset. The right side stopped working. Hard to believe but one of the leads to the ear speaker was disconneted from the solder lug. To disassemble, pry the gold AKG emblem using a jeweler's screw driver. You can pry it without damage by locating a small notch on the black plastic rim at the 6 o'clock position. Then unscrew ththe tiny phillips screw and remove black disc. You will see two leads (red and white) feeding through a hole. Disassemble removing a larger screw. This will give you accesss to the solder lugs.
Nov 30, 2010 | AKG K 240 Studio Professional Headphones
I have AKG 141 studio headphones and the right hand side earpiece wont make any sound, i believe it is faulty wiring because if you move it around you can make it work.
take away the glued brandmark with a sharp tool (knife , little screwdriver) and you will find a screw. loosen it and open it. there you will see some cables witch probably have one loose. fix it by solding it.
Sep 12, 2010 | AKG K 240 Studio Professional Headphones
Left ear bud lost all sound- no cord damage-only 5 months old...is it worth getting fixed by professional or is there something I can do to fix it ? H
The cords are sealed into the earphone. You can take a multimeter and test the continutity of the either earpieces, once you are convinced that the left side is faulty, first of all use a small thin needle as the probe, use your multimeter in the continuity range, holding one end of the meter probe to the jack , inset the pin like an ijection into the wires to obtain the connection, it there is no connection out of the headphone jack, I think you can replace with a new one to be soldered. If not proceed to the earpiece to confirm, then open the sealed unit and be lucky if the earpiece is not damaged but only the wires. Good Day
Jul 07, 2010 | AKG K 321 cloud white Headphones
Can I take apart the logitech A-00006 headphones easily.
The padding comes of easily, hook your finger under from the inside and push out gently. Once removed reviles 2 philips screws. Once they are removed you have to pry the 2 plastic disks that form the swiveling ear piece apart. Then you have access to the speaker, which is glued down with a still very sticky substance but will come up quite easilly, then remove the screw from directly under the center of the speaker, then you can pop off the swiveling earpiece that is on a kind of ball and socket joint, this took quite a bit of force. This is as far as i'm going as I now have access to the damaged part of the wire! And also the 4 screws mentioned in the original question. Hope this helps.
Dec 08, 2009 | Logitech Bluetooth Wireless Headphones
The 2 wires red and white came apart from the right ear phone
This might help:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/
Oct 12, 2009 | AKG K 240 Studio Professional Headphones
Wiring code for the jack?
You're right on the code, with the exception of the right and left. I'm an AKG dealer and spoke to their service department. Here goes:
White=Ground
Yellow=Left
Red=Right
To confirm this, I used a multimeter in continuity mode and tested them. This code is 100% correct.
Nov 08, 2007 | AKG K 240 Studio Professional Headphones
541 people viewed this question
 Grubhead
Grubhead
