Question about SanDisk Sansa e250 MP3 Player
Shuts off every time i try to download music
The san disk sansa rvery time i plug it up to the usb/charher to download music it would be fine than once i go to the programs on the computer it will just shut off for no reason can you help
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
Sansa latest updates
Download the converter after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Oct 04, 2009 | SanDisk Sansa Fuze MP3 Player
I am having problems downloading music on my Garmin Nuvi 760
the mp3 file will not say on your pc when you have unpluged it. if you want to add or delete files from the mp3 it will need to be pluged in at all times
Jun 01, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
what you can do is try and move the music onto the drive and not into a folder. Also if you are using a Garmin GPS then you cant download music because the type of device doesn't allow .mp3 files of music and it has its own music interface
Jan 10, 2018 | Garmin (010-00583-00) for nuvi 750/760/770
How do i download music to my San Disk Sansa clip MP3 player?
You shold be able to sync the Sansa to your media player on your computer by just connecting the supplie dthe cable to the USB port and open windows media player. If you are just trying to dump songs on to it then all you need do is connect the sansa and go to my computer find the new device, open the device and copy your music from the folder you hvae it in and drop it directly to it. The Sansa is not like the I Pods that use software to sync music. Basically it is like a flash drive (thumb Drive) or a hard drive.
Aug 29, 2008 | SanDisk Sansa Clip MP3 Player
Sansa E260 Transfer Music with Yahoo Music Ulimited
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Thanks
Jun 13, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
San Disk E280 8gb MP3 Player
Do not use Rhapsody. See if you can get the downloaded songs from Rhapsody to Widows Media Player or another downloading program. If you need any help update the problem.
Good Luck
Feb 27, 2008 | SanDisk Sansa e250 MP3 Player
Sansa mp3 m230
If the device is visible from the computer, format the disk as described in the product page's video tutorials.
Aug 05, 2007 | SanDisk Sansa m230 MP3 Player
MWP does not recognize my san disk m230
i suggest an update software ,this will solve the problem.
May 31, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
