Question about Apple iPod Audio Players & Recorders
REBOOT IPOD HOW TO REBOOT
  • Apple Master
  • 27,725 Answers
Which model ipod they all have different ways to reset usually through iTunes
The iPod A1136 is the fifth generation iPod from Apple that uses a click wheel to scroll through your device's media library, and may occasionally lock up when you attempt to play a song or display a photo. This error error occurs when the hard disk is unable to access the information and stalls while opening a file. A reset of the device usually corrects the problem, as it clears the device's memory and any errors. Check your iPod's buttons to determine if the cause is due to a hardware error before resetting the device, as the problem may be due to the iPod's hold switch. Slide the hold switch at the top of the iPod to the right, and slide it back to the left to ensure the switch is in the off position. Hold down the center button in the click wheel, and at the same time hold down "Menu" on the click wheel. Continue to hold the iPod's buttons until the device's screen shuts off, turns back on and shows the Apple logo. Plug the iPod's connector cable into the dock connector on the bottom of the iPod. Plug the other end of the cable into your computer's USB or FireWire port to charge the iPod. Wait at least two hours for the iPod to charge. Launch iTunes on the computer, and click "Controls" of the iTunes menu. Click "Eject iPod" in the sub-menu to disconnect the device. The iPod takes four hours to completely charge its battery.
Hope this helps.
Posted on Jan 20, 2013
My iPod isn't working.
Okay. It seems like your iPod is stuck. Hold the home and power (screen lock) button together for around 10 seconds. Your iPod should reboot. :) If even after reboot, problem recurs repeatedly, it's a software problem. Restore it using iTunes or take it to you nearest Apple Service Center.
Jan 26, 2013 | Audio Players & Recorders
Ipod is not connecting through p.c
1.Disconnect your iPod from your PC by removing the ipod data cable from your iPod and your computer.2.Reboot your PC.
3.While your PC is rebooting, reboot your iPod. Do this by placing the iPod on a flat surface. Using your middle and index finger, press down on the menu button and the center button simultaneously. If done correctly, the screen on your iPod should go black and then you'll see the Apple logo as it starts to reboot.
Apr 24, 2012 | Audio Players & Recorders
Want to reboot my ipod 16 gb touch
To reboot you ipod all you need to do is just turn it off and turn it back on.
If you mean restore your ipod follow these steps
Complete a Regular Restore
  1. Back up your iPod Touch's data to your computer before the restore to prevent losing data. You'll need to reinstall it after the restore process.
  2. Connect to the Internet and install the latest version of iTunes from the Apple website.
  3. Make sure your iPod Touch is connected to your computer.
  4. Pick "iPod Touch" in the Source pane of the iTunes program.
  5. Click on the Summary tab.
  6. Choose "Check for Update."
  7. Select "Restore" and follow the instructions to finish restoring your iPod Touch.
Complete an Advanced Restore
  1. If following the steps in the previous section did not work, follow these steps to perform an advanced restore. Turn off the power on the iPod Touch.
  2. Plug the iPod Touch into your computer.
  3. Power on the iPod Touch.
  4. Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  5. Release the "Sleep/Wake" button but continue holding down the "Home" button. The iPod Touch should reboot, and iTunes will notice the iPod Touch in recovery mode.
  6. Return to the above section and follow those steps to restore your iPod Touch.
Sep 24, 2009 | Apple iPod touch
No response from ipod
Reboot your Ipod by pressing the center button while holding down on the menu button. An apple logo should appear. This will reboot your ipod.
Feb 17, 2009 | Apple iPod nano
Ipod 30 gb
Reboot, plug your player in, open Device Manager, and remove the device that shows up representing your player (completely uninstall it). Reboot again, and plug in your player. It should be recognized now.
Jan 13, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod video click wheel
Try to restart the Ipod.
Hold the select button and the menu at the same time until you see the screen go off.
If still does not work then try to enter disk mode and see if it works.
Disk Mode:
Reboot the ipod via Select and menu, right away hold the select and play button and hold until disk mode comes on. Does the wheel work?
If still does not work then reboot the ipod again and let it reboot normal to go back in apple firmware. If all buttons are working and none of the above works, I would assume it is not software related.
Nov 12, 2007 | Apple iPod MA446LL/A MP3 Player
Click wheel
Disk Mode:
Scroll wheel is nonfunctional
Disk Mode:
Nov 11, 2007 | Apple iPod MA446LL/A MP3 Player
47 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
