Question about Sewing Machines
Bernina 1130 power supply
Our Bernina 1130 stopped working from one second to another. Fuses are all ok, voltages at the transformer's secondary windings seem to be present. The machine is dead, even the little work lights are not working, so I assume a problem on the power supply board. I am an electronic engineer, but without schematics I can't even check voltages. Does anybody know where to get schematics or at least know voltage test points on the power supply pcb?
4 Suggested Answers
RickE1
  • 202 Answers
SOURCE: My wife has a Bernina
Possibly a fuse blew. To get to the fuse is a bit of a job as you will have to remove the handwheel, handwheel side cover and back cover to see it. The screws you can see are self evident though there are screws etc. under the cover in the center of the handwheel and holding the covers benieth the machine. When you do have the covers removed be sure you have grounded yourself so as not to send a static charge through the circuitboard while checking out the fuse. The side handwheel cover needs to come off before the back cover.
Posted on Jan 08, 2009
RickE1
  • 202 Answers
SOURCE: Bernina 180 sewing machine 'died'. Was sewing -
Hi, sorry to say but very rarely is it the fuse when this happens. You can unscrew the one screw on the ouside and pop the cover open. (carefull as there are wires attached and make sure you are grounded or have discharged any static from yourself).
The fuse will be self-evident but I suspect you will need a visit to your Bernina dealership for a new circuitboard.
Rick
Certified Bernina tech
Posted on Dec 07, 2009
  • 89 Answers
SOURCE: My Pfaff 1471 lights up,
Were the base plate pugs into the power leads, you should read about 6-18 is ohms. Open and short is a bad transformer.
Also there are fuses, 2-3 right next to the transformer, small blueish and round are the shapes. They go bad often.
Posted on Nov 25, 2011
Does the benina 1130 have a fuse
There are three fuses, all on the L Print circuit board under the rear cover.
F150 - main fuse on incoming mains supply
F151 and F152 - between the isolation transformer and the power supplies for the control logic, motors and lights.
If you are in the UK, then there's one in the mains plug too.
Apr 24, 2014 | Bernina Sewing Machines
I need a foot control for Bernette 55.
I can supply foot controls for 99% of sewing machines.
Mike
http://www.sewingmachineswales.com
sewingmachines2004@yahoo.co.uk
Oct 11, 2012 | Bernina Sewing Machines
Bernina 1130 power cord won't retract
since the machine is a bernina, the machine probably needs to
be checked at a sewing machine shop, to see why the power
cord won't retract
Jun 03, 2012 | Bernina Sewing Machines
Bernina 1130 backstitch is not working
then you need to call the shop that serviced the machine & tell them
about the problem that the machine won't backstitch & see what they
say
Apr 29, 2012 | Bernina Sewing Machines
My Pfaff 1471 lights up, but does not run. This model has no fuse. I checked the foot pedal with an ohm meter, & it sends a variable signal. My house took a direct lightning strike 2 weeks ago, &...
Sep 22, 2011 | PfaFF Sewing Machines
Need free! copy of bernina sewing machine #1130
Try this web site:
Bernina 1130 User Manual and Service Manual PDF
You can probably use the Bernina 1031 manual for most of your purposes. The 1130 is a bit newer and has more buttons.
BERNINA Support Machine and Accessories Finders and Software Support...
Jan 27, 2010 | Sewing Machines
Bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Apr 10, 2009 | Bernina 1008
Bernina Buttonhole foot #3A
Hi, you must have an 1130S which means it could also be a circuitboard issue. If the LED/LCD light for the buttonholer does not flash you either need a new RET-Print (circuitboard) or a new buttonhole foot. Sorry to say that you DO more than likely need a new buttonhole foot according to my manual on this machine. No way to repair the foot that I know of.
You should bring the machine in and try it first.
Guess not all news is good news. Sorry.
Rick (Bernina tech)
Aug 18, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
127 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
