Question about Hammering
Servicing kanga jackhammer
Greasing
How do i chack bosch 60 lb jackhammer oil leval
Bosch hammer uses grease available in repair kit. Check ebay or parts house. Remove four hex bolts on the mid section of the hammer and pull off the lower end. Most of the grease goes here. There is a side cover to expose the drive gears if you hear gear noise. Depending on use, only needs grease once a year. Good luck.
Jun 30, 2014 | Makita HM1500B 42 Lb. Demolition Hammer
Bosch jackhammer
To long without service , or problem with a broken part ? or an problem with a electric field (slide contact somewhere ) or one of the carbon brushes is autostop activated ?
Or simple a cable break , a switch with a problem ,
Mar 27, 2014 | Hammering
What type of oil
http://www.homedepot.com/p/Makita-Hammer-Bit-Grease-194683-7/205182387
For outside chisels
Inside its depend on the model but most time its a Makita 181490-7 or for the older types Hammer grease Makita P-08361
Feb 19, 2014 | Makita Hammering
Disapearing kangas and slow game
If game runs slow then you need to adjust pc settings to peak performance.
- update drivers that control your PC
- update java
- stop unwanted programs and services'
- stop Antivirus
- delete temporary internet files
If issue still exists then i would suggest to use a game optimization tool like PCFresher.
Mar 25, 2013 | PopCap Games Bejeweled Blitz
Black & decker jackhammer manual
Go to the Dewalt service website at http://servicenet.dewalt.com, put your model number in the Find Parts search box and you can get the manual and parts breakdown if they are still available. You didn't list the model number so I couldn't verify if it's still available there.
Jul 24, 2012 | Electric Demolition Jackhammer
Kango 900 hammer:\r\nDon't know how to greace the
Milwaukee K900K or the English Kango 900K Blue old or Red some younger handle it differs very much English Kango was using a thick brown grease in 2 chrome colored plastic bags . the Milwaukee K900K has a lubrication grease also not oil but be aware of the operating hours i f you have a K900K model from Brand Milwaukee tools replace also a service kit and the bearings on the armature is important also Its neccesary to protect you from damage
if you have a English Kango its hard and expensive to get a spare parts and most times the tools are worn in the front of the chisel stroke bolds do not get right close and the piston pins are worn it was a good tool about 20 years ago i have serviced much of them . but the first thing thats important that its air-tight in front of the chisel and everywhere thats having a mechanic/pneumatic duty
Milwaukee Services and fill k900k with (IMPORTANT) the right number
Jun 05, 2010 | Electric Demolition Jackhammer
My Black and Decker demolition jack hammer broke
Go to Dewaltservicenet.com and in the header under service locator follow the prompts and type in your zip code to find the nearest service center near you.
Aug 30, 2009 | Electric Demolition Jackhammer
Kango 950k
it sounds like it needs service,service is taking lower unit apart cleaning and regrease with special kango grease, if unit was serviced recently or not used much, grease could be real old and dry,sometimes you have to warm up unit before they start hitting correctly,,also if used a lot could be dirt build up,inside bit holder.remove bit holder clean out dirt regrease with heavy bearing grease,just grease the lower part,not very much grease is needed
Jul 28, 2009 | Electric Demolition Jackhammer
I have a old electric 120vac jackhammer (not sure manf.)
usally their is grease packed in the hammer part,you can usally see a plastic type bung(plug)on outter casing
May 13, 2009 | Electric Demolition Jackhammer
Jackhammer
Hi
Check your main memory. If you could have loaded more number of programs there will be problem in accessing the memory. Automoatically the speed will come down. If you remove of those unwanted stuff from your phone including stored messages you will find better speed and accessibility.
Sam
Feb 12, 2008 | RIM BlackBerry Pearl 8100
Hammering Logo
88 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
