Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Dead KDf 60xbr950; 6 blinking red lights. I spent hours on research & would like 2nd opinions, please.
I've got a 3 1/2 yr old 60" KDF 60XBR950 which suddenly just died. The blinking light sequence says it's an internal problem. I am not a tech by any means, but am handy and willing to try a few simple procedures to save huge repair bills and a weeks of waiting. In any event, I researched a bit and downloaded a service manual which tells me as follows: "+B OVP error 6 times +17V is not supplied.(G1 board)" The board is cheap enough ($45 plus s/h) and even to my untrained eye looks easy enough to replace. A few screws and careful removal, matching and reinstallation of wires and the replacement should, at least in theory, be done. Whether or not this solves the problem is whole differnent matter...... The threads I saw here point to various possible issues such as the board itself or even the optical block (ouch!). If this is the issue I'll be speaking to Sony and/or just buying a new one. I am willing to swap what appears to be an easily reached component, but am hopefully smart enough to stay away from buried or delicate components. The G1 board seems to be neither. I pulled the back cover and could see it there right in front of me. Here are my questions: Is this a worthwhile to at least try replacing the G1 board? My realistic worst case scanario is that I waste $60 in parts/shipping. Well, OK, the total worst case is that I drop the TV and smash it in a million pieces, but I'm trying to be at least somewhat realistic. Any suggestions/hints/warnings or other ideas? Thanks to all in advance. Much appreciated
  • 1 more comment
  • James Shuttleworth Jul 19, 2007
    Thank you for spending the time to help. Much appreciated. Unfortunately, the problem is far more severe. Seems the "Q box" died--a $900 repair, which Sony will not assist me with.
    Do I fix it or buy a new one? Hmmmm........
  • Anonymous Nov 17, 2007
  • ata87 Dec 30, 2008
    I replace the G1 board but no lock with
Thanks. Even better-- Sony is giving me a new 60" XBR2 (usual price: around $3K) for the cost of repairs, or $800. This should work!
Posted on Aug 01, 2007
    Scholar:
  • 150 Answers
Not the board, there is a thermal fuse under the lamp housing that has opened up, you need to order an upgrade thermal fuse link that will mount to the Lightengine side of the lamp housing, the clips are there, there is no sensor there.
Posted on Jul 17, 2007
  • les lake Aug 01, 2007
    My Opinion is Buy a new one, a 55" Sony LCD runs under $1500
  • les lake Aug 03, 2007
    KEWL, was worth contacting them then! :-)
3 Suggested Answers
  • 2336 Answers
SOURCE: sony grand wega kdf 60xbr950 purple stain on the screen
Is very likely that the lamp will need to be replace soon.
Is some cases those spots might be generated in the inner part of the lamp.
Posted on Apr 27, 2008
  • 22 Answers
SOURCE: kdf-60xbr950 no pic or sound. standby light flashing
Sounds like the lamp is bad. Might be time to replace the TV.
Posted on Mar 31, 2009
SONY KDF-60XBR950
The six blinks should have been the G1 board, double check your wiring and the check to make sure you have the 17V coming from the G1 board. If the problem has not changed it is possible you got a bad board.
May 24, 2014 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
KDF-60XBR950
Zenit, When did you start having that problem? havent it turned on once? Do you still have the warranty?
Dec 28, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
KDF-60XBR950 red light blinking 6 times. Please help.
red light usally means bulb is no good, not in properly, or is overheating. if you turn it on and it goes off in short time and starts blinking red then its the bulb for sure. they get hot then kick out and blink..
Aug 18, 2013 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony kdf-50e200 wega. replaced bulb. now it wont turn on and red power light blinks
Was the set working prior to the replacement. If so you must go back to repeat what was done and it can be sometimes related to a fault connection in the process of replacement. so please check this out before we can suspect the motherboard drivers.
Oct 28, 2011 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I had 3 red blinks in my KDF-60XBR950 Sony Wega.How do I jumper the door switch? What do I need to put to hold the switch?
The door switch is for safety. Is the door deformed (PN: X-4042-246-4), which is causing the error? Twisting the 2 wires together (after stripping) is a quick way to by pass the switch. If that fixes the problem, you should replace the switch (PN: 1-570-245-11). I hope this was helpful, best wishes.
Apr 24, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand Wega KDF-50E2000 3 red blinks
3 blinks is the lamp door error code. Try jumpering the door switch. These switches are notorious for going bad.
Mar 28, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Wega, 60" LCD
I hope you know the light engine to these sets cost 1,900.00 up to 2,500.00 also did you reset lamp timer when you installed new lamp to tell set lamp has 0 hours on it?
Nov 27, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
No picture but hear the fan on
does your power light blink red 3 times?
Feb 17, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
KDF-60XBR950 Start up failure - Blinking Red Lights
anytime you put pressure on something to get it to work is not a fuse but a bad connection. in this case sounds like the door triggers a switch....maybe you can just bypass the switch. or you need a new door housing assembly. good luck
Aug 15, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
942 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
