Question about GE Cafe 20.7 Cu. Ft. Stainless Steel French Door Refrigerator - CFCP1NIZSS
The interior water dispenser suddenly stopped working
icansurf
  • 72 Answers
SOURCE: WATER IN DOOR
bad solenoid assembly maybe
Posted on Jul 11, 2007
SOURCE: water in door stopped dispensing
We just had this happen on our Kenmore side-by-side and we had to replace the water valve and now it works great.
Posted on Aug 17, 2007
PJofSMK
  • 3 Answers
SOURCE: the water dispenser in the door suddenly stopped working
Try checking the hose that goes from the freezer to the water pipe it is hooked up to, it may be clogged. If you aren't sure if it is clogged just go to home depot and buy a new hose kit witht eh spout, it cost no more thna $20. This happened to me and when I replaced the old hose and spout with a new one it worked fine.
Posted on Mar 13, 2009
aasc
  • 1606 Answers
SOURCE: water dispenser suddenly not dispensing water
Remove the bottom kick plate . Follow the plastic line about 6" and you'll find a connector . Push in on one end of the connector and at the same time , pull the line out . Close the door and press for water . If no water comes out of the disconnented line , the water valve is probably bad . If water does come out , the line inside the freezer door is frozen . If this turns out to be so , you can lower the freezer temp for maybe days , or , put the food on the door, inside the freezer , tape the light switch down ( to keep the lite off and fan running ) and tape plastic over the freezer door opening so the freezer will continue to work . Reinstall the line back into the connector by pushing the hose firmly into place . Leave the freezer door open for maybe 1 or 2 days for thawing out , going by ocassionally and pressing the water dispensor . Important : lower the freezer temperature slightly to keep line from freezing again . ONLY CHANGE THE FILTER WHEN WATER FLOW SLOWS OR ICE CUBES GET SMALL . The change filter lite comes on by the amount of times water dispensor is used and to make money for the vendor .
Posted on Aug 12, 2009
  • 668 Answers
SOURCE: the Water Dispenser suddenly stopped
It tends to be the problem of the valve. Connection is not proper it is not allowing water to ice maker. The valve can be checked with a volt/ohm meter if you.
You can ohm the solenoid of the valve and see if the circuit is open. You can also use the meter to check voltage to the water valve when the ice maker cycle starts. No voltage if the ice makes cycles or if the ice maker never cycles would indicate a problem with the ice maker.It tends to be an open solenoid circuit in valve.
Hope this helps.
Please feel free to ask us if you have any further queries.
Shane
Posted on Apr 24, 2011
FGHB2844LF water dispenser not working
Turn the temp down on the refrigerator side but not below freezing. Some frigs have a "trap" set up for the water dispenser. its located behind a panel in the frig and it is there to help chill the water before it dispenses. if the frig setting is too cold then it can freeze the water .
Dec 08, 2013 | Frigidaire FGHB2844LF Gallery 27.8 Cu. Ft....
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Water dispenser stopped working
Our fridge did this. Unplugged, plugged back in and it reset and is now working.
May 05, 2009 | Hotpoint HSS25GFP Side by Side...
Water dispenser inside fridge does not dispense water
Are the water inlet / outlet correctly fitted onto the filter ??
Sounds silly - but very easy mistake seen several times.
Is the water supply for the filter turned on . . remove hoses from filter to verify. - YOU WILL GET WET.
Aug 15, 2008 | KitchenAid Architect KBRA20ERSS Bottom...
Kenmore Elite - Interior water dispenser stopped working
Frozen water tank, some of these had an insulation kit that will prevent this from happening. Make sure you have water coming out of valve to tank, if so it will probley be a frozen tank. Make sure fridge is on factory settings. If it doesnt thaw out, check into the frozen tank kit...
Jul 14, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Water in door stopped dispensing
Aug 17, 2007 | GE GSS25SGMBS Side by Side Refrigerator
WATER IN DOOR
Jul 05, 2007 | GE GSS25SGMBS Side by Side Refrigerator
GE Cafe 20.7 Cu. Ft. Stainless Steel French Door Refrigerator - CFCP1NIZSS Logo
26 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
