Question about Honeywell L7224U1002 electronic aquastat 120 volt 60HZ high limit 130240 low limit 110F to 220F Less Well
How to clear error 2 on a Honeywell Aquastat L7224U
2 Suggested Answers
  • 693 Answers
SOURCE: How to wire 240v to honeywell aquastat
heres a diagram its self explanitory http://digital-magic.tv/digitalplanet/resources/36_Honeywell-circulator-zone-panels.pdf
Posted on Oct 26, 2011
I have installed honeywell aquastat relay per instruction manual on my dunkirk xeb-4 lp boiler furance with honeywwell ignition unit s8610u but it wont ever start the exhaust fan checked everything several...
If aquastat wirings are ok, and control module had been set up properly, the the furnace should start.
Check if bypassing the control the furnace starts, if it starts then check aquastat wirings.
If it depends on the furnace, check the valve, the safety sensor and the ignitor.
Here is the guide to set up the Aquastat control:
Guide to Setting & Wiring Heating System Boiler Aquastat Controls
Sep 13, 2008 | Honeywell Heating & Cooling
Well my furnace wont turn on at all i got power to the aquastat "honeywell L8148A1017" but no power coming out of the b1 b2 "burrner outs on the board at all but i hear the click in the...
the relay on the aquastat is probably bad ( contacts ) try actuating the relay with a screw driver to see if it engages the unit. if it does theres your problem new aquastat
May 09, 2017 | Honeywell Heating & Cooling
My L4103 aquastat is set too hot, it does not clearly stat temps on set dial which way do i turn it to lesson temp
phl4103-3.jpg on the left side of the dial will be a little metal arrow that will not move when the dial moves, this is the set point. set the temp. you want at this point.
Dec 17, 2010 | Honeywell Heating & Cooling
Looking for simple wiring diagram to wire ******** aquastat
What are you fanning??? the fire?
Do you have a circulator that circulates when the water is up? Many controls have a AUX connection ... wire the AUX to your fan --- alaternatively, wire directly fron your circulator connection to the fan.
I hope I understood your question ...
Let me know what happens.
a
Oct 16, 2009 | Honeywell International Honeywell&...
I want to increase the boiler temp by using the your aquastat
Warning! Can cause electrical shock! Here is the instruction manual
for L7248c
http://customer.honeywell.com/techlit/pdf/PackedLit/68-0281.pdf
Jan 12, 2009 | Water Heaters
How to install aquastat relay L8148J1009
Go to this URL for pdf instruction sheets.
http://customer.honeywell.com/techlit/pdf/PackedLit/95-6940.pdf
Oct 23, 2008 | Heating & Cooling
Honeywell L7224U1002 electronic aquastat 120 volt 60HZ high limit 130240 low limit 110F to 220F Less Well Logo
Top Honeywell Home Security Experts
Sean
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
