I have an Insignia 39L700 tv. I have purchased an antenna to try and get a few local channels. When I scan for channels I come up empty. The antenna may be in the wrong position, but I have no channel
    Genius:
  • 1,669 Answers
Try moving the antenna around various places in the room that are close to the wall where the channels originate their broadcasting and then have the TV automatically scan for available channels.
Posted on Jan 20, 2013
The analog tv picks up a lot more stations and correct channels than the LED TV. Is it possible to set the Insignia LED NS-19E320A13 to analog? Is there a device available?
.YES IF ITS A DIGITAL TV U WILL GO TO MENU GO TO ANTENNA CHANGE FROM DIGITAL TO ANALOG OR AUTO ENTER THEN SEARCH ANOTHER WAY GET AN ANALOG TO DIGITAL SET TOP BOX FIX YA ANTENNA TO IT CONNECT TO TV BY HDMI.OR AV CABLES GET THE SET TOP. ON GO TO SCAN OR SEARCH AND YOU WILL HAVE ANALOG CHANNELS ON YOUR LED TV
Oct 08, 2015 | Insignia Televison & Video
Using hdtv antenna (not cable) but get no signal when scanning channels on my Insignia 19 inch tv
You may be using the wrong type of antenna. Apparently there is a lot of mystery and fiction in the advertisement of these antennas. Read this article and see if it doesn't clear up some issues for you.
Sep 09, 2014 | Televison & Video
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
I CAN ONLY RECEIVE 2 OR 3 RADIO CHANNELS ON MY INSIGNIA RECEIVER
Radio tuners receiving AM and FM channels/broadcast MUST have some sort of antenna connection. For local channels a paper clip will work, but for more distant channels, use either a better inside antenna or purchase a outside antenna as needed.
Jan 30, 2013 | Insignia 200W Stereo Receiver
Insignia channel auto scan
If its cable and requires a box the set will have to be on a specific channel---if directly from wall etc go into set menu and make sure it is set to CATV or cable----if in air or antenna it will not save channels.
Jun 13, 2012 | Televison & Video
How can I receive local channels on this tv? I do not subscribe to cable and only want local tv channels. I purchased antenna, but no luck. I only get ION channels
Hi my name is Roety,
I can help you with your issue ,
all you need is an antenna then run the auto scan programming to lock in any available channels.
I roof or attic antenna would work better than an indoor antenna
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Jan 30, 2010 | RCA L26HD35D TV
New tv connected to cable, suppose to have 52
With the cable securely connected to your new TV, go into the Menu setup features and tell the set to AutoProgram all cable channels. It will then search for every signal. This will take a few minutes but give it some time to scan,
If it cannot find anything then you do not have a proper cable or antenna signal.
Cheers
Dec 29, 2009 | Insignia NS-L19Q-10A 19 in. HD-Ready LCD...
I'm able to view all local channel in digital (new tv with in philip hdtv indoor antena) but after conver to diggital I lost channel 7 and 9 I scan many time but sitll no lick
What local area are you in? 7 & 9 may have moved to another channel. Every distributor of channels ie. Comcast, Directtv, Dish, Bright House, etc has channels all over the map!! with no real clear plan it seems! If you go to DTV answers.com you can get the new local lineup for your area. At this point, if you still don't have the signal, you may need to re-align your antenna for the best possible reception. If you go to Terk.com you can type in your zipcode and it will show you where the transmitting antennas are located. You may need a better antenna like a Wineguard or larger Terk to get all your channels. Hope this helps
Jun 23, 2009 | Insignia Digital-to-Analog Converter for...
Hello. I am contaqcting you for my mother. My brothers recently purchased and insignia 26" LCD NS.LCD26. I have run it through the auto scan program, and she receives the digital channel 18-1 but on...
Are you useing rabbit ears? If so you may have to switch to an outdoor antenna to get those channels ( the digital signel is a better picture but the signel is not as wide as an analog signel so in most cases you will need an outdoor antenna!)
Also make sure your tv is in the antenna mode and not the cable mode!
Please rate this response
Thank You!
Jan 23, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
