Question about Toshiba Satellite 5005-S507 Laptop Universal AC Adapter 15-17v (AC22VPN9HV6NJ)
Toshiba satellite 5005 s507 no wireless?
I bought this computer used, rebooted back to default and now I cant get it to connect to our wireless internet. I have tried FN F8, that turns a green light on but still wont connect. I can't find a switch to turn the wireless on
    Master:
  • 969 Answers
Use network to setup a wireless connection. You must have a RJ45 hard line for internet to perform this task.
Posted on May 25, 2014
4 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: Why My TOSHIBA SATELLITE A660-13Q Froze during
Possible that PC is hanging up as there is fault on the OS ( operating system) . So open the internet options in the browser and clean all the cookies, temporary internet files, defragment the drives and RESTORE the PC to an earlier set date.
You can use a registry cleaner like Advanced system care. Download from the site and check you system for corrupt files. Also use a good antivirus software which is active to keep your system performing without an attack on the OS. Remove all unnecessary programs installed which you do not use all the time and clean up the drives. This will free up the space and make your system faster.
If there is no response but the PC tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed.
Also a fault on the memory can be another issue but an hardware problem that needs a probe.
Posted on Jul 14, 2011
  • 114 Answers
SOURCE: HOW TO RESTORE FACTORY DEFAULT
If my answer has helped you today please offer four thumbs up as thanks!
Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
Posted on Sep 02, 2011
shahidkap97
  • 392 Answers
SOURCE: Toshiba Satellite Laptop wont boot up
does it shows the flash screen which displays *********** board? if yes then you can check by installing a fresh copy of windows and if nothing comes on the screen then you may have defective mother board.another thing if *********** board is fine and you find that your system is not installing the OS,you need to zero-fill your hard drive then,coz you may have a corrupted hard drive.
Posted on Apr 07, 2012
My satellite 5505-S504 seems to heat up and shut down. I can hear the fan but the bottom of case seems to get to hot. It will not boot up completely. It boots to the point that the windows xp logo shows,...
A lot of Toshiba laptops had overheat problems. Buy a can of air and blow out your air vents real good. One in the back is a heat sink and they accumulate dust and will start heating up. You can buy the air at any electronics or computer store or if you have an air compressor you can use that, the can air is dry.
Dec 11, 2010 | Toshiba Satellite 5005-S504 Notebook
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba satellite 5005-S504 Secure Digital Card Slot problem
Hi there
Take a close look inside the card slot (you may need a torch/flashlight) look to see if any of the brass pins are bent or out of position, if they are use a very small flat head screwdriver to gently push them back into place.
If all looks fine with the slot and there are no foreign objects inside your card maybe faulty.
Also i suggest the you check the drivers are installed, check this in device manager.
Good luck and thanks for using FixYa!!
Apr 03, 2009 | Toshiba Satellite 5005-S504 Notebook
Cannot get Toshiba P@% S507 to see new hard drive.
you can't use a restore disk made for a specific hard drive with a much larger hard drive. This information is checked by the restore cd. You would need to contact toshiba and get a regular windows install cd.
Apr 01, 2009 | Toshiba Satellite P25-S507 Notebook
Toshiba Satellite wireless switch doesn't turn on
Ok, if your using Vista, what i want you to do is right click "computer" select "manage" and then "device manager", then click on the + sign next to "network adapters" and right click on the wireless network and "un-install" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again
keep me informed please and thanks for using Fixya
Feb 13, 2009 | Toshiba Satellite M35X-S161 Notebook
My Toshiba Satellite P25 will no longer boot up but keeps running the following text. RTL8139(x)/8130/810X PCI ethernet controller v2.13 (020326) PXE-E61: Media Test Failure, check cable PXE M0F: exiting...
Hi and welcome to FixYa,
Initially, I am tempted to think that the CMOS/BIOS could not detect the internal hard disk and therefore is booting from the LAN. Pls reboot and enter CMOS/BIOS setup. Thereafter determine if the computer could detect the hard disk either auto or manually.
If the above solution has merit, pls click on my "Ask Me" to explore additional options, postback how things turned up or should you need additional information.
Good luck and Thank you for using FixYa.
Dec 03, 2008 | Toshiba Satellite P25-S507 Notebook
My Cd-Rom/DVD-rom don't work. It doesn't open any folder. I thought I have problems with drivers: SCSIVAX DVD/CD-ROM SCSI CdrOM DEVICE DVD-ROM SD-R2102 TOSHIBA LAPTOP SATELLITE 5005-S507 THANKS, OSCAR
According to the Toshiba website, the scsi cd-rom/dvd-rom does not require a driver to operate, but the driver for the scsi controller card it plugs into may need to be reinstalled or updated. Visit the following link, and go to the section labeled scsi cdrom/dvdrom. At the bottom of this section there are two links to websites where you may be able to find the drivers for your scsi controller card.
http://sdd.toshiba.com/main.aspx?Path=8100000000220000000100006598000000E7/810000000C58000000010000659C00002C36
Apr 09, 2008 | Computers & Internet
I need help i've tried and need help bad so please get in tuch
this happened becoz u heve cancelled windos insatlltion in the middle . do one thing go to bios option by pressing f2 or del during boot up and then selct cd as primary boot device . also dont forget to selct the name of cd drive in cd drive option then try formatting the computer
Jan 23, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Reformatting the Toshiba Satellite 5005-S504
you did not specify what operating system you are currently using, anyhow, if you are using winxp, configure the bios setting set the cd rom as your 1st boot device and insert the winxp cd to the cd rom then save and exit the. computer will automatically reboot after exit. a message will appear "press any key to boot from cd" you may press a key. you follow correctly instructions or message from the screen then you will succeed. hoping that this will help you. if you have some queries you may send me thru my e-mail.
Dec 28, 2007 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S507 Laptop Universal AC Adapter 15-17v (AC22VPN9HV6NJ) Logo
89 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
