Question about Cannon Office Equipment & Supplies
WiFi connection/printing with Cannon MP560
Interesting problem. I can not get my cannon mp560 to work wirelessly. I can get it to connect to my access point. And in its menu gives me the details that it is. My router shows the mac address that it is indeed connected. Here is the kicker, I have setup my router on a subnet of 192.168.2.1 so that it would not interfere with the att uverse gateway they give you and must have (its under the normal 192.168.1.1) When i look at the ip address assigned (from the printer menu itself) it has an ip of 192.168.1.79. So I know its on the wrong sub net, but it says it is connected to the right router......... Im at a lost, I cant get this thing to work.
  • Dustin Fullmer Jan 20, 2013
    Well, just after posting this I found that the printer has a LAN menu and I can set the subnet manually. Was able to get it to 192.168.2.1! All is god now.
    *good*
  • 24 Answers
SOURCE: HP C4380, Wireless Printing Problem
Do you have other printer drivers installed, if so thre may be a driver conflict. wireless printing requires network connection and also printer drivers. This appears to be a driver issue since the printer shows up on the network. I would try reinstalling the drivers.
Posted on Aug 27, 2008
SOURCE: Samsung ML 2010 under mac os X 10.5
I found a solution that worked for me by prowling around various Apple discussion forums. The two keys to the solution for me were numbers 3 and 5 below.
1. Opened print/fax preferences
2. Opened Add printer by clicking the +
3. For protocol, select HP jetdirect-socket (not IPP or LDP)
4. Determined the IP address for my Belkin wired print server and typed this into the Address line of printer setup
5. Manually selected the printer driver as ML-2010. It is in the list of drivers but is in the M's, not under the Samsung drivers.
6. This worked for me. I've seen reports from people who had to power cycle their print server and/or printer as well.
Posted on Oct 26, 2008
  • 88 Answers
SOURCE: printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
Posted on May 23, 2009
SOURCE: Brother MFC-7840w wireless printer won't connect to network
Ignore the instructions that come with the printer, choose Open System, then choose WEP, enter, and it hooks up. Thanks to the above posters for this solution.
Posted on Oct 18, 2009
SOURCE: Brother printer and Neygear router wireless connection bad.
Had the same issue. Change the router wireless security settings from TKIP to AES algorithms. This did the trick for me.
Posted on Jan 11, 2010
Without Disc how can I connect a CANON MP560 printer to the computer ?
go to the cannon support website put your data and for your printer and download the drivers for your printer on to your computer. space
Mar 05, 2015 | Canon MP560 All-In-One InkJet Printer
My Canon mp560 series has an error.it says an error has occured.Turn off power then back on again.If problem persists see the manual and I follow that instructions but still not working
FIRST OF ALL I WILL ADVISE YOU TO REMOVE OR DELETE ALL OF YOUR PRINTER DRIVERS FROM YOU COMPU DO THIS AFTER YOU UNPLUG AND DISCONNECT ALL THE CABLES OUT OF FROM THE BACK OF YOUR PRINTER AND COMP AFTER YOU DO THIS GO TO CANNON WEBSIDE>SUPPORT > DRIVERS ENTER YOUR PRINTER MODEL# COMPU INF ETC DOWNLOAD AND INSTALL DRIVERS , THEN RECONNECT ALL CABLES BACK AND FOLLOW INSTRUCTIONS AND YOUR PRINTER SHOULD WORK BACK.
Sep 28, 2014 | Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL...
Mp560 u052
I tried all the solutions I found including the one recommended by Cannon, replace all ink cartridges. Nice parting shot! I stopped short of replacing the print head. The best solution I found is buy a new printer. Make sure it is from a different manufacturer.
Aug 11, 2013 | Office Equipment & Supplies
Cannon mp560 photos are printing all a pink colour
it sounds as if one or more of the nozzles of your printhead is dried or blocked. I would advise printing printing a test page like this one to clarify the cause.
Assuming one of the colours is missing (i would imagine it would be cyan or yellow) then run some head cleans from your printer software or the printer itself.
Sep 06, 2012 | Canon MP560 All-In-One InkJet Printer
I have a Cannon MP560 all in one printer and I want to connect it to my laptop as well as my desktop. I have sky broadband and wondered if it can be connected via that.
I really don't see why you can't (I hate the "can't word - it means won't! -- like nails on a chalk board!)
Ok - well, if you haven't tried it, call tech support at the manufacturer of the printer or perhaps even sky network? and see if they can assist?
Best regards
Ck
Oct 22, 2011 | Office Equipment & Supplies
I have installed a replacement ink cartridge in my MP560 and it is saying ink tank is not recognised and refusing to print. What can I do? It seems like a bit of a con to force you to use Canon inks which...
hi,restart your printer with the printer replacement inside and wait for the error message to appear once error appear,press and hold the stop button untill the system re started.in this process the main ink detector will be reset and will recognized the new replacement cartridge
note:press and hold the stop button and never release the button until power restarted.
If you want to be able to save on your cartridge you can refill your empty cannon cartridge with ink
here a video on how to refill the cartridge.
Jun 28, 2011 | Canon MP560 All-In-One InkJet Printer
Hello, im trying to install my wirless printer to my wireless computer and im having some difficulties. for example its asking me to check my wireless LAN access point.. I dont know waht that is? im...
The Canon is trying to connect to a wireless router or wireless access point which is connected to your computer network. Your Sprint 3g device is a wireless broadband device for Internet connection and cannot connect to the Canon using this device.
You need a wireless card that connects to the wireless router or wireless access point.
Otherwise you can connect to your printer using a printer cable.
May 16, 2011 | Canon MP560 All-In-One InkJet Printer
I have a new Canon Pixma MP560 printer and a router that supports wireless connection between two laptops and our existing laser printer. The laser printer is connected to our main desktop communter via a...
In this situation your wireless printer might require a power reset before you print each document. Though the printing activity will take place efficiently you will have to physically go and power the printer to enable it to print. This problem might require you to reload the firmware of the router and set the wireless printer to manual IP address in order to make it work seamlessly no matter how many documents you have to print. get more information for Wireless Printer Problems .
Sep 06, 2010 | Canon Office Equipment & Supplies
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Greg Cann
Greg Cann
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
