Question about Emerson MS9700 CD Shelf System
CD player stops, won't open
When I turn on the cd player, it makes a noise like it's trying to move to a disc, but then stops. I've tried switching to another disc, but nothing happens. Also, the player itself won't open. I tried looking for a manual opening mechanism for the player, but there doesn't seem to be one. I've removed cd cases from the top of the system, thinking there might be too much weight on the top, but that didn't work either. The radio and tape player are working fine.
  • 2 more comments
  • Heather McGinnis Jul 18, 2007
    What is does is make a kind of clicking noise like it's trying to switch to a cd. I'd really appreciate any help, since I've got cds stuck in there that are out on loan.
  • atomicmini Nov 27, 2007
    my cd thing won't open
  • grannie60 Jun 22, 2008
    CD player door wont open and when it is turned on it just clicks and nothing happens. This is a RCA brand, it is very frustrating since I am a senior citizen and dont have enough knowledge for these things.
  • gailcry Aug 01, 2008
    I have a Emerson MS9700 CD Shelf System and the drawer that holds the CDs does not open and I was wondering if you knew how to open it?
I have a windows vista and when i put in a cd nothing comes up now yet i downloaded pictures a couple of weeks ago
Posted on Oct 09, 2008
How do I get to the broken spring to see if that the problem?
Posted on Jun 24, 2008
There is a spring loaded mechanical switch under the cd rack that often breaks
I am trying to fix one right now and i am going to rig a three phase switch on the out side of the case
Posted on May 16, 2008
You have to unscrew the case. then you can get the cds out
Posted on Aug 05, 2007
SOURCE:
Honda 12 odyssey cd player says bad disc eject
The symptoms suggest a CD is jammed inside. You will have to remove the player and open it up to find the problem and correct it.
Aug 14, 2016 | Audio Players & Recorders
I have a Sony CDP-CX400 that has a flashing blue light.
sounds like the mech may be out of alignment. I would try running it by hand and making sure everything is moving correctly.
Mar 25, 2014 | Sony CDP-CX400 400-Disc CD Changer
Bang & Olufsen Beosound 3200 CD Door won't open
Could be the PCB9 light and motor control have the problem its on the upper left side of the player.
Feb 25, 2013 | Audio Players & Recorders
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
CANNOT OPEN PLAYER
To open the drawer, unplug the unit while the power is on (so that the drawer doesn't try to open on its own). Keeping the unit flat on a table, look underneath and find the small hole where you can turn the loading gear. Rotate it until the unit opens, using a standard flat screwdriver. The loading gear is a white plastic part with a slot in it. You should be able to see it rotate if you move the drawer by hand.
After manually removing the disc, turn the gear with your screwdriver until the drawer is all the way in, The gear should be able to be turned for three or four more turns when the drawer stops loading. If it doesn't, turn it a bit further unit it "pops" past one more gear notch. It should then turn freely for a few more turns, at this point you should stop. Do not force it once it stops the second time. This is the "Disc Loaded" position.
Power the unit back up and see if it loads a disc and plays correctly.
Dec 18, 2008 | Sony CDP-C445 5-Disc CD Changer
Tray will not stop opening and closing
You have to open the cabinet ..with the power off!! with tray open look at the laser it should be in the cd home position..move the laser toward away from the spindle motor or turntable.you should see a switch with a cover over it,it may be black or white or clear..the is your laser home switch..with your finger or small screw driver gentely push the switch towards you or bend it towards you.with the cover off.plug the unit up.Watch the laser as it moves away from you towards the cd spindle, it it stops and the tray moves in, and the cd mech chucks .you should see the laser turn on and see the objective lens move up and down..if it does not..and it continues with your original problem the you have to retime the tray and loading gear..try this first..
Nov 02, 2008 | Sony CDP-CE335 5-Disc CD Changer
Faulty Denon CD player
The sled motor sounds like it's malfunctioning and not stopping winding at the beginning or end of the disc. There should be a detector switch to stop this. Might just need a good clean.
Nov 13, 2007 | Denon CDR-M30 CD Recorder
My portable cd player is acting weird all of a sudden! HELP!!!!
You need to open it up to check the parts inside. First look around to see if there is any plastic parts that are damaged. This might account for the noises inside. If you can not see anything wrong. Get a magnifying glass or lens and look at the lazer lens. Make certain the power is NOT on for any of these tests. If you see any odd light patterns or damage on the lazer lens it will not play discs. Unless it was an expensive model it will not be worth repairing if the lens is damaged. Do not open the unit if the model is still under warranty. In which case contact the maker of the unit.
May 05, 2017 | Lenoxx Electronics CD-50 Personal CD...
Emerson MS9700 CD Shelf System Logo
604 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
