What are the pin voltages of 4UR18650F-2-QC-MA1 laptop battery?
I have 4UR18650F-2-QC-MA1 Gateway laptop battery. It has 7 pins.
I want to know the pins voltages (output or charging) for each pin of the battery.
I have a external charger which is made for charging similar battery which has exactly same specs (Li-ion 14.8V 4800mAh 8 cells). But the connector is different. (Charger has 5 pins)
I want to match charger pin voltages to the battery pin voltages.
Could you please let me know the voltages on each pin of the battery?
or If you have external charger for the same battery, voltages on the charger?
Thanks,
Arvind
2 Suggested Answers
CHA55Y
  • 13 Answers
SOURCE: Battery for iBook 14inch not recognized by iBook
you could try resetting your pram..?
Resetting PRAM and NVRAM
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models.
Resetting PMU on PowerBook or iBook computers In some troubleshooting situations, if resetting PRAM does not resolve an issue, resetting the PMU may be the next appropriate step. For information on when this is appropriate and for instructions on how to reset the PMU in your PowerBook computer, see Resetting PowerBook and iBook Power Management Unit (PMU).
Posted on Jun 08, 2009
Low voltage battery
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12 volts or better after charging.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. Clip a testlite to a good ground and touch regulator pin, if light glows replace regulator.
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor. Good luck
Feb 05, 2014 | Harley Davidson Motorcycles
Voltage regulator
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
Jan 28, 2014 | Harley Davidson Motorcycles
7 pin connector trailer back up light no voltage
Pull one of your tailights on truck, and find wire to back-up on it, then run jumper down to 7 pin plug. Might save a lot of trouble/time.
Mar 10, 2012 | 2002 Chevrolet Silverado 1500
My gateway MA1 laptop running win xp has cooling problems
Contact GATEWAY, and get them to fix your laptop.
The fan is designed to run at "full-speed" when you first turn it on, and then there are temperature sensors that slow the fan down, to minimize noise, while the computer is "cool" enough that the fan does not need to run. The sensor is malfunctioning, and is not turning-on (or turning-up) the fan when the computer gets "warm".
Jul 17, 2010 | Gateway Computers & Internet
Which connectors are used for front panel, power on (red @white) and led ( blue @ white) please show a close-up view
On the motherboard the pinouts on the front panel should be colour coded, and marked with letters like in this picture >>>>>
The connectors are also marked corresponding to where the connect on the motherboard, like in this picture >>>>>>
If the board is not colour coded then the motherboard will marked with the same letters, you may need a strong light to see the marks.
Regards.
Feb 22, 2010 | Gateway GT5428 PC Desktop
I need to reset my bios password on my Gateway T6836...does anyone know how?
hi
1} visit the website to recover your BIOS password
http://www.pwcrack.com/bios.shtml
OR
2}it is very risky to unlock it on your own .it involves shorting of pins on the motherboard (remove the Cmos battery and put it after 1min)
clear the password
Dec 22, 2009 | Gateway T-6836 Notebook
Gateway Laptop it not powering with or battery or plugged in
Try to connect AC/DC power supply to your PC. If it works there is something wrong with your DC Battery. If you have done this, try to use tester to test if the power battery can still transmit power from source. If power is down, may be another kind of battery that is compatible to your PC. Insert only battery required for your laptop that would destroy your PC totally.
Jun 19, 2009 | Gateway Computers & Internet
Gateway MX6453 power pin problem
http://shop.ebay.com/items/?_nkw=Gateway+MX6453+dc+power+jack
Any of those should be fine.
Mar 24, 2009 | Gateway MX6453 Notebook
What type of replacement battery should I order for my Gateway laptop 400 series? The model number on the original battery is 4UR18650F-2-OA6 rechargeable Li-ion battery Rating 14.8V=4200mAh Tried...
You may try one of these 6500711, 6500712, 1528266, 61527196, 6500671, 6500710,3UR18650F-2-QC-OA1A, 6500663, 6500716, 6500718, 6500719, 6500760,6500761, 6500818, 6500819, 450SP, 450SX4, 450X, 450E, 450RGH, 450ROG,450XL, SQU-203, 400VTX.
You can get it from several locations like amozon, ebay and hwww.portablecomponentsforall.com
Nov 10, 2008 | Gateway Computers & Internet
Radar screen shows "no scanner". Would like resistance data for cable pin-out from display to scanner head.
Hello Clifford,
This is an old message. Are you still having trouble with this or has it been resolved?
Aug 22, 2007 | Raymarine C80 GPS Receiver
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
