Question about EnGenius EAP350 802.11n 2.4GHz Wireless Indoor AP/WDS/Repeater Gigabit Ethernet
How to change ip address on engenius eap350 - EnGenius EAP350 802.11n 2.4GHz Wireless Indoor AP/WDS/Repeater Gigabit Ethernet
davecon
  • 85 Answers
SOURCE: Engenius EOC-3220+
if you have a the router's manual,there is a guide on how to do that.
but in case you dont have the manual go to the device website and get some guide.default ip varied from different manufacturer
Posted on Apr 23, 2008
  • 351 Answers
SOURCE: resetting EnGenius EOC 3610
Dear Venmattey,
please follow these steps, it works:
1. Connect the EOC-3610 to your computer with a null modem serial cable.
2.Start a HyperTerminal session: Click Start and then select Programs-> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3610.
b. Select correct COM port. Ex:COM1.
c.Set baud rate as "38400", data bits "8", parity "none", stop bits "1",and flow control as "None". Then press “OK” to bring up theHyperTerminal window.
d. Unplug the power on the POE injector and wait 5 seconds then plug the power back in.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
NEW: Keenan Systems has written a software that will soft reset the 3610 series back to factory reset. Thisfree software is provided "AS IS" by Keenan Systems and is notsupported or guaranteed by EnGenius Technologies. Use at your own risk.
Be Happy Always
Regards
Posted on Dec 03, 2008
Macs R We
  • 481 Answers
SOURCE: Hi, I cannot setup my
You need to enable the DHCP server on the EOC-2611P. Then it will negotiate an IP address with your PC without you having to set one by hand.
Posted on Oct 27, 2010
Macs R We
  • 481 Answers
SOURCE: Trying to connect Blackberry to
It sounds like your AP is not set up to be a DHCP server. If you want to use devices with your AP that expect to receive addresses over DHCP, then you either have to enable the DHCP server on your AP, or enable one somewhere else on your network to which your AP provides access.
Posted on Nov 01, 2010
Macs R We
  • 481 Answers
SOURCE: my Engenius access point is having problem wth the
Assuming you are using the proper serial channel reset procedure, this should not be occurring. If it is occurring, your unit is probably malfunctioning and cannot be corrected.
Engenius eap350 not connecting to ps3
If its far away or if you have device that work generaly in thae same area then its not a issue of interference. esspecialy if it worked fine before. but one thing always bothers me is that tvs the magnetic feilds are like a invisible sheild for wifi sometimes wifi is upstairs and the tv is downstairs and the tv is blocking the signal. try moving the ps3 or the router a bit. but worst case is that the device has a issue with ssid
I have noticed that if you change the password to a router and something like a ps3 had the old password sometimes it will not work until you change the name of your network. not sure why.
Sorry if I am usless
Mar 23, 2014 | EnGenius EAP350 EBusiness Class Indoor...
Mac Laptop cannot access internet via the Engenius EAP350 wireless AP
Jason,
What does the logs say over EAP350, are the cards on Macs properly getting associated with EAP350? What happens if you put static IP?
Also check for the latest firmware for EAP350 which addresses this issue.
Regards
Feb 27, 2014 | EnGenius EAP350 - wireless access point
I have a Engenius 3220, can't access on 192.168.1.1, I was change the firmware and can't connect now... are another IP to access, I try whit DDRT tool but not can see the IP.-
Try the program Belarc Advisor. It worked for me. I had the same problem when I updated the firmware of my EnGenius ERB9250 Extender. Once Belarc has displayed everything it has discovered about your computer, scroll down to the area labeled Network Map. There you will find your EnGenius 3220's IP.
Aug 22, 2011 | EnGenius EOC-3220 (EOC3220)
I set up the Engenius EAP as a repeater and can connect to it with my lpatop and Iphone. When I try to connect another laptop I have excelletnt connectivity reception, but Internet Explorer cannot display...
Signal is only one part of the complete connectivity problem. Your lack of connectivity is almost certainly due to some other component, such as your second laptop having an incompatible static IP address specified, or no DNS servers specified.
First, ensure your PC is configured for a dynamic IP address. Once you have acquired good signal and connected, check to see that you have received a dynamic IP address. If that works, open IE and type in the numeric IP address if your EPA repeater. If you get a response, the problem is not your wireless connection or local IP address. Now type in the IP address 74.125.19.103 . If you get a response, your problem is that you have no DNS servers specified.
Feb 28, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
EnGenius Mesh AP
you will get a software which hacks the ip address search in google pls rate
Jan 20, 2009 | EnGenius EUB-362 (EUB362 EXT) Wireless...
Confirguration
After installing the hardware and physical mounting, basic configuration is something like below:
1. Set your computers TCP/IP address temporarily to be a static IP address such as 192.168.1.5;
2. Open your browser and type in 192.168.1.1 in the address bar. The EnGenius password prompt should appear. The default user is admin and the password is also admin. The control interface should now be accessible;
3. Under the Wireless heading click on Site Survey. This will display all the access points in your area. Your ISP or to whatever WiFi network you would want to connect should be listed in the ‘Wireless Site Survey’. Select the access point with the highest signal level or your choice. Click ‘Connect’;
4. After clicking ‘connect’, it should confirm that the EnGenius has connected successfully;
5. Click Ok and it will take you back to the list of wireless site surveys;
6. To confirm that the SSID has been changed go to the ‘Wireless Basic Settings’ page which is in the Wireless submenu in the left side bar. Once on the wireless page go to the box with SSID. The value should read "Your ISP or the WiFi network you would want to connect"; this has to be exact and case-sensitive to connect successfully.
This is just the start, all settings are configurable and actually depends as to how you would want to use the device; as a WiFi Access Point, as a client router mode or Wireless outdoor bridges in WDS mode.
After all settings have been changed to your requirement(s), go back to the PC's control panel and your network connections, and change your TCP/IP address back to DHCP settings (obtaining an IP address automatically). panel window.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 15, 2008 | EnGenius EOC-3220 (EOC3220)
Engenius EOC-3220+
Apr 18, 2008 | EnGenius EOC-3220+ (EOC3220PLUS)
EnGenius EAP350 802.11n 2.4GHz Wireless Indoor AP/WDS/Repeater Gigabit Ethernet Logo
161 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
