Question about BenQ FP567s 15" LCD Monitor
I have a dell inspiron 9300 with win xp pro for an os, my lcd screen is broke, so i took it off completly. now i am trying to hook up an benq fp567s monitor through the vga output. it will get me as far as desktop screen just after boot up. & most of the time it goes in to sleep mode before start up is complete. the screen suddenly displays "no signal" ?
    Problem Solver:
  • 18 Answers
Many people have noted two primary failures with this monitor. i have a couple time-saving troubleshooting tips, which actually apply to mostly all electronic devices. first, of course, bulging electrolytics [capacitors] should be considered suspect. i personally usually replace all the filter [power supply] caps as a matter of practice, since they are the 'hardest worked' component. anyway, a good way to test then [if you dont't have a capacitor tester capable of testing them at working voltage] is to check the voltage across the cap terminals, with your meter set to the A.C. volt scale. it should read close to zero, with only perhaps a few millivolts max. this test is only valid for the filter caps, many smaller caps are bypass or coupling caps, and you will get a reading. secondly, the transistors- many references have been made to shorted transistors in the inverter circuit. it has been stated that the transistors must be removed to test them. in almost all cases, they can be tested in circuit- first, if you're lucky enough to have an old analog vo. [such as the simpson 360, or tripplett 630] you can usually get an accurate test using the rx10 or rx100 scale. it is always possible to get an inaccurate reading depending on how it is configured in the circuit. - but a very good, accurate test is to measure the voltage between the emitter and base [while the unit is powered on, of course] you should get aproxomitately
.7 [seven tenths] of a volt if the transistor is on and conducting. this test applies to almost all electronics. the only variatin in this rule is if the transistor is a germanium type [you won't see them unless the device is from the late 1950's to mid 1960's] in which case the voltage reading will be more like 1.2 volts. also, in some cases, darlinton [multiple transistors in one case] occasionally behave differently, but you should still get a reading close to .7. on most inverter boards, the transistors are a TO-22 case. with the outer leads being the emitter and base, and the center lead the collector. in many devices, you may actually see the center [collector] lead cut, appearing to have no connection. this is because they are using the actual mounting tab, which connects to the collector, to make the connection. you should see the B+ [power supply voltage,] present at the collector to ground. i hope the readers find thid info helpful, and remember, these test procedures work for pretty much all electronics. - and one other thing- when testing capacitors, if you have an oscilloscope, you can take the reading across the cap terminals, and you should see a virtually flat line- if the cap is bad, you'll see a sawtooth pattern. one word of caution- if you use a scope, use a three-prong adapter on the ac plug of the scope, and defeat [don't connect] the earth ground of the scope. this is because many of the power supplies used have the common [ground] above earth ground potential, and you can actually damage it when you connect the ground lead of the scope-i've had it happen- especially in a few of the older sony tv's!
Posted on Jan 26, 2009
I've got an Dell Inspiron 9300 LCD
Try running diags Fn + Power button see if anything fails
Since you can boot to the BIOS, then the system is posting, so I suspect you have either a Windows issue or a hard drive issue.
If the HDD passes diagnostics, I'd try booting to the XP CD and see if you can press R for recovery console and run the command CHKDSK /R and see if that resolves
Post back with the results
Jul 19, 2010 | Dell Inspiron 9300 Notebook
Numerous, bright, multi-colored vertical lines on 9300 screen
Try taking out the Ram memory first one stick at a time. Sometimes when Ram goes bad or overheats, it first affects the display. If that is not the issue, here is the link to your service manual.
http://support.dell.com/support/edocs/systems/ins9300/sm/index.htm
Oct 09, 2009 | Dell Inspiron 9300 PC Notebook
Dell inspiron 1705 9300 17inch shuts down after 15-20 mins win xp
first thing to do is run psa test. turn off laptop. remove batt use ac adapter alone. press and hold on Fn key then press power button once. complete the quick test check if you will be getting error codes like 0142 , 0146 this is hard drive replacement.
Oct 01, 2009 | Dell Inspiron 1501 Notebook
Missing VGA out port signal
According to the specs for this laptop it comes with Vista. Because of that I am assuming you have put XP on it in place of Vista and I am also assuming that you just need to install some additional drivers from Dell. Click Here to go to Dell's driver listing for the Inspiron 6400 and make sure Win XP is selected as the OS and download the correct Video driver.
Jul 09, 2009 | Dell Inspiron 6400 Notebook
Monitor displays no signal as soon as i boot into win xp
You may have to put the laptop in presenter mode, which tells it to use the attached monitor. There is supposed to be a key on the laptop which does this, its normally the FN key with CRT/LCD (F8). You can also do it via screen properties but since your screen is broke u'll have to use the key shortcut.
If that doesn't work, then your video card may be bad and you'll have to change it.
Jan 26, 2009 | BenQ FP567s 15" LCD Monitor
Dell Inspiron 9300 VGA output to 46" Sony LCD problems
Assuming that you have Audio already functional, the solution is to set your system to "Clone" rather than "Extend" video. Right click on desktop > properties > settings > click on second monitor > uncheck extend monitor box (below). Click ok, press Fn + F8 to Clone.
Jan 11, 2009 | Dell Inspiron 9300 PC Notebook
BenQ fp567s won't come on
I am looking for the LCD panel from a 567 V2.
If you can't repair the problem e-mail me and I would like to buy one from you for parts.
sack4000@aol.com
Jul 08, 2008 | BenQ FP567s 15" LCD Monitor
Xp Drivers for Dell Inspiron Laptop 1525
Dear Sir, Have Dell laptop Inspiron 1525 with Vista loaded....but I need Win XP-2 OS on it...CD of which I have but don't have the laptop drivers compatible with XP. Can you pls guide me how & where to find these drivers....Dell does'nt have those drivers anymore (outdated) Pls...
Apr 04, 2008 | Computers & Internet
FP567s Ver.2 ON/OFF
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
Jun 07, 2007 | BenQ FP567s 15" LCD Monitor
BenQ FP567s 15" LCD Monitor Logo
87 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
