Question about Dishwashers
The soap pump dispenser from sink is stuck anyway to fix it or should I just order a new one. The pump releases too slow. I soaked in vinegar. I think it is a delta
    Genius:
  • Dishwashers Master
  • 1,669 Answers
The idea of using vinegar to clean off excess soap is reasonable, but not the easiest way. First try hot water (the best solvent known). Next try using a lubricant such as CRC or WD 40 spray on the sliding parts.
Posted on Jan 20, 2013
Same thing, my sink soap dispenser doesn't seem to have enough pressure or something to dispense the soap..just get a little soap every pump.
The pump seal o-ring has gone or is going bad really common problem with all of these soap dispensers just buy a new one the parts and time to fix it are not wroth the time and money.
Mar 06, 2011 | Plumbing
I have a Grohe soap dispenser and it has quit working for me. It is as if it gets stuck after you push it down and it seems to leak the soap out of the bottom part of the dispenser getting soap all over...
Sounds like there might simply be old soap caked on the inside of the dispenser head and feed tube. Best thing to do is have a sink filled with HOT water and just put the head portion in there to soak for a while. This should loosen the old soap enough to either dissolve or at least get it moving again. You can also take what soap is still in the dispenser out and put in another container, taking time to rinse the container with hot water as well and then filling it with hot water as well to test the pump action of the head, again using this action to help clean the insides of the pump. Short of this doing the trick, it may just be time for a new one. Good luck.
Aug 26, 2010 | Grohe Satin Nickel Soap Dispenser...
Water is very slow coming out on hot side but okay on cold side. Teh rest of house taps work great.
Remove the cartridge and rinse it in another sink. If you have hard water, soak the cartridge in vinegar for a couple of hours.
Apr 05, 2010 | Price Pfister Marielle Kitchen Faucet with...
My grohe soap dispenser sticks. I cannot get it to pump. I've soaked it in vinegar to de-gunk it - what else to do?
You may be using too thick of a liquid in it palmolive is the worst to use in soap dispensers flush the head out with water if you remove the tube from it be careful alot of them have a ballbearing or spring inside or the unit is worn
Nov 15, 2009 | Grohe Satin Nickel Soap Dispenser...
Plugged dispensor of the liquid soap at kitchen sink.
soak it in hot water and try pumping it every so often,should loosen liquid soap.
May 25, 2009 | American Standard Contemporary Kitchen...
The spout on built-in chrome sink soap dispenser fell out
The only good solution here is to purchase a new pump.. Sorry
Kurt
Mar 21, 2009 | Home
Kitchen sink soap dispenser won't pump
soap may be too thick or pump tube may not be touching soap in dispencer. try pumping same soap from cup
Mar 08, 2009 | Plumbing
Soap dispenser leaks
You can fill these 2 ways.You can pull out pump from top,at sink , and squeeze soap in .Or you can unscrew bottle from under sink and fill, I'm thinking that your bottle is loose under sink, or the plastic neck has a hairline crack. Im not real clear on where the soap is comming from.Thankyou.
Dec 11, 2008 | Grohe Satin Nickel Soap Dispenser...
Soap dispenser pump pricefister
Here is the link to installing a Price Pfister Soap dispenser:
Soap Dispenser
Hope this helps!
Nov 23, 2008 | Price Pfister Home
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
