No signal on vizio smart tv from RCA portable DVD player using composite cable
Connected using composite red/white/yellow cable, switched tv input to composite input, turned DVD player on. TV displays "no signal" while DVD player is working properly.
  • 3,904 Answers
First try another composite cable. Those "in box" ones go bad all of the time. Hook up to another tv or with another style of cable (such as S video) and verify that all is truly working first. If these steps don't work message again.
Posted on Jan 20, 2013
thecritter
  • 29 Answers
SOURCE: I cannot get a signal on my Phillips 50
if you haven't unplugged the unit for 30 seconds, try that. otherwise, if that doesn't help, probably a board needs to be replaced. call phillips for service.
Posted on Mar 17, 2008
  • 52 Answers
SOURCE: LG plasma buzzing
Problem is probably with your cable box as you have confirmed that the set is working by using the dvd player, that is unless you have a bad cable for the cable box.
Posted on Aug 12, 2008
dsacco86
  • 1077 Answers
SOURCE: 50" Vizio Plasma reads "No Signal" on all inputs?
Well, your TV is still under warranty. That's the good part.
The only thing I can recommend without voiding the warranty is leaving the TV unplugged for 30min. That way, the TV can reset itself and hopefully correct the problem.
If that doesn't solve the problem, it's time to use the VIZIO warranty.
Here's contact info if you need it.
Technical Support
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Posted on Jun 17, 2009
  • 15 Answers
SOURCE: when using component cables(red, green, blue )
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
Posted on Feb 24, 2010
  • 114 Answers
SOURCE: Our 42" Vizio will not display/play sounds when
Hello
One board takes in the HDMI as well as the other signals. Sometimes part of the board breaks and that is what sounds like has happend in your case. This is a fairly common problem and most people tend to just live with it. Others sell thier tv and a few find the number of thier board to see if one is available on ebay or shopjimmy. If you are comfortable with electronics the board is not hard to replace.
Im sorry your HDMI broke....
I hope this helps
Posted on Nov 28, 2010
How do I connect DVD player to tv with yellow,white and red cables?
Yellow is the composite video signal , White and Red is the Audio stereo signal.
You will need leads that can connect to the DVD player for these signals and connect them to the video and audio inputs of the TV .
If your TV doesn't have video and audio inputs, you will need a modulator box to combine these signals and send them to the areal input.
Jul 14, 2016 | Televison & Video
Input/output drama
hello sir,,
Are u sure the red blue green chord signal is connected properly to the source of the signal?
thank u
Jul 12, 2008 | Philips DVP3140
Could you tell me the steps to hook up my vcr & my dvd players to my tv. And what cables and or devices I need to accomplish this task?
It will depend on the devices. Most VCRs will have composite and S-video outputs. For this you will need either a composite audio/video cable (3 RCA plugs on each end: yellow (video) and red and white (audio)) or an S-video cable and a separate audio cable. The DVD player will probably have component video or HDMI outputs, depending on its age. The component video requires a 3 plug RCA video cable (red, green, blue) and a 2 plug RCA audio cable (red and white). Some DVD players have composite outputs as well. However, this limits you to an SD video output and isn't recommended, unless your TV doesn't have any HD inputs.
If your TV has one each of the appropriate input ports or 2 composite video ports, you just need those cables, assuming you have no other devices that have filled the inputs. Always connect the devices with the TV and the A/V components off. Match the color of the plug to the port. If you mix up the colors on component video cable, you may get a black&white picture. Some newer TVs use an adapter dongle to convert composite or component video to single port on the input board. Again match the colors at the dongle and then plug in the adapter. If your TV has shared composite and component signals, use the HDMI port output on the DVD player, if possible, or get a Audio/Video switch, like this: http://www.amazon.com/Panlong-Switcher-Composite-Selector-Consoles/dp/B00KXVBB3Q/ref=sr_1_24?s=audio-video-accessories&ie=UTF8&qid=1440632814&sr=1-24 .
Please add a comment with the make and model of your specific TV, VCR and DVD player. I hope this helps.
Aug 26, 2015 | Televison & Video
How to connect Sony dvd player to onkyo TX-8511 receiver
The TX-8511 is an older AV receiver with only composite video inputs. Your DVD player may not provide this type of output as it's not capable of HD video. If your dvd player has a composite output with a Red, White & Yellow set of outputs, that will connect into the Video 2 inputs on the receiver. Your TV will need to connect up to the Video2 or Monitor output. You'll need a set of composite video cables with the red-white & yellow RCA type plugs.
Here is a link to the manual for this receiver:
Receivers Receiver Stereo Receiver AVR TX 8511 Onkyo USA
Mar 13, 2015 | Onkyo TX-8511 Receiver
Tv screen turns black and red when playing through pioneer receiver
Usually when I hear of solid colors that display on a TV, my first solution would be to change the cable. We know your DVD player is working as you connected it straight to your TV and you report no problems. I assume you are using a composite cable (red, white, and yellow) Red and White being the Audio and Yellow your video.
But since your player works...and your tv works under the same input, then the only other issue would be the output cable from the receiver or the actual composite input or output connector is faulty.
try a video game system in place of the dvd player through your receiver..if it happens again, then change the receiver's output cable...if it still persists then your reciever's output connector is faulty.
I hope this helps.
Aug 09, 2012 | Audio Players & Recorders
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Is i possible to connect a rca cable to the converter box from a dvd player and watch on the tv?
DVD players can have several outputs:
* coaxiable cable
* composite video (RED/WHITE for stereo audio, and YELLOW for video)
* component video (RED/BLUE/GREEN to video components, plus RED/WHITE for stereo audio)
* HDMI
TVs can have several inputs:
* coaxiable cable
* HDMI
Just use the correct tables to "match" the output to the input.
Feb 21, 2011 | RCA (DTA800B1) Video Converter
Have Sony KDL-40EX400 LCD TV, Sony STR-DH510 AV reciever, Sony DVP-NS57P dvd player. When connected to reciever using component connections the TV does not show a picture. I have seen this problem in a...
  • If I understand your question correctly you want to watch your DVD on your TV thru your receiver,
  • you need to connect either composite connections "Audio/Video Output " red/white/yellow RCA jacks or "Optic cable output" of your receiver
  • ( pls note that component to composite conversion is not possible on receiver ..use one type connection thru all the way )
  • to "Audio/Video input " red/white/yellow RCA jacks or "Optic Cable input" of your TV
  • than just switch to DVD mode on corresponding your RCA or Optic connection...
There you go..Your DVD sound and video both are on the TV..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Feb 06, 2011 | Sony DVP-NS57P
My dvd player only plays movies in black and white. When I watch tv, it's in color so I know its not the tv.
I suspect you may have connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables - the plugs and sockets are usually colour-coded red, green, and blue. COMPOSITE only uses one RCA type video cable - the plugs and sockets are usually colour-coded yellow.
If you connect the yellow video cable to one of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check your connections. Make sure you have not connected to any sockets - either on the TV or the back of the DVD player - under the heading of "COMPONENT" - or individually marked "Pr", "Cr", "Pb", "Cb" or "Y".
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV and the DVD player. I will then be able to assist you further.
Regards,
BElectric
Jan 14, 2011 | Insignia DVD Player with MP3 Playback/JPEG...
Televison & Video Logo
383 people viewed this question
Top Televison & Video Experts
