Question about MSI Computers & Internet
Ultra Gladiator and mother board - MSI Computers & Internet
    Renaissance:
    An user who is expert in 3 categories / brands.
  • MSI Master
  • 2,226 Answers
Go to ebay
Posted on May 26, 2014
2 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: mother board manual for Chiantech VNF4 Ultra
http://www.motherboards.org/mobot/motherboards_d/Chaintech/VNF4%2BUltra%2BZENITH%2BVE/
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Motherboard installed in computer case, (Processor to the Top, Ram Memory slots to the Right), the Front Panel header is at the Bottom/Right corner,
http://img.neoseeker.com/v_image.php?articleid=1773&image=24
Black rectangle of plastic with 17 contact pins. Top row has 9 pins, Bottom row has 8.
Notice that the Bottom row has a White triangle pointing to the first pin.
This triangle points to Number 1 pin.
Top row has 9 pins.
Starting on the LEFT side going across to the Right;
Pins 2, 4, 6, 8, 10, 12, 14, 16, and 18.
Bottom row has 8 pins.
Pins 1, 3, 5, 7, 11, 13, NO PIN, and 17.
A) Pins 1 and 2 are for the Green Button. This is also the Standby button.
Let's discuss this for a moment............
Myself I wouldn't connect to it.
B) Pins 3 and 4 are for the HarDDrive activity LED.
(Light Emitting Diode, so to call it an LED light is redundant)
Pin 3 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
C) Pins 6, 8, 10, and 12 are for an internal speaker. Used so the computer can generate BIOS Beep Codes.
Doesn't indicate which pin is for the Positive ( + ) wire, but with most motherboard speaker setups, Pin 6 would be for the Positive ( + ) wire, and Pin 12 for the Negative ( - ) wire.
D) Pins 5, 7, and 9 are for the Power On LED.
Notice there are 3 pins. This is used for a dual color Power On LED light.
Usually a Green/Yellow.
Pin 9 is for the Positive wire.
Two wire Power On LED? Positive wire goes to Pin 7, or Pin 9. I believe both to be a Positive connection.
Pin 5 I believe to be the Negative connection. ( - )
(I suggest connecting the Negative wire to Pin 5. Then connect the Positive wire to Pin 9. Not very bright? Put it over to Pin 7 )
E) Pins 11 and 13 are for the Power On switch.
F) Pins 14 and 16 are for a Reset switch, IF a Reset switch is used.
G) N/C for Pin 17. No Connection.
H) N/C for Pin 18. No Connection.
Here's the full review starting from Page 1 detailing the motherboard,
http://www.neoseeker.com/Articles/Hardware/Reviews/vnf4ultra/
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Aug 28, 2012
I am working on a KT3 Ultra CE MS-6380E ver.1 mother board. The original problem was that nothing run after I pushed the power switch. I thought the Power Supply went out so I replaced the power supply but...
Sounds like the board or processor has failed. You will have checked all the power connectors to the board? Usual fix is a new board, rather than trying to find which component on the board has failed.
manual
MSI MS 6380LE User Manual
specs
MSI KT3 Ultra2 Specs
MSI website details on the board
KT3 Ultra Ultra ARU Motherboard The world leader in motherboard design MSI...
Seems to be a problem board
Questions Answers for kt3 ultra ce ms 6380e
Jul 12, 2017 | AMD MicroStar KT3 Ultra Socket A ATX...
Looking to get new mother board because it went on fire, old mother bd was asus P5VD1-X HAVE INTERL P-4 CHIP AND DDR 400 MEMORY THAT I WOULD LIKE TO KEEP USING WHAT MOTHER BOARD DO YOU SUGGEST
Better to purchase new mobo, cpu n memory. Bcoz the compatible Motherboard for your CPU/Memory is no longer available. If it is available, only from the dead stock or refurbished. Better to purchase new motherboard/cpu/memory
Sep 17, 2010 | VIA Asus P5VD1-X PT880 Ultra Chipset 1066...
P4X400 motherboard bad are there any replacement boards avalable?
Any motherboard with the same FSB speed and a Socket 478 should do.
Check out eBay:
http://shop.ebay.it/items/mother-board-socket-478_W0QQ_nkwZQ7bmotherQ20boardQ20socketQ20478Q7dQQLHQ5fAvailToZ101QQ_armZ1QQ_armmZ63QQ_ruuZhttpQ3aQ2fQ2fshopQ2eebayQ2eitQ2fitemsQ2fmotherQ2dboardQ2dsocketQ2d478Q5fW0Q51Q51Q5fnkwQ5AQ517bmotherQ5120boardQ5120socketQ5120478Q517dQ51Q51Q5farrQ5A1?_rdc=1
Unfortunately the Soyo P4X400 seems to have a FSB quite long in the tooth: from 100 to 133 MHz.
http://active-hardware.com/english/reviews/mainboard/p4x400-dragon-ultra.htm
You might be forced to upgrade the onboard RAM.
Oct 27, 2009 | Soyo P4X400 DRAGON Ultra Socket 478...
Have athlong xp 2500, shuttle an35n ultra mother
I think that you might be asking about latency timings... Try downloading NVIDIA's Performance software. If you search google with those two words you will likely find it. When you install it, look for system settings and whatever you can change there, will be all that your MoBo allows you to change.
Oct 02, 2009 | Shuttle AN35N Motherboard
Hard Drives -ATA and SATA
Yes, they can coexist.
May 17, 2008 | Computers & Internet
Shut down
did u check the memory card clean the surface if its ok contact a chip level engineer because u might have problem with ur power section in ur mother board
Oct 22, 2007 | DFI LANPARTY NFII ULTRA (LANPARTY NF2...
Computers & Internet Logo
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
