Question about Clarion EQS746 Equalizer - 7-Band In-Dash Rotary Equalizer with Subwoofer Crossover Auxiliary Input Car Equalizer
Back rear speaker wont play when singled out. more details inside
I have a cd player with 3 preouts, and a 4channel amp. i got this clarion eq746 installed. my rca's are run directly from the amp to the eq out slots and one rca coming from the cd players front pre out to the EQ's main in slot. if i balance all the way to the right using my radio and fade to the rear both left and right speakers play. but if i balance to the left and fade to the rear no music will play out of either rear speaker. why do both speakers play when only the right rear should be playing? also why doesnt the left rear play at all when it is singled out with fade and balance? but when everything is set to zero (balance and fade) all 4 speakers work. i am not using any Y cables or splitting any signal. i am running a set of 4channel rca's. is something on the inside of my eq getting the rear left and right signal confused? what could be causing this?
i have been in car audio for years. everythign is hooked up as should be. i did not use any short cuts here with the install. i just cant figure out why or how something like this could be happening? please help me out m1chae11ane123@yahoo email<
    Scholar:
  • 116 Answers
I would suggest you mdisconnect the rear speakers from the amp, take a 9volt battery and click te speakers on at a time. If proble duplicated, the you have the left speaker tied to the right somewhere.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
I need a wiring iagram for a 1980 clarion radio & CB for a honda goldwing can you help
clarion radio!!!!!!!!!!!!!!!!!!!!!
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
with the cb just connect the red and black wires upto the red and black on the radio then the cb wont switch on until u turn the accessories on
pls rate people arnt rating hope this helps
May 09, 2010 | Clarion DB245 CD Player
I need the diagram for a clarion touch screen cd /dvd player modle max 675vd11? does anyone have one so i can put into my car
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
Mar 21, 2010 | Clarion MAX675VD Car DVD Player
I need a wire diagram for a dxz745mp clarion car audio
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
pls rate people havent been rating
Apr 18, 2009 | Clarion DXZ745MP Car CD Player-Plays...
Clarion vrx 485 vd.tuner works with amp but cant get dvd or cd to play with amp.screen works cd an dvd are playing but no sound.an with key off tuners playing till i open door?what have i hooked up wrong?
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
it sounds like you have hooked the power wires up wrong try trace back your wires with this diagram
Mar 29, 2009 | Clarion VRX485VD Car DVD Player
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Problems with amp or stereo
check out www.installer.com
this site has your stereo's wire diagram.
The amp wires only go to the rear output (rca jacks on back of cd player)
It wont work right if it is connected to the front outputs on the back of cd player
Jan 16, 2009 | Alpine CDA-9856 CD Player
Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Oct 13, 2008 | Pioneer Audio Players & Recorders
Car audio
Yes you can use the speaker output in conjuction with the rca pre-outs...but depending on the wattage of the amp, there may be a big difference between the loudness of the front speakers over the rear speakers. If you have a 4 channel amp you can put the rear speakers on the amp also and lower the input gain for the rear speaker. Or if you have a 2 channel amp, you could use a passive crossover to filter out some of the bass to the rear speakers since they are smaller, this would help prevent over-driving them...as it is normally too much bass that distorts and blows a speaker. I'm not sure what you are asking about the hi-rear preouts vs the mid front pre-outs. If you decide to use the amp for the fronts you should be able to connect the amp from the front preouts of the deck. Hope this helps.
Mar 30, 2008 | Audio Players & Recorders
Clarion DB175 cd player
The Clarion manual lists 3 error messages.
Error 2-A disk is caught inside the CD deck and is not ejected.
Error 3-A disk cannot be played due to scratches, etc.
Error 6-A disc is loaded upside-down and cannot be played.
Good Luck.
Mar 26, 2008 | Clarion DB175MP CD Player
Car Audio & Video Logo
698 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
