L22w-7sd edid checksum
Dvi port of l22w-7sd gives bad edid, the only problem with it is that name of monitor stored in edid has one character wrong (last D) and because of that checksum is wrong.. and cause monitor not being detected by linux (dmesg shows bad edid checksum) and windows and display doesn't get activated without doing some kind of hack for ignoring/faking edid. is there a way write correct edid back to monitor. I tried powerstrip and edid-rw on linxu.. but it seem eprom is read only.. any way to get monitor to service mode/make eprom rw?
  • ivanoppulo Jan 20, 2013
    L22W-7SD is Fujitsu siemens monitor.
  • ivanoppulo Feb 05, 2013
    So I tried 2 different laptops and desktop (each having different graphic card) and various tools (powerstrip (win), edid-rw (linux) I could always read edid, but writing would fail. Finally I connected DVISVGA adapter to monitor and connected i2c pins to RaspberryPi and using "i2cdetect -y 0" I was able to get monitor i2c bus, and "i2cdump -y -r 0x00-0x7f 0 0x50" to dump edid, and finally "i2cset -y 0 0x50 0x78 0x44" to put "D" back where it should be in monitor edid.. evertything works now like it should.
3 Suggested Answers
  • 4 Answers
SOURCE: Primary display issue
Try going to Windows Safe Mode. You do this by pressing the F8 key repeatedly exactly after you hear your computer beep when it is rebooting. This should bring you to a screen that will have 3 Safe Modes listed, choose just plain Safe Mode by using your arrow keys to highlight Safe Mode and press enter. Once in Safe Mode, a box will come up asking you if you intended to enter Safe Mode, click Yes. You should now see your desktop, however it will look larger, and with less colors. This is normal.
If this mode did not allow you to get into windows, then reboot, press F8 like before and select Enable VGA Mode instead.
Now that you hopefully have a desktop, try this link which will take you to a video that will walk you through the process of setting up your DualView monitors. Also, note that there are some check boxes that allow you to select which monitor you want to be the primary.
I realize this video is specific Windows 2000, but the process is the same for Windows XP.
Hope this helps and Good luck!
Posted on Dec 23, 2007
  • 300 Answers
SOURCE: "No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Posted on Sep 14, 2008
How do i solve problem of power save mode?
that typically means there is no signal coming in to the monitor. You could have a defective dvi cable or dvi port. Try another PC with DVI output and see if it works. If SO, you have a bad dvi port on the pc. If NOT, try another cable. If you tried another cable and it still fails, you could have a bad screen. Check your warranty coverage if it is bad to see if you can get it replaced.
Oct 09, 2014 | Dell E2011H Monitor
How to add second monitor on ECS RS482-M
Doesn't work that way Max.
You can use EITHER the OnBoard Graphics,
the Add-On Card graphics. (Graphics card)
BIOS will NOT support both at the same time.
If you wish to use dual monitors, get an AGP card that has more than one graphics port on it.
For example, although I'm using a graphics card based on the PCI Express technology, and not AGP technology; my card has a VGA port, DVI port, and HDMI port.
1) VGA Connector;
2) DVI;
3) HDMI;
I use the VGA port, and the DVI port.
RCA EN-V L26HD31, (26 inch HDTV) to the VGA port.
HP 2009M 20 inch Widescreen monitor to the DVI port.
Had to install drivers for HP 2009M.
Let's say I had two DVI ports on the graphics card.
(ATI Radeon HD5450 is the graphics card I have)
But I have a monitor with a VGA cable, and a monitor with a DVI cable.
I would (And have) use a VGA to DVI Adapter.
One example,
Note that the DVI is Male, and the VGA is Female.
The graphics card DVI connector is Female.
The VGA Cable connector is Male.
So.............what is the manufacturer name, and model number of the graphics card; plus what type of monitors are you trying to use?
That is, what type of monitor cables do they have?
Know this;
My HDTV I'm using as a monitor is Digital. However I'm using a VGA cable on it. Best quality would be achieved if I got off my lazy rear, and attached a DVI Cable to it. It uses both.
VGA is Analog. A computer however puts out a digital video signal.
The computer has to convert the digital video signal to an Analog one. This slows the video signal down, and the quality is not as good.
Best to use a digital monitor. (Or a digital monitor WITH a digital cable. DVI Cable. Such as I need to do)
You are also using a PCI Express graphics card, NOT an AGP graphics card.
I'm wrong? OK.
In the meantime turn the computer off, unplug from power, and yank that AGP card out of the slot you put it in.
Tell me what expansion slot on the motherboard you put it in.
The Orange expansion slot on the motherboard, is a PCI-Express x16 slot. Uses a PCI Express graphics card -> ONLY
The white expansions slots are PCI.
Can use a PCI graphics card. CANNOT use an AGP graphics card.
Post back in a Comment.
Feb 18, 2013 | DFI 661GX-MLV SIS661GX CHIPSET SOCKET775...
I have an HP m9000z that was previously used with a DVI cable/monitor. I only have a VGA cable/monitor and the pc doesn't access the monitor.
This PC has a VGA and a DVI ports? Are both ports on the motherboard or a Video card? Or is the VGA onboard video and DVI is a Video card? You may have to disable the DVI port to get Video to vga or enable the vga port.
Jan 13, 2018 | HP Pavilion Elite M9000z PC Desktop
Hi - I have a shuttle xpc sxh57 core i7 model. A couple of days ago - it stopped sending a dvi signal to the monitors. I have replaced the video card, tried clearing the CMOS and cleaned dust. The fans and...
I suggest try the HDMI connection on your machine and see if its able to give display, since you purchase a new Video Card I assume it have a HDMI port. Or try different monitor with a DVI port if you really want a DVI connection, If it works it means the DVI port on your monitor is faulty.
Hope it helps.
Apr 20, 2011 | Shuttle Computers & Internet
How do you connect LG W2261 VP Monitor to HP Pavilion 6310uk Desktop
The computer has VGA, DVI-I (dual link) and HDMI ports. The monitor has VGA, DVI and HDMI but only came with a VGA cable. Some computers have recently come with shielding covering all of the ports except the one that is currently live. Thus, check your hardware; the computers I've seen with only one active port, the HDMI port was active before resetting the video options. So get an HDMI cable (it will provide the best signal in addition). If the DVI-I port is currently live, you should get that cable as well and then change the settings to enable the HDMI port.
I hope this helps.
(you do not need to get the super-expensive cables; the low end ones will be fine. However a single link DVI cable is not the same as a dual link cable; sometimes using the wrong cable leads to no signal to the monitor.)
Oct 12, 2010 | LG W2261V 22" LCD Monitor
Dvi-dvi connection to a ati radeon hd4670 does not recognise monitor,ie no display. Using a supplied adapter dvi-vga and a vga cable their ia screen display but in device manager it is a generic monitor?
Was there an installation disc that came with it in the package? Some monitors require software to be used. If you don't have the installation disc, you will most likely find the necessary software on the manufacturer's support site: ProLite Support Driver Download Site.
If the monitor software doesn't solve the problem, try using a different DVI cable. More often than not, these types of problems can be traced back to a faulty cable or port. If the DVI port on the monitor is bad, you will have to use the VGA port as you are now or replace the monitor.
If the DVI port on the video card is bad, you will need to replace it. A good way to test this is if you have another monitor with an available DVI port you can connect to the video card.
Hope this helps! Good luck!
Aug 10, 2009 | iiyama ProLite E481S-B 19" LCD Monitor
How can I use my apple lcd monitor (model m7649) to my dell
here you need to do:
1) you need find a video card with a DVI port and analog output ports, upgrate this card in your destop if you can not find a DVI port at your destop.
2). then you need buy a ADC to DVI adapter because your monitor ADC port is a digital port. you may reference here:
and you can buy the parts at:
hope help you fix it. please take a rating let me know huw much helped you thanks!
May 19, 2009 | IBM (14R0060) Monitor
Running two external monitors
Okay. Thanks for the info too...
I looked at the user's guide for this laptop and see exactly what you're saying.
I found it here:
So, the laptop comes with a DVI to VGA adapter because the only port on this system that will allow you to connect an external display is one that connects to a DVI port (in short, you don't have a VGA port).
moz-screenshot-3.jpgmoz-screenshot-4.jpgOkay, you have a couple of options here:
  1. You can purchase a docking station which, depending on where you buy it from, will be more expensive than the other options. If you decide to purchase one, first make sure that it will provide the ports that you need. For example, my docking station has one DVI port and one VGA port. If and when I connect a second monitor, I will connect it to the DVI port using a single DVI to VGA adapter (as I don't have any flat panels that connect directly to a DVI port). 63efdf2.jpg If you purchase the docking station, make sure it has both the DVI and VGA or you're stilling floating up the same creek without a paddle.
2. You can't use the cable that came with the laptop because it only connects to the DVI port
of your laptop with one VGA connector on the other end, therefore, supporting only one
external monitor. You need either a DVI to DVI and VGA adapter or a DVI to VGA and VGA
This is a DVI to DVI and VGA adapter
This is a DVI to VGA and VGA adapter
Okay, now that we covered that information, let's get down to business...
Since you already have your monitors and probably don't want to spend $200-300 on a docking station, this is the best and quickest solution:
You have two monitors both with VGA connectors. Your laptop has 1 DVI port on its side (correct?).
Look at the image of the DVI to VGA and VGA adapter. You need to purchase one of these. It will allow you to connect one end to the DVI port on the laptop and connect your monitors to the two VGA ports on the other end...viola!!
You can use the DVI to VGA and DVI adapter but it would complicate your situation unless you were trying to connect a VGA and DVI monitor so we can eliminate that option unless you are desparate and that's the only adapter you find to purchase.
These adapters are very inexpensive (probably anywhere from $9 to $19. You should be able to purchase them at a store that sells computers, hardware, software, etc. You may even find them at Wal-Mart or RadioShack. If need be, you can purchase one online. However, if you go out and search a couple of stores or computer places, you should find one and be able to connect your monitors when you get home.
Feel free to leave any comments if you need further information.
Thanks for using Fixya and don't forget to rate this solution.
Apr 03, 2009 | Apple MacBook Pro Notebook
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
