Question about Pioneer Vsx 921 K Av Receiver Black
Automatically powering off - Pioneer Vsx 921 K Av Receiver Black
    Genius:
  • Pioneer Master
  • 1,054 Answers
May be the amp is shorted. Try disconnecting all speaker wires from the unit. If it still turns off, then it needs to go in for repair.
Posted on Jan 21, 2013
Replaced battery, now auto windows wont come up auto automatically
If on a GM car the battery has been disconnect the windows may need to be reprogrammed
The following steps explain how to program the side door window regulator motors:
  1. Press and hold the power window switch until the window is fully DOWN. Continue holding the power window switch for approximately 3 seconds.
  2. Press and hold the power window switch until the window is fully UP. Continue holding the power window switch for approximately 3 seconds.
  3. The power window regulator motor is now programmed for the express function.
  4. Repeat this process for all of the power windows.
Dec 01, 2015 | Cars & Trucks
Trying to check which fuse is for the power antenna
What fuse disables the Automatic Antennae? - Toyota ...
www.toyota-4runner.org/.../70614-what-fuse-disables-automatic-antenna...
Aug 25, 2010 - Is there a fuse that disables the automatic antenna? ... For the price of 1 toyota power mast you get a whole assembly and it won't break again.
power antenna fuse location? - Corvette Forum
Nov 28, 2015 | Cars & Trucks
HOW DO I install a 3 phase generater to an mcc to automatically change over to generater power in the event of a mains power failure?
You would need a three phase automatic transfer switch.
Your local electric company usually requires you the have these automatic transfer switches install by a license electrician.
Dec 03, 2014 | Electrical Supplies
IN104 automatic shutdown
Hello, my infocus in104 will power up for a while (1- 5 minutes) when connected to the power supply and turned on, after that it automatically shuts down. Power button does not light red when it automatically shuts down and need to be unplugged for a minute or more before red power button will light up again.
Mar 21, 2013 | InFocus IN104 Projector
What voltage should be read on each pin of the power adapter?
hello ,, this information is based on ScanJet 5400C - (C8517V) -- if yours is other p/n, let me know
North American use , C8517-84200, Low power AC power module (Wall Mount Type) - 100-120VAC, 60Hz - Detachable power cord not needed (USA, Canada) - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
European use , C8517-84201, Low power AC power module (Wall Mount Type) - 200-240VAC - Detachable power cord not needed (Europe) - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
Worldwide use , C8517-84201, Low power AC power module (Brick Type) - 100-240V input - Requires a 3-wire detachable power cord - For worldwide operation - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
i hope thsi helps -- if it does, please rate my service
Nov 13, 2010 | HP Scanjet 5400c Flatbed Scanner
How to set the power reserve on timex automatic
Power reserve can not be set, as this is mechanical feature in watch which works along with watch winding. As soon as the watch is wound, the power reserve automatically is engaged and the indicator is showing how much power is left. Fully wound watch will show maximum power and completely unwound watch will show no power at all. All explained is for automatic and manually wound (spring driven) watches only. Rate me, plz.
Feb 25, 2010 | Timex Watches
Does not run. does this watch have a battery in it?
There are two types power sources for watches. Automatic and battery.
Automatic needs to be either wound by the crown (winder on the side) or wound by the movement of the wrist while it is worn.
The battery powered is self explanatory.
Since you didn't include the model it's difficult to say for sure because Relic makes both automatics and battery powered watches. Although I can tell you is most automatics will clearly labeled. If your watch say automatic somewhere on the face or back you need to contact Relic for service because your watch has a 12 year warranty.
To prevent violating your warranty a jeweler should be the one who replaces the battery if it is battery power.
I included the link to Relic watches below for info on the warranty and instructions.
Hope this helps.
http://relicbrand.com/
Nov 13, 2009 | Relic Multifunction Watch
Automatically rebooting computer after power failure
The bios settings turn the computer on automatically. I actually have mine set to turn on automatically in the morning before I get out of bed so it's already on when I get up. Watch what you see on your screen as you boot up the computer and do whatever it tells you to do to boot up in bios (typically by hitting the F2 or Del key). Once in bios, go to the power section. In the power setting you should see something pertaining to the modem. If you do NOT want it to power up automatically, choose the Disable option. If you DO want to power it up automatically, it will also ask for a time (day of month, hour, minute). If you set the day as 1, for example, it will power up on the 1st of the month at the time that is set. If you set the day of the month to zero (0), it will power up every day at that time.
Oct 02, 2008 | Compaq Presario SR1000T (568657) PC...
Automatic power on
Hi
I do not know why you need the automatic power on for your server. Server should be on all the time 24/7 .
If it is a PC , then you should know that even though shutdown , they are still on (you can see a light) .
This means you can use magic bullet to wake it up (wake up on lan).
Read up on magic bullet.
Good luck,
David
Jun 11, 2008 | Dell PowerEdge 1600SC Server
SYSTEM WILL BE POWERED OFF AUTOMATICALLY
while installing windows, your computer will restart automatically after a few minutes, wait untill it restarts and press press anything
Mar 02, 2008 | Compaq Armada E500 Notebook
Pioneer Vsx 921 K Av Receiver Black Logo
67 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
