Question about Kenmore Washing Machines
Won't stop washing
Won't drain or spin. just keeps washing cloths
  • 367 Answers
Generally this is caused from a bad timer motor. The timer motor makes the washer advance through the different cycles. Replacing the timer should fix your problem.
Posted on Jan 22, 2013
dh1200s
  • 335 Answers
SOURCE: washes but won't spin or drain completely unless no clothes in
Hello screenman780
I will assume you are taking dc or UC errors to the display in spin cycle. Just need the first two digits of your machine serial number, ie. 10,12,16 etc. That information is located on the right back side of the machine console. If you are taking those errors I recommend removing the clutch inspecting the clutch roller bearings and clutch spring. There is a test to perform for the Tub Displacement Sensor that we could check first but 10 times out of 10… so far it’s the clutch. Most of the time a cleanup with WD-40 and re-lube of the clutch bearings with some light bearing grease will get you back in service. If the clutch bearings are rusted up beyond clean up or the clutch spring is broken then a clutch replacement will be required. I recommend this clutch as a replacement. I put that clutch in my machine (1st two digits of my s/n are 16) just to make sure it would work, my original clutch was cleaned up with WD-40 alone and worked as the day delivered on 7/05. Take a look and read thru the post in the link below. In that post I go thru a step by step process to replace the clutch (comment of 3/18). I can also offer some phone support no charge; I'm a DIY'er owner of the machine. I believe the repair cost (from previous post on this forum) to replace the clutch and labor will be around $300 if you don't DIY the repair/maintenance for this issue. Most of the clutch malfunctions are resolved with the clutch maintenance. Anyone can do this with only basic mechanical skill sets. If you can change the spark plug on a lawnmower you can deal with this, the work area is just tight. Here are some folks that had positive results with this maintenance. Unfortunately I feel many of these machines end up at the curb for bulk trash pickup when a $10 fix for some WD-40 a squirt of bearing grease or worse case a $50-$60 new clutch replacement. Good Luck and let me know if you need additional support, Rich.
http://www.fixya.com/support/t527875-maytag_neptune_tl
Here are some folks that did this maintenance with positive results.
Positive Fix1/19
Positive Fix 1/18
Positive Fix 3/4
Positive Fix 3/4 different Forum
Solution #4 posted on Mar 17, 2009
Posted on Mar 27, 2009
SOURCE: washes until it's ready to drain & spin, but does nothing.
I see someone has same problem on another Whirlpool model.
Whirlpool lsq8243hq.
The washer goes through the regular motions until it is ready to drain/spin and then it stops. I have reset the dial & it starts up again until it gets to drain/spin cycle. I've tried opening & closing the door. Nothing, it keeps stopping at the drain/spin.
I fiddled around after reading about the plunger on the lid and the lid switch. I am guessing that it is the lid switch? but not sure if that is what the part is called but here is how I get the machine to work. I propped a screw driver into the slot where the plunger would go and the screwdriver pushes against something & the machine works fine. But if I close the lid without the screwdriver in place, the plunger does not start the machine. I notice tiny clicking noises in the machine when using the screwdriver (probably always does it but never heard it with lid down) to as the machine goes from wash to drain/spin mode. I just had a repairman replace coupling ($96.00) 5 months ago.I am hoping that this repair is something minor and I can do it myself. a diagram would be very helpful if available. Thanks in advance. Y'all told me my problem last time in a matter of minutes. You do a great service!
Posted on Jul 10, 2009
  • 215 Answers
SOURCE: Spin cycle won't work. Wash works OK.
sounds like motor brushes may need replacing.
Posted on Feb 17, 2010
hh0405
  • 77 Answers
SOURCE: I have a Roper top load washing machine and the
the washer needs to have the lid closed to go into spin cycle the lid switch is broken just replace it and that will fix it
Posted on Apr 03, 2010
SOURCE: We have a Fisher &
Try draining it manually, if that does not work you may have a blockage, theres a good video fix on you tube
Posted on May 19, 2011
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Hi, I have model wfw8300sw04. I'm having trouble with it spining & draining. It won't drain and it spins once and stops. I have check the drain for any clogs and nothing.
Open the door and push the bottom front of the boot aside and look to see if an article of clothing as gotten in there. Post back your findings.
Nov 13, 2012 | Washing Machines
Won't final spin ?
What is the model number of your unit?
Nov 04, 2012 | Washing Machines
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
Washer doesn't spin out sometimes
you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
May 07, 2012 | Washing Machines
Won't fully spin and alarms nd as a code
You may want to check your drain to be sure there's not a clog/partial clog when draining out the water. Also, you may want to check the filter and possibly clean it. A partially clogged filter may cause this problem. And, you might try...turning off the unit for 10 seconds and turn back on...select Spin Cycle...press Start/Pause to drain the water. Good luck and hope this helps.
Walt
Apr 26, 2012 | Samsung WF218ANB 4.0 Cu. Ft. Front-Load...
My machine does not spin the clothes out like it should. I have to put on spin again before the clothes come out like they should. What could be the matter?
mine was doing that too...eventually you'll end up replacing the drain pump motor cuz one day it won't **** out any of the water and blink and beep and stop on ya hope this helps!
Sep 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Machine won't go in to spin and cloth stay wet
Hi alvism,
The drain pump may have something clogging it up, or obstructing the pump impeller, easy fix, see my Tip below:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards d')
* If you found this solution helpful, please rate it.
Jul 21, 2011 | Malber P21 Front Load Washer
My washer won't spin. It stop and gave me a warning "UE". What is this mean. Please help me.
I have a LG LNC6753A71 the washer agitates drains rinses but won't spin. The motor runs but it won't spin.
May 01, 2011 | LG WM0642H Front Load
Washing Machines Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
