Question about Samsung HCN553W 55" Rear Projection Television
Diagonal lines on my screen(samsung 55" projection HDTV hcn553w)
Hello there I just bought a Samsung 55" HDTV monitor model #hcn553w.. the issue that Im having with this is that the color seems to be off.. only on certain things though. The main problem that Im having is that there diagonal lines constantly on the screen. I dont know a whole lot about these kind of TV's but I was told that it might have something to do with the converting. I guess Im looking for any type of information that can steer me in the right direction. Now this does this on everything.. TV, DVD, PS2.. it does not matter what is playing. Thanks BJ
  • 3 more comments
  • Bryant lentsch Jul 16, 2007
    No nothing changed.. I did pull the back off and tried to adjust each color and the lines would somewhat clear up.. but then I would lose all focus. So I tried to use the auto focus and the three little adjustments that are inside the front panel.. nothing would work. Although I do have a better picture, I had to focus the back projectors back to the point where the lines would come back. All in all the lines never totally disappeared.
    I will try but I dont think that it would show up.. the lines are fine.... but I will try to see what I can do.. Im guessing its goin to be one of those things that a tech will have to come out to the house.
    this is the best that I could get... the lines are always moving. they kind of do a zig zag on the screen.
    http://i25.photobucket.com/albums/c74/bl..." class="h_mi" />
    This is the best I could get.
  • madridista Jun 12, 2008
    I have the same problem or may be a similar one. There some colored diagonal lines appear on the screen when I play for example a 3D game or see some photos with high resolution. I really don't know what to do?
  • 944 Answers
Here's the link to the user manual; http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=32370&CDCttType=UM&ModelType=C&ModelName=HCN553W&VPath=UM/200310/20031002105141187_P55A_00054A_0410.pdf Check page 28 and 29 for convergence instructions. Give it a try to see if it makes any difference. Check page 27 for the "perfect focus" feature and see if that helps. Could you take a photo of the "diagonal lines" on the set and post it - might help? If you open a menu on the screen, does it also have the lines across, or is it clear as normal. Check page 64 for how to run the demo, and try that. Have you recently unplugged the set from the mains power supply, left it for at least 15 minutes (preferably two hours) then turned it back on? if not, try it and see if you get any change. Check page 38 for the usual video settings - play around with them and see if any significant change? Check page 39 and set the "automatic picture setting" to standard, if it isn't already, and something else if it is - see if you get a change. Check page 40 for the colour tone adjustment - probably won't change anything, but worth a play in case. Check the bottom of page 46 about channel fine tuning - reset at least a couple of channels to 00, see if that makes a difference (long shot). Does the screen itself need cleaning? recommended is just a clean dry cloth - basically have a good close look at the screen when it is both on and off, to see if there are any marks that might be causing the problem - in particular has it possibly been cleaned with a solvent or too aggressively cleaned in a diagonal direction? shine a light on it at a few angles to check, and look from a few different angles too. Check by moving or turning them on and off if any other electric or electronic items near your tv may be causing the effect - speakers perhaps. Move speakers to check. A way to check other items is to totally cut off the electric supply to the whole house for a couple of minutes, except one circuit into which you can plug the TV and a picture source. See if you get a perfect picture - if so, start switching circuits back on 1 by one until it changes. Hope this helps - I think a photo would help a lot :)
Posted on Jul 16, 2007
  • 1 more comment
  • Nigel Ridehalgh
    Nigel Ridehalgh Jul 16, 2007
    PS Do you have a lot of humidity? If so see if you can get a dehumidifier for a couple of days and see if it makes a difference (also long shot).
  • Nigel Ridehalgh
    What results did you get from trying any of the above suggestions?
    Any chance of a photo?
  • Nigel Ridehalgh
    Sorry couldn't take your chat - was in the middle of something - a photo of what you have now willn hopefully tell a thousand words :)
I have diagonal lines on the picture of Samsung HLM50
Most likely bulb is not in correctly or a issue with the optical light engine this set uses
Nov 29, 2012 | Samsung HLM507W 50" Rear Projection HDTV
SAMSUNG DLP HLN5065W HAS DIAGONAL LINES ON SCREEN, LINES ARE NOT PRSENT ON THE pip SCEEN
Look for Bad capaciotrs on the board on left hand side up front most of the time this will be your problem they will be swollen or puffed up on top. If you need any more help just let me know Thank You.
Aug 13, 2010 | Samsung HLN5065W 50" Rear Projection...
The picture seems to be sliding down the screen of my Samsung HCN553W, I can still watch it except for the top 4-5 inches in the top left corner, it's black. Does anybody have any idea what it could be?
Ur tv it beginning to create and will develope a simtom call "Convergence alignment"These problems will delope in to the picture will have shades of colors like red or blue shadows,the picture bows in coners and colors will misaligns,the picture look like u watching a 3D movies,and the tv sometimes,just die and making chirpings sound.This problems very common in DLP tvs,it will develope just sonner or later that all.The covergence problems,the only way to fix are to take the tv aparts take out the Pc board call The Convergence board.Change the 2 STK convergence ICS,and some or all it supporting resitors and pico fuses.
May 06, 2010 | Samsung HCN553W 55" Rear Projection...
HI, I am having Samsung 29' tv, TV screen has moved to left side, when i click on menu it displays that hotel mode, can u please help me in this manner. Thanks in advance, Ismail
turn the television into standby.
with the remote press the following.
INFO, MENU, MUTE then POWER this will bring up Samsung hidden menu where you will be able to disable the hotel mode option this will allow you to sort the screen out and other options
hope this helps
Little Dish Fitter
Feb 21, 2009 | Samsung HCN553W 55" Rear Projection...
Diagonal lines through the picture of Samsung DLP set.
Poor solder connections, resolder convergence ICs or you may beed to replace them.
Dec 27, 2008 | Samsung HLN5065W 50" Rear Projection...
Diagonal lines through the picture.
I've found the lines caused by the digital board before. Unfortunately it is expensive. I'd recommend running it on HD and it will bypass the faulty circuit. The lamp light flashes telling you the lamp is firing up. As the lamp ages, it will take longer and longer until it fails.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Diagonal lines on a Samsung 46" TV
picture is ok /converg.-ok/;diagonal lines on screen; looks like waves.Appear on tv and video modes.I observed same problem on some another tv in my practic,but this case is worse.
Sep 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HCM553W 55 in. Rear Projection Television - image duplicated
Hello, I am a Samsung TV repair man. What happened was one of your bulbs in your tv has burnt out. you have to contact your samsung repair phone line. how old is that tv? do you have a warranty? if you do, it might be repairable for free. I hope this info is useful!
Apr 20, 2008 | Samsung HCM553W 55" Rear Projection...
Green screen crash
i have a projection tv. It is a a Samsung HDTV 55" widescreen. There is a green curvey lines at top of screen. Can you help?
Jan 20, 2008 | Televison & Video
Samsung HCN553W 55" Rear Projection Television Logo
1,556 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
