Question about Echo 2-Cycle 28.1 cc Straight Shaft Gas Trimmer SRM-280UC
Have a ECHO gas trimmer SRM 2100 wont start. coulld it be the fly wheel
    Sergeant:
  • 322 Answers
If it doesn't turn over when you pull the rope it could be in the starter assembly or the flywheel where the starter pawls engage it. If it turns over then you need to check for fuel, spark, air and compression.
Posted on Jan 23, 2013
  • 32 Answers
SOURCE: How can I remove Echo 230 SRM trimmer head?
on the head there is a u shape slot on the side. turn it until you can slide a small screw driver in it to lock the head. then loosen the nut on the bottom i do believe it is a left-handed
Posted on Jul 23, 2009
  • 7 Answers
SOURCE: Echo SRM 1501 trimmer has minimal fire. Feels very
If this is a solid state ignition ( black box mounted right next to the fly wheel)check for rust on fly wheel and coil/ignition.Sand with light grit sand paper if nessesary. Make sure to reistall with the same gap between the two parts.note the gap at this point could also be wrong.Also check to see if the clip inside the boot where the spark plug conects is not bent and that it is conecting properly. If this is a points ignition system then its basicaly the same steps.Clean contact pionts check plug boot for good contact. Or could be bad coil.Be sure you are using a plug with the propor heat range.
Posted on Jun 08, 2009
rycgl
  • 1545 Answers
SOURCE: My echo srm 2100 weedeater will start, but when I
There are an array of things that could be wrong, but most likely this is a carburetion problem.
For starters, make sure the fuel lines are soft and there are no cracks or pinholes in them. They tend to break down after time. I don't know the age of this machine, but a gasket and diaghragm kit may bring it back to normal operation. The parts in this little kit are easy to install and not very expensive. Another issue of note is there is a very fine mesh screen inside the fuel pump chamber of the carburetor that traps dirt and foreign particles. It is easy to access and clean, once you have the pump cover off. The internal parts of the carburetor need to be soft and pliable like the fuel lines to operate correctly. They dry out after time and need replacing. All these little carbs have this issue at some point in their usage. If you remove the carb, gaskets and diaghragms, try spraying all the holes with carb cleaner aerosol spray after cleaning the fine mesh screen. If a good cleaning doesn't help, then you probably need the gasket and diaghragm kit for that carburetor.
Posted on Oct 10, 2010
#1 Taper
  • 1040 Answers
SOURCE: engine starts finem, but will not reach fill RPM.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
  • 1126 Answers
SOURCE: i need an instruction manual for echo srm 225 weed
http://www.echo-usa.com/documentation.asp?Model=SRM-225&lang=E
Hope this link helps.
Posted on Sep 08, 2009
How to check fuel needle setting in Echo 2100 weed eater
Jack, Check the attached links for trimmer carb. tuning,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Tune Up an Echo Trimmer
http://www.echo-usa.com/getattachment/e8f287f6-0f5c-4f36-b0fa-ea8fa4a550b9/SRM2400241025012501S2510es_120194
echo srm 2100 weed eater
May 07, 2016 | Echo Garden
SRM 2400 trimmer. Why doesn't it start?
Ralph, if you are getting fuel, spark and have compression , I suspect the muffler screen is plugged. Check the attached links,instruction and guides, Good luck
Small Engine Repair Cleaning Carbon Buildup on the Exhaust Port Muffler on...
Echo trimmers and loss of power EXHAUST PORT CLOGGED
Symptoms Repair Of Clogged Spark Arrester On Grass Trimmer
My Aunt Echo PB 2100 Blower with Clogged Spark Arrestor Screen
Apr 17, 2016 | Echo Garden
Echo srm 225 manual
Smoke generally means you have too much oil to fuel ratio in your mix. Mix per manufacturer 50/1 exactly and try again.
Sep 02, 2014 | Garden
no not fly wheel maybe coil if not sparking check switch fist is on for sure or bad plug coil expessive try squrying some starting fluid in the carb check compression has to be above 90lb to start check and see if carbon has block exhaust port do all this first
Jan 20, 2013 | Echo 2-Cycle 28.1 cc Straight Shaft Gas...
ECHO SRM 2100 GRASS TRIMMER HAS NO POWER
For all others with String trimmers, blowers and other 2 stroke style engines...
If no power on high, tends to bog, won't run once choke off, check these:
  • Fuel Filter - It's IN the Gas tank; Just replace it
  • Spark Arrestor at Muffler, it's a screen that tends to clog up and causes very restricted exhaust flow
  • Spark Plug - again just replace it
  • Carburetor, clean or install rebuild kit
  • And adjust sorta hidden High/Low carburetor adjustment screws
Take a look here...
And here:
And one more...
Aug 10, 2012 | Echo Garden
Carburetor is probably gummed up inside. There are very fine needle-thin holes in the spray nozzel through which gas has to flow. if they are gummed up, you will have an engine that starts, but has no power. try to take the brass nozzel out of the bottom of the carburetor, it unscrews & may be kinda tight. but take it out & clean the smallest holes with a thin piece of wire. should work great after that.
Aug 10, 2012 | Garden
On my echo srm-2100 what length should the 3 lines be?
Check out the manuals on their website. They are all posted there. Or maybe check their FAQ section: http://www.echo-usa.com/faqs/
Jun 06, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Engine starts finem, but will not reach fill RPM.
Jim
Jun 27, 2009 | Echo Rapid Loader, Trimmer Head
Echo SRM 1501 trimmer has minimal fire. Feels very slight, will not fire thru plug
Jun 07, 2009 | Echo Garden
Echo 2-Cycle 28.1 cc Straight Shaft Gas Trimmer SRM-280UC Logo
513 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
