Question about Speed Queen " ATE50F Electric Stackable Washer Dryer with 8 Wash Cycles, 3 Dry Cycles, Energy Star Qualified in White"
Kenmore 110.88675810 agitates doesn't spin or drain, it only agitates
  • Peg Hubner Jan 20, 2013
    Thank you SOOO much, I truly appraciate the help you have offered!!!!
    Sergeant:
  • 291 Answers
Most likely the timer needs relaced.
Posted on Jan 20, 2013
  • 4 more comments
    THANK YOU!! It is my elderly neighbors washing machine. :-)
  • B.H. Countryman Jan 20, 2013
    This is the cheapest way to go: http://www.ebay.com/sch/i.html?_nkw=3946...
    Before purchasing a timer, check the drain hose between the tub and drain pump for a clog and verify that the drain pump itself is not jambed. The tub must drain before machine will spin. So it could be that simple.
    Also you can examine the timer and usually determine if it's bad by removing the plastic slide piece. Look at the leaf fingers with good light. Use a small pocket screw driver or equivalent to lift the fingers. You will see points type contactors. The spin contactor is usually on the far left and will have blackness around it. It is the hardest working contactor in the timer, so look for it to be worn down with a splashy look. Compare it to it's neighbor if you aren't sure. If it looks good, or pretty good don't replace it. Let me know, we will look for the problem somewhere else.
    Probably should have said unplug the machine and remove the timer to inspect it.
    LOL, okay, my neighbor isn';t home yet, when she comes home I will start investigating. You have been an amaIng help, thank you!!!! :-)
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
My washer fills, agitates but will not drain
Does your washer spin? If yes, and it doesn't drain it most likely a failed/plugged pump.
If it doesn't spin it could be a belt or timer issue..
Sep 15, 2011 | Maytag MAV2755AWW Dependable Clean Top...
My 110 20862990 kenmore washer doesn't spin, the motor runs, it drains, and the coupling is in good shape. On another DIY page it asked to turn the drive side of the coupling one way to see if the...
My washer was doing the same thing. I had a magic marker on the bottom of the plastic tub below the inner tub. The agitation cam could not release for spin. I remove the magic marker and she took off.
This video shows how to get the inner tub out:
More here
More here
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
The washing machine is not spinning and emptying.
The leading problem when your washer fills and agitates but doesn't drain or spin is going to a broken lid switch. This tip i wrote explains how to check for a broken lid switch http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
GENE
Sep 05, 2011 | Kenmore Washing Machines
Kenmore washer 90 series - 1/2 hour ago we replaced the coupler and clutch because it would not spin. Now, it spins great - if you manually set the knob to spin! It will not move through the cylcles...
the first thing to check is if the small appx. 3/8" diameter clearish rubber hose got disattached from the side of the outer tub espically if before replacing cluctch is didnt overflow
Aug 12, 2011 | Kenmore Washing Machines
I have a Kenmore 80 series Model # 11028812790. It was working just fine and then the next load i put in it would not agitate..... Please help 3 boys and NO clean clothes!!
if it still spins and drains and continues through cycle but doesn't agitate, problem is probably the 'dogs', about 5 to $10.00 for the parts. easy to replace for someone with even basic knowledge or handy-man ism
Jul 13, 2011 | Washing Machines
Speed Queen " ATE50F Electric Stackable Washer Dryer with 8 Wash Cycles, 3 Dry Cycles, Energy Star Qualified in White" Logo
82 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
