Question about Rinnai Water Heaters
Rinnai 2532 error code 10
The rinnai 2532 water heater is flashing error code "10". how do i fix that?
  • 3 more comments
  • Jeremy D Jan 20, 2013
    checked the vents. Connected correctly: yes,
    no blockages
    still doing the error code after 10 min of use and shutting off
    only showing error code "10"
  • Jeremy D Jan 22, 2013
    rinnai infinity 2532. the exhaust and intake pipes are fine and connected correctly with a down % grade to make sure condensation runs out
    Sergeant:
    Champion:
  • 282 Answers
Error Code 10 Problem: Reduced or no air supply to the water heater or there is an obstruction in extracting the flue gases out.
Solution: Make sure that the recommended Rinnai venting is used, there is no obstruction in the venting system, no reduction in diameter and lengths are per instructions. Also make sure that nothing blocks the venting system or fan, and that dip switch and condensation collar are set properly.
Good luck,
Marty
Posted on May 13, 2014
3 Suggested Answers
mrhotandcold
  • 248 Answers
SOURCE: rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Posted on Oct 31, 2009
  • 3 Answers
SOURCE: Our Rinnai tankless water heater is producing water as hot as pre
Power outage will reset Rinnai unit to that temperature. Read manual for more info.
Posted on Jan 26, 2010
I have a wall mounted tankless water heater for
It's scaled
Do you have a softener? Water must be 15 GRS/PPM or less in iron and calcium. Hot spots in unit are boiling water and are causing the noises.
Descale and flush unit following Rinnai Specs and check water hardness for compliance with Rinnai standards because too hard an inlet water will VOID the Heat Exchanger Warranty (10 year).
Oct 19, 2014 | Water Heaters
Rinnai 2532
You have an issue. The water heater is Kaput! Bad! No more! You need a new one!
Jan 17, 2014 | Water Heaters
Our rinnai R94LS will shut off after running several minuets and shows error code#10. I'll turn it off for several minutes and turn back on, run system for several minuets and it will shut off again and...
Tankless computer is not working.
Error 10 is blocked flue or inadequate air supply. Or failed PC motherboard, or failed sensor etc.
Get more fresh air to unit. Check if bird built nest on flue pipe. If flue exits side of house, look for obstructions nearby that can slow the exit of poisonous vent byproduct into the air you breathe. For example trash cans and boxes or parked car etc.
http://waterheatertimer.org/pdf/Rinnai-installation-and-error-codes.pdf
Call service technician who is qualified to work on tankless computer. This will be a well-seasoned veteran of computer technology and plumbing expertise ... a plumber who knows how to fix computers lol.
This person will catch unit up on required yearly maintenance, and check specialized operation conditions needed for tankless computers to function properly.
If tankless computer is older than 5 years, then compare it to your 5-year old laptop, and assume same level of glitches and problems.
Solve any tankless problem yourself, today, for $385 by installing tank type heater from local box store:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 29, 2013 | Rinnai Water Heaters
Keep getting error code 10 for our rinnai rl75 tankless water heater how can we fix this?>
Go to the manual or go on line for the manual and look up the code and its meaning.
Aug 14, 2013 | Rinnai Tankless Water Heater Internal...
I have a Rinnai Model 2532 with an MC-45-4US and BC-45-4US control units. I finished another bathroom and want to add a controller, but have been told that a compatible BSC-45-4US is no longer made. Is...
Sorry Ken I worked for Rinnai Australia as a service manager so treat my advice with a little cuation but you should find the basic universal controller should work fine. The code over here is a MC-91 Q2A. It will MC-91 sometihing for over there (I'm guessing from the codes you use you are across the pacific!). You can wire this unit either back to the heater or to wiring from another controller, just match the colours and link them in. Power off the heater first but it is all low voltage.
May 26, 2011 | Rinnai Digital Remote Water Heater Control...
How do I flush the Rinnai when I get the "LC" error code?
Do you have the isolation valves in place in order to do the flushing?
Jan 22, 2011 | Rinnai Webstone The isolator EXP tankless...
I have a Rinnai Continuum Model 2532 natural gas tankless water heater in my home. It takes about 45 - 60 seconds for the water to get hot at the faucet which is closes to the heater. This thing is...
clean filter on the cold side coming in and clean or replace the aerator at the sink, rinnai works on water flow, common problem if your water hardness to high or if you have iron in your water
Oct 04, 2010 | Rinnai Webstone The isolator EXP tankless...
How to install rinnai 2532 Continuum Individual temperature control
if you mean additional remotes then go to rinnai.com and enter your model number. go to owners manual and it gives step by step instructions
Jan 10, 2010 | Rinnai Webstone The isolator EXP tankless...
Water Heaters Logo
507 people viewed this question
Top Rinnai Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
