SOURCE: Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
SOURCE: I have a jenn-air gas range which is 4 yrs old.
There is a possibility that the burner is partially blocked,make sure the oven is off and cool, take out the shelves, get a torch, a pin, a small piece of emery paper (or brillo pad) and a matchstick.
Inspect the burner at the back of the oven (look at the holes) remove any debris with the pin or match stick, use the emery paper/brillo to clean the igniter (this is a white stick with a piece of metal sticking out near the burner) very gently clean the metal part.
Try lighting it, if it makes no difference it's likely that your FSD (Flame Safeguard Device) is faulty and not allowing the correct amount of gas through.
It's a fiddly job looking at that so i would highly recommend a 'Gas Safe' engineer take a look at it for you.
I hope this helps.
SOURCE: I have a Jenn-Air W130 electric range and the
HI. This error code is indicating that there are several issue that concern the integrity of the main oven control board. This damaged control board will need to be replaced asap. Once replaced, the unit will operate correctly.
SOURCE: Jenn Air Range Model 88370
It will be the oven element that has failed, a new one wiil need to be
fitted.
It is located at the rear of the oven compartment behind a removeable
cover.
I hope this helps.
