Did auto channel scan and still unable to watch tv
  • 3,904 Answers
If you are going straight from the wall to the tv you most likely will not get channels. You will have to come off of the box supplied by your cable provider. If you are coming off of a box currently then you need to make sure you tv is tuned to the right channel and then use the provided remote from your service.
Posted on Jan 20, 2013
MNfisherman
  • 11896 Answers
SOURCE: Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
Posted on Jun 22, 2009
Danmart
  • 291 Answers
SOURCE: can't get the channels to enter into the channel list
A lot of the " auto channel scan " etc. need a certain signal strength. you could have too meny tvs,equipment or anything connected to the "signal giver" that is sucking the signal strength.Not just turn off ALL connections to signal but disconnect the antenna 'input' to any equipment (sometimes people connect cable wires to radio receivers for stronger & better signals.)
You could have a open circuit to the input of the equipment in trouble.If you know how to get inside (with out killing yourself) connect an antenna directly to the end of the line of the intanna input INSIDE of the TV. if the signal comes in and the tv 'autoscans' and locks channels, then you have a open wire leading into the circuit.
p.s. BE CAREFUL!!, IF YOU don't know how or what you are doing.........DON'T DO DAT !! [that]
Posted on Nov 30, 2008
SOURCE: JVC LT 32E479 UNABLE TO SWITCH ANY CHANNELS
go to menu select TV settings select add a channel  In the scan boxes  type 1 and 3 or what every you have your Satellite set to  Then hit start scan  The TV will come on reset to channel 3.
Posted on Mar 29, 2009
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
emissionwiz
  • 78335 Answers
SOURCE: How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
Why does my Westinghouse tv display "auto scan required" when it is on an outdoor digital antenae and there is no picture
Auto scan programs the channels. Auto scan detects the signal strength of the channel and adds the ones that you can watch.
Sep 07, 2014 | Televison & Video
I cannot get the channel scan to recognize channel 3 to be able to watch directv
Make sure the direct TV is turned on and has a channel selected before running the auto scan. The TV won't see channel 3 if there is no signal there.
Oct 29, 2013 | Vizio Televison & Video
The tv keeps saying run auto channel scan
I have run the auto scan many times and it never finds any channel. I found that you have to put it on the HDTV, PC, AUDIO channels in order to watch or connect anything on the TV. Try doing that.
Sep 13, 2013 | Proscan PLDED3273A 32" LED 720p HDTV with...
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
Sep 25, 2011 | Dynex Televison & Video
If i am on either AV2 or AV4 watching either sky or a DVD the TV will then change itself to channel "00" automatically after a few minutes. I am then unable to change back easily if i do then it...
A newly designed LCD TV has various capacity functionalities. For example, AV 2 or AV4 are connection capabilities with DVD or VCR recorder device peripherals. Once any devices are connected to the TV, an auto scan is required to acquire adjustment of what is common expection whenever powered on. USing the TV remote control, perform settings fucntionalities to acquire the auto scan to acquire connection functionalities. For example, refer to the TV user guide or manual on setting the TV channels. For TVs that are connected to subscriber providers cable tv or dishnetworks, contacting technical experts would readjust the TV signal receptables to display media. good luck
Jan 08, 2011 | Sony KDL-32S3000 32 in. LCD Television
17 in. trutech tv unable to get channels except 2-13
For channel setup you will need to;
1) Connect the signal source to the back of the set.(Antenna or Cable)
2) Go into the TV Menu and select the same signal source you connected to the back.(Antenna or Cable)
3) Go to the auto program/scan menu and run it. This may take a few minutes.
Now the channels may be watched.
Mar 16, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Tuning Sony KDL 32U3000 for Sky TV
Hi Max,
I an not familiar with Sky TV, I assume it a Cable or Satilite Service.
Here are a few things to check.
  1. Press the INPUT button on the TV remote or on the TV control panel, cycle through all inputs and see if you get a signal.
  2. From the TV's Video Menu, set tuning band to Cable and not to Air or Antenna.
  3. From the Video menu Scan for channels, there should be a Auto Scan option.
Try these and let me know how it goes, I can be of further assistance.
Lone99star
Feb 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Jan 14, 2009 | JVC LT-32E479 LCD TV
Jul 28, 2009 | Televison & Video
Channel scanning
yes file for repair as everything you would have to do to fix this means opening it. and likely voiding the warranty.
Feb 19, 2008 | Samsung LNT3242H Television
Televison & Video Logo
Top Televison & Video Experts
