Question about GE Profile Arctica Customstyle Side-by-side Refrigerator Psi23ncnbb
GE Profile Arctica not making ice
PTS25LHPPTS25SHP
    Genius:
  • 1,669 Answers
Check to see if the fuse for the icemaker is blown. Check to see if the linkages are moving. Check the activation motor is getting power.
Posted on Jan 20, 2013
Testimonial: "After two days of not making any ice cubes, my fridge suddenly started producing cubes again... go figure. Anyway, my thanks to all for the suggestions."
Have a ge profile refrigerator went completely dead,repair man replaced mother board and control panel still not working, fridge is only 14 months
If there is no power after the repair man replaced the board and panel, the repair job is not complete. Have the repair man finish the job.
May 03, 2016 | GE PFE29PSDSS 29 cu. ft. French Door...
Ge profile refrigerator temperature setting
Sounds like the damper controller is stuck due to obstruction or isn't working at all and needs replaced.
Jul 31, 2014 | GE PFE29PSDSS 29 cu. ft. French Door...
Water drip on to floor from rt.rear. profile side by side
Tube may be a ice maker supply line. You can replace it at any home depote
Apr 29, 2014 | GE Profile : PSCS5RGXSS Refrigerator
IHave a ge side by side refrigerator not cold enough and freezer has frost on back wall and some items are not frozen
your GE self defrost is not working. 1. clean the ice and look for the heater element and your lemi switch. If you have a GE profile, they have a motherboard at the back of the ref. if all i the part i mentioned are working, just replaced the motherboard. at searspartdirect.com
Apr 06, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
On the freezer side their keeps being water frozen in bottom
The drain to it is stopped up or the heat strip that melts the ice has gone bad. When working right, the water should drain out. The water goes into a pan under the freezer and evaporates.
Jan 27, 2013 | GE Profile Panel Ready 24.6 Cu Ft White...
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 | GE Freezers
Ge profile refrig - watrer dispenser does not deliver water. Ice maker works fine. What is wrong?
Water solenoid at the rear of the fridge has failed, there is two or three solenoids there, locate the one that does water feed to the door (not ice maker) and do a load test or just replace. Also make sure you dont have a filter safety cut-off, check filter cond and it is located perfectly in housing, check lines inside and outside fridge unit for obstructions. Good luck.
Feb 27, 2011 | Continental Freezer Wide...
GE Profile Side by Side - PSS26lsrc - Unit whistles - like wind noise. Also does not produce as much ice as it used to. Need to pres 'quick ice' to get it to make ice.
I know of two things which can cause the noise. Since it hasn't always made the noise I would guess the motherboard is making it. Try to pinpoint the noise. Your motherboard is on the back. Part 801 on this diagram. If this is where the noise is coming from and you can put up with the noise, you can wait till you have more trouble with it. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=PSS26LSRCSS&productCategoryId=0165000&brandId=0432&modelName=REFRIGERATOR-R-SERIES&diagramPageId=00009&componentDescription=SEALED%20SYSTEM%20&%20MOTHER%20BOARD&documentId=G0503214&backToLink=Return%20to%20Sub%20Components%20list
Another cause I've seen is because of the unique shape of the condenser coil. With the air pulled through it it can make a noise. It may help to clean the coil which may also help the ice situtation. It's part 730 on the diagram.
Sep 08, 2009 | Freezers
Freezer temp
Was the condenser fan back there running. It should be when the compressor is.
Is the fan in the freezer running. Check for ice buildup on the back wall and behind the back wall cover on the evaporator coil. Heavy ice here would be defrost problem.
Jul 12, 2009 | Freezers
GE Profile Arctica Customstyle Side-by-side Refrigerator Psi23ncnbb Logo
238 people viewed this question
Top GE Freezers Experts
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
AJMAL KHAN
Are you a GE Freezer Expert? Answer questions, earn points and help others
