Question about LG 42LC7D-UB Television
LG 42LC7D turns on ok but no display or sound,tried using monitor out with another tv but no picture either
Tv seems to start up ok but nothing appears on screen. can see backlight, pressing remote and tv responds by blinking green light on front but nothing happens on screen. i plugged in another tv into monitor out to see if anything was happening but nothing comes out.
  • LG Master
  • 3,904 Answers
Check to make sure you have the right input selected for the input that ou have plugged into.
Posted on Jan 20, 2013
  • 12 Answers
SOURCE: Hard time turning on tv. I turn it on, green light flashes a few times then becomes solid green. No picture or sound. I turn it off and light becomes red. I do this at least 5 times before tv will
There are some capacitors on the main boardthat are low quality. You can buy a capacitor repair kit on Ebay that contains a set of capacitors to replace the offending ones - about 15-16 bucks. I soldered in the new capacitors and the TV has worked perfectly since.
Posted on Nov 28, 2011
tvservice306
  • 458 Answers
SOURCE: my LG 42LB5D TV turns on after the LED blinks 11
REPLACED MANI BOARD
Manufacturer LGE Part Number EBU39191501 Description MAIN TOTAL ASSEMBLY
Posted on Sep 19, 2009
SOURCE: No Sound, No Picture on LG 42LC7D
I do not have a solution but I have the same situation with my tv
Posted on May 25, 2010
SOURCE: Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Posted on Jul 28, 2012
SOURCE: Screen is black even though the green light is lit
sound like you have some bad capacitors inside your tv take the back off and check them if capacitors are raised up on top they are bad
Posted on Sep 02, 2012
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Hard time turning on tv. I turn it on, green light flashes a few times then becomes solid green. No picture or sound. I turn it off and light becomes red. I do this at least 5 times before tv will come...
Nov 11, 2011 | LG 42LC7D-UB Television
LG 42LC7D.......Have sound but no picture at all. Light goes from red to green and sounds as though the screen tries to turn on but no picture.
It sounds like you have a logic board problem. It is easy to fix open up your tv on the back and the logic board should be covered with a small metal plate unscrew the it, it uses small screws get the number of that board an order it through guytvparts.com is the cheapest
Apr 03, 2011 | LG 42LC7D-UB Television
I have the exact same issue as the unsolved problem below on this page: I have a LG 42LC7D that is about 3 years old. A Problem with the LG 42LC7D-UB Television I have a LG 42LC7D that is about 3 years...
The power on problem is a cap in the power on circuit. The loss of signal for an areal is delayed. Nothing you can for DIY.It needs repair shop visit.
Feb 12, 2011 | LG 42LC7D-UB Television
Dec 27, 2009 | LG 42LC7D-UB Television
My Lg 42lc7d 42 inch flatscreen tv has no sound
1- check all the cables that are hooked up to the TV 2- try to get audio to and external speakers or home theater (to check the sound card). 3- if the step # 2 don't work either you have a bad sound board on your TV. 4- opn the TV try t get the part # of the board, and replace it
Nov 11, 2009 | LG 42LC7D-UB Television
Lg 42lc7d turns on to blank screen doesnt respond to any request
I need sreen for LG 4LC7D-UB because the screen is damaged
Mar 16, 2009 | LG 42LC7D-UB Television
Can't play PS3 on LG 42LC7D tv
use hdmi cable from ps3 to rear of tv (you should have hdmi 1 & hdmi 2)then ppress input on remote until you get hdmi 1 or 2 on screen walaa
Dec 20, 2008 | LG 42LC7D-UB Television
LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Jul 28, 2008 | LG 42LC7D-UB Television
LG TV Making Bad Noise
have u tryed new cables for sound 1st
Feb 03, 2008 | LG 42LC7D-UB Television
LG 42LC7D-UB Television Logo
191 people viewed this question
Computer Repairing
Computer Repairing
