Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Murray snow thrower model 629104x6 spark plug gap
    Genius:
  • 1,669 Answers
Ask the supplier here:
http://www.sparkplugs.com/category.aspx?zcid=202&gclid=CIyM8fDV9bQCFQLd4AodfU0A8g
Posted on Jan 20, 2013
5 Suggested Answers
huffman49
  • 235 Answers
SOURCE: Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Posted on Apr 14, 2010
  • 36 Answers
SOURCE: Will a snow thrower 42" Mod. no. 486.248392
As long as your deck mounts match up then you should be good to go. You might have to change to a different sized belt though. Other than that everything should be fine.
Posted on Feb 08, 2011
  • 144 Answers
SOURCE: I need to know what number spark plug for a Murray
Hi iwl3792,
I will try to help you out. This riding mower has a Tecumseh engine and the recommended spark plug is a Champion L82C or equivalent. The electrode gap should be 0.030 inch (0.76 mm) for all models. I hope this is helpful. Regards and good luck. Denis.
Posted on Mar 19, 2011
bigguy810
  • 448 Answers
SOURCE: Will a Craftsman 42" model 486248392 snow thrower
it shooed fit with no problems but first check the crank shaft
to make sure they are the same size that's always ben the
problem trying to switch motors let me no if you need more
assistance
i hope this helps you
bob
Posted on Jun 07, 2011
How do I get the left wheel of a Murray snow thrower to engaged when the traction lever is engaged?
You will find there is a shear pin that has broken in the wheel that will not engage. Not sure if its a pin or bolt. I had to replace one several years ago.
Jan 24, 2016 | Murray Feiss Murray 27" Dual Stage Snow...
I am looking for belt size for HABAN 24577 snowthrower to Murray 18hp lawn tractor. Book doesn't provide size info.
I have a Haban Model No. 24577A 42" front mounted snow thrower attachment, which I have mounted to a Murray lawn tractor. I needed to replace the lower drive belt, labeled: V-Belt-Long Part No. 23948 in my Haban manual. I had found it next to impossible to find a replacement belt part number or cross-reference to other brands. I tried many belt sizes and lengths to no avail - belts broke quickly and suddenly after 1 or two uses.
While researching Haban on the internet, I realized that they also supplied snow thrower attachments for Sears Craftsman lawn tractors. A thought hit me at one point in my research... that Haban probably sold the same snow thrower chassis to all manufacturers, but only with different interfaces to the tractors. So I ordered up a belt for a different Haban model that was supplied to Sears, and I think that my intuition was correct!! I have found a belt that works with my Haban Model No. 24577A snow thrower.
The belt that appears to be a direct replacement for the Haban belt part number 23948 (long) is as follows: Kevlar Blue V-Belt 5/8" x 87". It is sold by several suppliers under various part numbers, priced at $20 to $30.
I hope this helps you.
Jan 19, 2011 | Garden
I need to know what spark plug to use for my snow thrower. My son lost the one I had taken out to be replaced.
If snow thrower uses ordinary gasoline, then go to hardware store and get spark plug for lawn mower.
If snow blower uses 2-cycle engine oil mixed with gas, then get spark plug for weed eater.
Or buy both and try them out.
Hardware store is more likely to have someone familiar with which spark plug you need than box-size home center.
http://www.toro.com/home/customercare/interactivemanuals.html
Dec 26, 2010 | Garden
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
I have a craftman snow thrower, model#536.886122, serial#632722946 and I'm in need of a manuel.
Manuals of Sears products are available through their 'Parts Direct' system and have been resonable in price. The last one for a riding mower cost ~$7.00
Sep 21, 2009 | Tools & Hardware - Others
Toro powerlite snowblower sputters out after 10-15 minutes
I would change the spark plug and be sure to gap it as per your owner's manual. I would also clean or change the air filter. I would also use only high test gas and the oil recommended by the manufacturer. good luck.
Jan 14, 2009 | Mowtownusa Snow Thrower Starter Switch for...
My snow thrower wont start
Change the spark plug being sure to set the spark plug gap as recommended in the owner's manual. Then clean or change the air filter. Finally use new high test gasoline. good luck.
Jan 12, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Jan 11, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
