Water will not fill into tub
I just replaced the pcb board because the unit was not draining or even starting (pump was ruled out as an issue). Now, it starts right up and sounds like it is trying to fill with water but nothing is going into the drum. It just worked 2 days ago when the technician diagnosed the bad pcb board. I am not getting an error codes, it just keeps running and trying to fill. The time on the display never changes either. Is there something that needs reset on the pcb board or something?
    Sergeant:
  • 291 Answers
Push the buttons or turn the dial which ever you have that changes water temperatures. Select each temp and check for water entering the tub. Let me know what you find.
Posted on Jan 20, 2013
SOURCE: GE frontload washer will not wash cycle or spin out
Thanks to Guest #2 our laundry is back in action and we're not waiting for a serviceperson. We took the front panel off, unscrewed the white plug and was sure our plastic drawer was open to catch the water, a load's worth. We found a small screw driver, 8 or so pony holders, some change, drill bits, bark, games pieces, can tops, etc... unbelievable. Thanks SO MUCH for the hint!
Posted on Nov 22, 2007
  • 1294 Answers
SOURCE: Drain pump runs constantly:Error code E02
Suggestions: First see that the exit hose behind your machine is inserted at a particular height, ie about 3 feet above ground level, then into the standpipe in your wall. If things dont work plug off the wall, open up behind, you will see a thin pipe coming down from the pressure switch to the drain area. Disconnect this pipe carefully from the top and blow into it, it should be free. If blocked clear, if broken or damaged change. Refit carefully.
Pl rate me helped.......
Posted on Dec 28, 2007
SOURCE: Admiral Washer AAV7000AWW everything works -goes through cyclebut will not drain
You,ve done a good job the first time the pump fail MikieM. You can do it again. We sometimes forget to empty our pocket. Some small metal things could have gotten into the pump...could be other hard foreign object. Good luck.
Posted on Dec 29, 2007
  • 107 Answers
SOURCE: Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Posted on Mar 18, 2009
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Posted on Mar 20, 2009
Can you tell me what error code E12 is on a Bosch vision 300 washer?
I am not quit sure if my answer will help you, but I am going to tell you the cycle
The unit fills to whatever water level you choose to use
After reaching the water level the the wash begins, after 20 or 30 minutes of washing it needs to drain the soapy water. The drain pump turn on draining the water, after draining the unit fill back up to the settings and or sprays water while doing the draining and spinning to remove as much dirty water as possible from the first wash. After the first draining, fills back up again for the final rinse and the final drain
The symptom you are describing, here tell me, that issue is with the drain valve, drain hose, the sewer, or is a big possibility that there is is a sock or woman garment stuck in inside holding the rotor causing the water not drain inside the water valve, if the sensors are not sensing the opening of the pressure switch after the first fill. it will not continue This units lately has been added many sensors the only thing this unit doesn't has is the ability to speak but if using common sense you can get to the part that needs to be replace. You need to read and understand the wash cycle first.
Nov 24, 2017 | Bosch Washing Machines
Why when we start the wash the water goes in and drains right out so it just keeps doing that
check your drain hose going to the drain pipe in the wall. if the drain hose is lower than the highest water level on the unit, it will cause a siphoning issue. water will run into and the never fill enough to start into cycle. If unit is filling and the drain pump is on at the same time it is filling, then it is a bad control board.
Feb 12, 2015 | Amana Washing Machines
What is F27 error code?
The F27 error code indicates an overflow condition. If the washer is overfilled and continues to fill with water, this would indicate that you have an inlet water fill valve that is stuck open. If you unplug the washer and water continues to fill the tub, then the inlet fill valve assembly will need to be replaced. Make sure that the drain system is properly installed according to the installation instructions. An improperly installed drain system could result if siphoning of drain water back into the washer.
Check to see if the drain pump is working properly to pump out the water. When the F27 occurs, the drain pump will run constantly to pump out the water. The door will remain locked. Shut off the water supply faucets behind the washer. If water is not being pumped out of the washer, you could have a clog in the drain pump or drain hose. The following link of a previous answer provides advanced troubleshooting for a drain problem:
Why won't my HE4t washer drain?
If the washer is not overfilling and the F27 remains even after the washer is drained, then it is likely that you have a failed pressure switch. A failed electronic control board in the washer could also cause this problem. To access the pressure switch, unplug the washer and remove the top panel. Screws at the very back of the top panel secure it to the washer. Remove these screws and pull the top panel slightly back and then up and off of the washer. Sometimes, you can reset a stuck contact in a pressure switch by tapping on it with the handle of a screwdriver. I you cannot reset it, the pressure switch will need to be replaced. If you have the same problem after replacing the pressure switch, you will likely need to replace the control board in the washer.
Aug 19, 2014 | Kenmore Washing Machines
Washer drains at it fills up, so water level never gets to where it needs to be. This is in all cycles. Machine never get to a point where it starts running.
Your drain hose needs to have the "curved" part above the level of the basket top. Otherwise, water will continually run out (usually onto the floor).
Some models have a stand alone water pump that is turned on to drain the washer. The timer (during drain, spin, etc cycles) turns this pump on and off. If your hose is inserted into the stand pipe as it should be, then the water pump being turned on is likely the problem.
Since you aren't mentioning that water is all over your floor, I think that a loose / torn hose can be ruled out as well. You need another timer switch assembly.
Jun 28, 2010 | Maytag HAV2557 Top Load Washer
Had a LD error and successfully cleared clog in waste water tank. Turned it on and pump worked perfectly to pump out water. Started a new cycle to test everything and things went wrong. First, the tub...
If the water keeps filling with the unit unplugged you have a bad water valve(or low house pressure)
If the unit does stop filling when unplugged you have a plugged pressure hose to the pressure switch or a bad pressure switch. To access you peel back the front emblem to remove a screw in the center. This allows you to raise the top to check the pressure hose. You can also find the end of the hose at the control panel to blow through it, should be clear when tub is empty of water. A hole in the pressure hose would also cause flooding. This hose connects from the bottom of the outer tub to the pressure switch in the console to control the water level in the tub. Unit will not turn on drain pump if it does not sense water in the tub......
good luck......
Apr 06, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Keeps filling up with water even on spin
Close the water supply valve and allow the machine to completely drain the water from the tub. Turn off the machine and disconnect it from the power outlet. Open the water supply valve. Replace the water inlet valve if water drips into the tub when the machine is off.
Start a new cycle if the machine stops filling when it is off. The control board or the water level switch is malfunctioning if it keeps filling even during the spin cycle. Indicate the model number for proper troubleshooting and repair assistance.
Feb 05, 2010 | Washing Machines
Maytag FAV6800AWW - Major overflow right after starting machine
Hi, If you turn the water source valve on and water starts filling the machine even tho the machine is off, change the inlet valve.
If you have to start the machine so water will fill but, the water does not shut off at the desired level, there is a problem with the water level switch.
I hope this helps you. Please let me know if I can assist you further.
Vic.
Jun 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Fill up the tub but never spin and then drain, suggestion please?
The same issue occured with me. I spoke with Customer Service as the unit was still warrantied at that time. A Technician come out; his experience was common with this Bosch unit as he had learned over the months that Bosch has sub-contractors that supplied faulty and/ or sub-par circuit boards and components. This particular board was replaced and the incident did not recur.
Mar 21, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
LG LDF6810 Dishwasher Starts filling with water then pumps water
Because you are not getting an error message, I agree that the controller card is malfunctioning. Almost everthing else would triger an error.
Recommend replacing the controller card.
Feb 19, 2009 | LG LDF6810 Built-in Dishwasher
Spin cycle issue
if this is a frigidaire as in the healine , then see if the tub turns over at all. if not then it may be the inverter board located on the bottom right rear. If there is water left in the tub now that water should drain before it will fill again. check drain pump for obstruction/operation.
for the inverter, there is a techsheet in the bottom attached to the wall, It gives info for checking it. Have a multimeter handy.
Apr 23, 2008 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
