Question about Kenmore Elite 45986 Front Load Washer
Odor The compartment where you put soap and bleach smells moldy and mildewy. Our towles always have a mildew odor even if you wash on hot
  • 3 Answers
I had the same problem and purchased various products for my HE that is too efficient. The first product I purchased was Affresh made by Whirlpool, was expensive and did nothing. Next I found WasherFresh at Sears, works great and I've been using it ever since.  Please note I did find it at Sears Canada, not sure if it is available at Sears U.S.
Posted on Feb 13, 2009
  • 130 Answers
Run a cup of vinegar thru a wash cycle, put it in like soap. i have also seen people use scolding hot water in the dispenser to disolve the soap and softner build up.
Posted on Jan 26, 2009
Washing machine smells like mould
The odor may come from several sources. Mildew may be around the door's gasket. That might be cleaned with a rag and a half bleach/half water concoction. The soap dispenser tray may have had stagnant water present. Other hose areas may be growing mildew.
Here are some things you can try:
1) Run dishwasher powder detergent once a month through the washer. Or...
2) Run 3 quarters cup of bleach through an empty hot wash cycle once a month.
3) Yes, baking soda, ye olde oder absorber, can also be tried.
3) Clean the trap (where coins, etc. may be captured). Clean the filter.
Some High Efficiency machines have "high efficiency, HE detergents recommended for them. Does the drum have a soapy coating? If so, it will likely require at least an empty hot water cycle to get rid of the excess soap which may be responsible for the smell.
Naturally, if you are using bleach to clean the the washer door, you want to clean the bleach off too before you ruin some clothes by contact.
Hope this helps.
Aug 04, 2015 | Washing Machines
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Water drains into soap dispenser; how do you prevent this? Mildew smell!
Most home improvement stores sell a washing maching cleaner product - try this or simply run the machine on the longest cycle with 2 cups of bleach added directly to the drum to eliminate the smells. Also check around the seals on the door and drum - lint and small items can collect there and mildew. For the drain problem, ensure that you washer is level or slightly leaning back ( no more than just slightly) and this could fix the problem. If not that, the pathway from the dispenser to the drum could be clogged with dried soap - try flushing it with very hot water while it is open for at least 20 mins. Fill it up, wait to drain, and do it again. You can also remove the soap dispenser tray to clean and take a look behind it with a flashlight - refer to the manual for specifics on how to remove the tray. Good luck!
Jun 29, 2012 | LG Washing Machines
Clothes stink!
Odor from your washing machine is being transferred to your clothes.
The washer must be cleaned first or it will "reinfect" your clothing upon washing. The secret is to clean the "splash area" just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this area add a washer cleaner to a full load of laundry and wash in a hot setting. The added bulk of the laundry will raise the water level to include the splash area. During this cleaning intermittent pausing to soak will give the cleaner time to dissolve the moldy mess.
Also, leaving the door open makes the problem worse because it dries out the residue which makes it harder to remove.
Jul 18, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Mildew/moldy seal
This moldy look could also be due to alot of 40 degree or less washing temperatures where the bacteria cannot be killed therefore a once a month maintenance wash at max temp would help solve this.
Feb 18, 2009 | LG WM1814CW Front Load Washer
Odor in front loading duet washing machine
The following link explains how to minimize wash tub odor, and what generally can cause it:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
I personally own one of these washers and have followed this same regiment since I purchased it new 9 years ago. I have never had a mildew or odor problem. Consumers that are not in the habit of using hot water very often will also run into odor and mildew problems, because detergent alone does not always kill bacteria. It is recommended that you run a "Clean Cycle" from time to time, to sanitize. Some newer models have a clean cycle added on the control panel.
NOTE: It is normal to have residual water in the drain lines and in the drain pump. If you need to clean, or check the drain pump, please follow the advice in this next link:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Debris caught in the drain pump reservoir can often cause some unwanted odors.
If the rubber door bellow develops mildew and mold, use a non abrasive pad (the little green pads are considered non-abrasive) and scrub the rubber with bleach diluted with water (50/50 mix). This will often kill and remove unwanted mold and mildew. If the door bellow becomes embedded with mold or mildew, it may have to be replaced in order to get rid of it.
If you establish and maintain a diligent routine, these washers will not mold or smell. Often what seems to be a dream appliance that is supposed to make your life easier, may actually require more attention in order to maintain it properly.
If you have questions or comments, please let me know. I hope this helps you.
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine odor
www.affresh.com this product has been devoeloped to lessen front loader odors. you NEED to be using an HE detergent. low sudsing ans specifically design for use with front loading washers.
Oct 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Disgusting odor
I had the same problem, except it wasn't just towels. It was everything. I did some research and found that this is a common problem and nothing a tech can fix. I was about to go out this weekend and spend $1000 on a new washer because I couldn't use this washer on my clothes anymore. I did one more search for a solution and THANK GOODNESS found a solution on another site. A woman had the same problem and, after much trouble, someone at Best Buy finally told her to never use liquid detergent in the machine, not even HE. So I cleaned the inside of my machine, around the door, the rubber seal, etc. I ran the tub clean cycle with bleach and vinegar. The smell was gone and I have been using powder Tide ever since, and the smell hasn't come back!!!!!
Mar 12, 2008 | LG WM2688H Front Load Washer
Foul water odor after wash
There is always a littlee water left in the sump of a washer after it is emptied. If the washer sits unused for as little as 2 or 3 days it can have that odor. One thing that I do is add about 1/4 cup of ammonia after the washer is full of water. DO NOT USE AMMONIA IF YOU USE BLEACH IN THE SAME WASH!!! IT WILL CAUSE CLORINE GAS TO BE RELEASED!! If bleach was used in the previous cycle it will be ok.
Feb 28, 2008 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Kenmore Elite 45986 Front Load Washer Logo
117 people viewed this question
Sal De
fordexpert
Robert Rankin
