Question about Dishwashers
Kenmore dishwasher model 17761/17765 not draining
Model listed above does not drain.. Has been working fine until 2 days ago. Found 2 pieces of busted plastic in front, removed and still will not drain. How do I access pump area so I can check that as well.
tzweeb
  • 318 Answers
SOURCE: dishwasher not draining - Kenmore dishwasher model 15754
depending on the age of this unit it may have food blocking what is called the "check valve".
on most models it is mounted right on the outlet of the pump housing. one model uses a 4 inch plastic tube style device and is about 1/2 inch on the pump and 1" on the hose. inside of it is where the food items can block the check valve. remove the hose and unscrew the check valve from the pump and see if something is blocking it.
on newer units the check valve is built into the drain hose, if you hose has a 90 degree elbow molded into it where the hose hooks up to the drain pump. once again take the hose off and look inside the hose or try to blow through the hose and see if the hose is clear.
good luck tom
Posted on Dec 31, 2008
  • 9 Answers
SOURCE: Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Posted on Jan 02, 2009
  • 10865 Answers
SOURCE: Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Posted on May 28, 2009
garing
  • 998 Answers
SOURCE: Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
Posted on Aug 11, 2009
localwonder
  • 6784 Answers
SOURCE: Potscrubber 900 Dishwasher won't drain
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Aug 27, 2009
Kenmore Elite dishwasher will not drain
If the drain pump won't run, the most common cause is something hard (like a piece of glass or hard plastic) got into the pump and is blocking the impeller. If you want to fix it yourself, first unpug the dishwasher. Then you will need to either siphon the water out of the sump area or use a wet vac to suck out the water from the sump area. Then remove the toe-kick panel so you can get to the underside of the dishwasher. Depending on the model, you may be able to access the drain pump from there, or you may have to pull the dishwasher out. Then you can remove the end of the drain hose and check the area there. If that's okay, you can remove the drain pump by finding and pressing on the release button or lever, and turning it 1/8 turn counter-clockwise, If there's an obstruction, you will find it now. If no obstruction, then you probably have a bad drain pump and will need to replace it.
Jan 07, 2013 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 15652 model. won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
Apr 22, 2011 | Kenmore 24 in. 15652 Built-in Dishwasher
My Kenmore elite dishwasher 665.13793K600 has 2 problems: 1. won't drain water 2. won't even start working today Please help!
I have a Kenmore model # 665.13793K600 and it has been having a small puddle of water remaining in the bottom at the end of each cycle. I've taken it apart and cleaned it. I'm thinking I may have the drain hose incorrectly positioned or it could even be something unrelated. I can only think of the drain because I replaced the kitchen faucets a coupe of months ago and it could be since then that this has been happening.
Sep 09, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
A Kenmore model 15522000 type 280-1 dishwasher will not drain
I scooped out the water and found a spoon jammed in the drain area. Works like a charm now.
Feb 04, 2010 | Kenmore Dishwashers
Kenmore Elite: Model 66576962K601.
I had exact same issue. I've called Sears Maintenance. They had to change 2 pieces in UI: Timer KUDS02SRB10 and CONSOLE Assy. Cost 360$ pieces  130$ Job Charge 60$ taxes.
Now It works perfectly, but I bought 1100$ 3 years ago... Really expensive to keep it running.
Nov 29, 2009 | Kenmore Dishwashers
Kenmore Ultra Wash 15812990 won't drain... I have already checked the connection between the dishwasher and the house drain line and the issue is above that. Someone suggested I clean out the food...
I removed the kick plate and unhooked the hose that connects to the bottom of the dishwasher. When I didn't get a gush of water, I knew my problem was higher than that. I took a pair tweezers and stuck it up the spout and found nothing. So I attempted to drain the diswasher with the hose unhooked and got some water to come out. I did this several times and apparently flushed down a large piece of rubber--either from a water bottle or a broken piece from inside the dishwasher. I removed that piece and had pressure when the drain button was activated. So I hooked the hose back up and ran a rinse cycle--and it drained fine.
Oct 30, 2009 | Kenmore Dishwashers
Aug 11, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
Owen Barnes
